I have a home assistant feature that does fail sometimes at the first command, so i wanted a flow that when this happens there are 3 retries before another action takes place (msg + restart application).
I've cobbled something together with info found on the forum, but i'm sure there are more simple ways of building this. Any input would be welcome.
"id": "a7c11995713d7dca",
"type": "tab",
"label": "Flow 2",
"disabled": false,
"info": "",
"env": []
"id": "f6f2ab575394f14f",
"type": "inject",
"z": "a7c11995713d7dca",
"props": [
"p": "payload"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "test",
"payloadType": "str",
"x": 370,
"y": 340,
"d83f8261fda92a3e"
"id": "d83f8261fda92a3e",
"type": "api-call-service",
"name": "action",
"server": "43edf570.794d9c",
"version": 5,
"debugenabled": false,
"domain": "switch",
"service": "turn_off",
"areaId": [],
"deviceId": [],
"entityId": [
"switch.plugbeneden_wekkerd_5"
"data": "",
"dataType": "jsonata",
"mergeContext": "",
"mustacheAltTags": false,
"outputProperties": [],
"queue": "none",
"x": 610,
"y": 340,
"55e53661163af3fc"
"id": "d441858f37d90197",
"type": "function",
"name": "count to 3 send close",
"func": "\nlet msgCount = flow.get(\"msgCount\") || 0;//get remembered count\nlet sendMessage = false;\nlet countMessage = \"\";\nmsgCount++; //increment count\n\ncountMessage = \"Count of payload 1: \" + msgCount;\n\nif (msgCount >= 3) {\n msgCount = 0;//reset counter\n sendMessage = true;//instruct code to send the msg\n msg.topic = \"control\";\n msg.payload = \"close\"; //set payload to a string of \"1\" as you requested\n}\n\nflow.set(\"msgCount\", msgCount); //remember count\nnode.status(countMessage);\nlet msgWithCount = { payload: countMessage };\n\nif(sendMessage) {\n return [msg, msgWithCount];\n} else {\n return [null, msgWithCount];\n}\n\n\n\n",
"outputs": 2,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 680,
"y": 460,
"a51a482896d5908a",
"e3994347eb9acb5b"
"011f256f4332d61f"
"id": "a51a482896d5908a",
"type": "gate",
"controlTopic": "control",
"defaultState": "open",
"openCmd": "open",
"closeCmd": "close",
"toggleCmd": "toggle",
"defaultCmd": "default",
"statusCmd": "status",
"persist": false,
"storeName": "memory",
"x": 1090,
"y": 360,
"d441858f37d90197"
"id": "011f256f4332d61f",
"type": "delay",
"pauseType": "delay",
"timeout": "3",
"timeoutUnits": "seconds",
"rate": "1",
"nbRateUnits": "1",
"rateUnits": "second",
"randomFirst": "1",
"randomLast": "5",
"randomUnits": "seconds",
"drop": false,
"allowrate": false,
"outputs": 1,
"x": 360,
"y": 400,
"d83f8261fda92a3e"
"id": "e3994347eb9acb5b",
"type": "delay",
"timeout": "5",
"rate": "1",
"nbRateUnits": "1",
"randomFirst": "1",
"randomLast": "5",
"drop": false,
"allowrate": false,
"outputs": 1,
"x": 1080,
"y": 460,
"76ec6703b51d4db9"
"id": "76ec6703b51d4db9",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "open",
"tot": "str"
"t": "set",
"p": "topic",
"pt": "msg",
"to": "control",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1280,
"y": 460,
"a51a482896d5908a",
"fd43bb5041e3bf12"
"id": "fd43bb5041e3bf12",
"type": "change",
"name": "Msg",
"rules": [
"t": "set",
"p": "title",
"pt": "msg",
"to": "Rc35 day mode not activated",
"tot": "str"
"t": "set",
"p": "message1",
"pt": "msg",
"to": "Check ems!",
"tot": "str",
"dc": true
"t": "set",
"p": "message2",
"pt": "msg",
"to": " ",
"tot": "str"
"t": "set",
"p": "message3",
"pt": "msg",
"to": "",
"tot": "str"
"t": "set",
"p": "sound",
"pt": "msg",
"to": "",
"tot": "str"
"t": "set",
"p": "critical",
"pt": "msg",
"to": "0",
"tot": "str"
"t": "set",
"p": "volume",
"pt": "msg",
"to": "1",
"tot": "str"
"t": "set",
"p": "target",
"pt": "msg",
"to": "mobile_app_davids_iphone",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1510,
"y": 460,
"e3ebcd14fc372a41"
"id": "e3ebcd14fc372a41",
"type": "link out",
"name": "link out 161",
"mode": "link",
"links": [
"6ee3f7c73fa6aab3"
"x": 1635,
"y": 460,
"id": "55e53661163af3fc",
"type": "api-current-state",
"name": "control action on?",
"version": 3,
"outputs": 2,
"halt_if": "on",
"halt_if_type": "str",
"halt_if_compare": "is",
"entity_id": "switch.plugbeneden_wekkerd_5",
"state_type": "str",
"blockInputOverrides": false,
"for": "0",
"forType": "num",
"forUnits": "minutes",
"override_topic": false,
"state_location": "payload",
"override_payload": "msg",
"entity_location": "data",
"override_data": "msg",
"x": 810,
"y": 320,
"6bfe3823fd554214",
"ae857c9227626769"
"a51a482896d5908a",
"b9ee918c4adb69da"
"id": "6bfe3823fd554214",
"type": "debug",
"name": "All Ok = do something // set counter to 0",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"statusVal": "",
"statusType": "auto",
"x": 1180,
"y": 280,
"id": "b9ee918c4adb69da",
"type": "debug",
"name": "Not ok = repeat message 3 times // then other action",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 1220,
"y": 320,
"id": "ae857c9227626769",
"type": "function",
"name": "reset counter to 0 if all ok",
"func": "var count = flow.get(\"msgCount\") || 0;\nflow.set(\"msgCount\", 0);\nmsg.payload = \"counter set to \" + count;\nreturn msg; ",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 1130,
"y": 240,
"id": "a9facd51c3fa600b",
"type": "inject",
"name": "reset counter",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"payloadType": "date",
"x": 850,
"y": 240,
"ae857c9227626769"
"id": "43edf570.794d9c",
"type": "server",
"name": "Home Assistant",
"version": 5,
"addon": false,
"rejectUnauthorizedCerts": true,
"ha_boolean": "y|yes|true|on|home|open",
"connectionDelay": true,
"cacheJson": true,
"heartbeat": false,
"heartbeatInterval": "30",
"areaSelector": "friendlyName",
"deviceSelector": "friendlyName",
"entitySelector": "friendlyName",
"statusSeparator": "at: ",
"statusYear": "hidden",
"statusMonth": "short",
"statusDay": "numeric",
"statusHourCycle": "h23",
"statusTimeFormat": "h:m",
"enableGlobalContextStore": true
