Covid application form help
Dood day.
Iv been at it for 2 days now. I'm trying to make a covid application form to save the data to a MySQL db. the problem I'm having is the text input node on the UI, send the payload when you finish typing and then the db is very messy. if tried the joined node but if you enter different text inputs it sets everything in the wrong place. What i need is for the text input node's to hold the payload till a submit button is pressed then send all the payload, or a function to wait for all the appropriate payloads then sent the string (iv been playing with context with no luck). I'm new to java scrips.
flows.json (5.4 KB)
Thanks in advanced.
Did you try the ui_form node ?
No, no i have not. thank you(i feel live a complete ID10T)
