Countdown Gauge/Bar ? anyone know of one?
Guys,
I want to create a Status page on my NR dashboard that will keep track of all my different sensors, devices etc and alert me visually if one has not checked in for a period (and also provide a visual indication of how far along until the next check in.
So say i have a node that sends its temperature measurement every 10 minutes, i would like (say) a 10 segment LED bar representation - all of them start out green and then as each minute counts down they fade out. If after 10 minutes the sensor has not been heard from , then they will start to light up RED until all 10 are lit and then messages (emails, Telegram etc) will be sent to warn that a sensor is not communicating.
Anyone seen anything like this ? I would assume it would be some form of angular to be inserted - at this stage that is way above my ability though - so i hope there is an easier answer
Craig
Just found there is actually one already built !!
Must not have had the right terms when searching before.
Craig
For future reference, can you post a link pls Craig.
Yep sorry - was just playing with it to make sure it was all good - seems great after 15 minutes playing
https://flows.nodered.org/flow/1538793825685bd8f08e4aea16ca2c74
Craig
