Create msg with nested object fields
I am new to NodeRed and I'm having trouble with parsing and generating msg. I have a nested object message that I am tried to parse into a new msg. The message is coming from an MQTT In node. In the debug window I see:
Here is the payload from the MQTT IN Node:
 object
   topic: "sensor/pushnotification"
   payload: "
   {"topic":"sensor.basement_hall.battery","payload":"Battery Low Warning","subtext":"10/9/2022
   09:55:47 AM","count":null,"percent":null}"
   qos: 2
   retain: false
   _msgid: "7042e909d390b98f"
I run that msg through a JSON node and here is the msg output:
 object:
   payload: object
        topic: "sensor.basement_hall.battery"
        payload: "Battery Low Warning"
        subtext: "10/9/2022 09:55:47 AM"
        count: null
        percent: null
  qos: 2
  retain: false
I want to generate a new msg with some of the nested object fields and I can't seem to figure out how to reference them in a function. For example :
 var sTopic = msg.topic.payload.topic;
 var sPayload = msg.topic.payload.payload;
 var sSubtext = msg.topic.payload.subtext;
 msg = {
     payload : sPayload,
     topic : sTopic,
     subtext : sSubtext
That results in:
function: (error) TypeError: Cannot read properties of undefined (reading 'subtext')
Try msg.payload.< property > instead
Use the tools the editor provides...
There’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path to any data item.
BX00Cy7yHi
Thanks Steve,
I tried using the copy path button for the nested payload value and it returned
payload.topic
which returned
I replaced it with
msg.payload.topic
in the function and which resulted in
Thanks very much for your help
Patrick
It might simplify things if you set your MQTT-In node to output a parsed JSON object rather than the default autodetect. Possibly you can dispense with the JSON Parser.
Yes that got rid of the JSON node. I think I had that set like that initially before my learning curve grief with msg.
