Creating dashboard with multi language support + camera?
An example of many possibilities how to achieve multi language dashboard. Quite of work to make one, specially if there's a lot of text content. But doable.
Side note - I haven't tried all the widgets so there's no guarantee that all bits and pieces allow such approach.
[{"id":"8c0c4f5b39418508","type":"ui-text","z":"a5b9f027282f32b3","group":"5898950bd97524e2","order":3,"width":0,"height":0,"name":"","label":"text","format":"{{msg.payload}}","layout":"row-spread","style":false,"font":"","fontSize":16,"color":"#717171","wrapText":false,"className":"","x":930,"y":280,"wires":[]},{"id":"d8659836df555d35","type":"change","z":"a5b9f027282f32b3","name":"","rules":[{"t":"set","p":"keys","pt":"msg","to":"[\"textLabel\",\"yes\",\"no\"]","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":370,"y":280,"wires":[["1151a5c80adc8fa3"]]},{"id":"1151a5c80adc8fa3","type":"link call","z":"a5b9f027282f32b3","name":"","links":["dc8465da62984149"],"linkType":"static","timeout":"30","x":560,"y":280,"wires":[["9e50d3e22f164ab6"]]},{"id":"dc8465da62984149","type":"link in","z":"a5b9f027282f32b3","name":"get-translations","links":[],"x":545,"y":120,"wires":[["a94f6a63f923c765"]]},{"id":"a94f6a63f923c765","type":"function","z":"a5b9f027282f32b3","name":"translate","func":"const language = global.get(\"language\") ?? \"en\"\nconst translations = global.get(\"translations\")[language]\nconst translated = {}\nmsg.keys.forEach(function(k) {\n    translated[k] = translations[k]    \n});\nmsg.translations = translated\ndelete msg.keys\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"const translations = {\n    \n}\n\ncontext.set(\"translations\", translations)","finalize":"","libs":[],"x":660,"y":120,"wires":[["4316811f512657d7"]]},{"id":"3f4e6cf917ae0e71","type":"function","z":"a5b9f027282f32b3","name":"translations","func":"const translations = {\n    \"en\":{\n        \"textLabel\":\"Text Node Label\",\n        \"yes\":\"Yes\",\n        \"no\":\"No\",\n        \"greenSliderLabel\":\"Green Slider\",\n        \"blueSliderLabel\":\"Blue Slider\"\n    },\n    \"et\":{\n        \"textLabel\": \"Teksti Sõlme Pealkiri\",\n        \"yes\": \"Jaa\",\n        \"no\": \"Ei\",\n        \"greenSliderLabel\": \"Roheline Liugur\",\n        \"blueSliderLabel\": \"Sinine Slider\"\n    }\n}\nglobal.set(\"translations\", translations);\n","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":330,"y":100,"wires":[[]]},{"id":"71681f6488cfb9e7","type":"inject","z":"a5b9f027282f32b3","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":170,"y":100,"wires":[["3f4e6cf917ae0e71"]]},{"id":"62e0784c7e911870","type":"inject","z":"a5b9f027282f32b3","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"true","payloadType":"bool","x":170,"y":260,"wires":[["d8659836df555d35"]]},{"id":"02990584ec5c0a7b","type":"change","z":"a5b9f027282f32b3","name":"","rules":[{"t":"set","p":"language","pt":"global","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":410,"y":200,"wires":[["3d0f6abf36a48fc7"]]},{"id":"4316811f512657d7","type":"link out","z":"a5b9f027282f32b3","name":"translated","mode":"return","links":[],"x":775,"y":120,"wires":[]},{"id":"daee52e7a2557988","type":"inject","z":"a5b9f027282f32b3","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"false","payloadType":"bool","x":170,"y":300,"wires":[["d8659836df555d35"]]},{"id":"9e50d3e22f164ab6","type":"function","z":"a5b9f027282f32b3","name":"convert","func":"msg.ui_update = {\n    \"label\": msg.translations.textLabel\n}\nmsg.payload = msg.payload == true ? msg.translations.yes : msg.translations.no\ndelete msg.translations\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":740,"y":280,"wires":[["8c0c4f5b39418508"]]},{"id":"40854ba824351cbb","type":"ui-slider","z":"a5b9f027282f32b3","group":"5898950bd97524e2","name":"green slider","label":"slider","tooltip":"","order":1,"width":0,"height":0,"passthru":false,"outs":"all","topic":"topic","topicType":"msg","thumbLabel":"true","showTicks":"false","min":0,"max":10,"step":1,"className":"","iconPrepend":"","iconAppend":"","color":"green","colorTrack":"green","colorThumb":"green","x":950,"y":360,"wires":[[]]},{"id":"daeec4da4f1930e9","type":"ui-event","z":"a5b9f027282f32b3","ui":"29792df7d7b05e2e","name":"","x":170,"y":160,"wires":[["1888ef3d01b34367"]]},{"id":"bb62ae8041230ee9","type":"change","z":"a5b9f027282f32b3","name":"","rules":[{"t":"set","p":"keys","pt":"msg","to":"[\"greenSliderLabel\"]","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":370,"y":360,"wires":[["11da38722b867783"]]},{"id":"11da38722b867783","type":"link call","z":"a5b9f027282f32b3","name":"","links":["dc8465da62984149"],"linkType":"static","timeout":"30","x":560,"y":360,"wires":[["bb0ef359076e0ea2"]]},{"id":"bb0ef359076e0ea2","type":"function","z":"a5b9f027282f32b3","name":"convert","func":"msg.ui_update = {\n    \"label\": msg.translations.greenSliderLabel\n}\n\ndelete msg.translations\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":740,"y":360,"wires":[["40854ba824351cbb"]]},{"id":"77d59665c189e445","type":"ui-slider","z":"a5b9f027282f32b3","group":"5898950bd97524e2","name":"blue slider","label":"slider","tooltip":"","order":2,"width":0,"height":0,"passthru":false,"outs":"all","topic":"topic","topicType":"msg","thumbLabel":"true","showTicks":"false","min":0,"max":10,"step":1,"className":"","iconPrepend":"","iconAppend":"","color":"blue","colorTrack":"blue","colorThumb":"blue","x":950,"y":400,"wires":[[]]},{"id":"f45bb5538c399362","type":"change","z":"a5b9f027282f32b3","name":"","rules":[{"t":"set","p":"keys","pt":"msg","to":"[\"blueSliderLabel\"]","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":370,"y":400,"wires":[["7652d9901d06d699"]]},{"id":"7652d9901d06d699","type":"link call","z":"a5b9f027282f32b3","name":"","links":["dc8465da62984149"],"linkType":"static","timeout":"30","x":560,"y":400,"wires":[["a6701e6de8707288"]]},{"id":"a6701e6de8707288","type":"function","z":"a5b9f027282f32b3","name":"convert","func":"msg.ui_update = {\n    \"label\": msg.translations.blueSliderLabel\n}\n\ndelete msg.translations\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":740,"y":400,"wires":[["77d59665c189e445"]]},{"id":"633a3757ebfa2784","type":"ui-template","z":"a5b9f027282f32b3","group":"","page":"","ui":"29792df7d7b05e2e","name":"language selector","order":0,"width":0,"height":0,"head":"","format":"<template>\n    <Teleport v-if=\"mounted\" to=\"#app-bar-actions\">\n        <v-btn-toggle v-model=\"lang\" color=\"deep-purple-accent-3\" rounded=\"0\" group>\n           <v-btn value=\"en\" @click=\"sendSelected()\">\n                EN\n            </v-btn>\n        \n            <v-btn value=\"et\" @click=\"sendSelected()\">\n                ET\n            </v-btn>\n        </v-btn-toggle>\n    </Teleport>\n</template>\n\n<script>\n    export default {\n        data() {         \n            return {\n                lang:\"en\",\n                mounted:false\n            }\n        },\n        watch: {\n            msg:function(){\n                if(this.msg?.payload){                       \n                    this.lang = this.msg.payload\n                }\n            }\n        },\n        computed: {\n           \n           \n        },\n        methods: {\n            sendSelected:function(){\n                this.send({payload:this.lang})\n            }\n        },\n        mounted() {\n           this.mounted=true\n           \n        },\n        unmounted() {\n           this.mounted=false\n        }\n    }\n</script>\n<style>\n  \n</style>","storeOutMessages":true,"passthru":true,"resendOnRefresh":true,"templateScope":"widget:ui","className":"","x":190,"y":200,"wires":[["02990584ec5c0a7b"]]},{"id":"6292bfe897385f0a","type":"link in","z":"a5b9f027282f32b3","name":"dashboard-update","links":["3d0f6abf36a48fc7","1888ef3d01b34367"],"x":195,"y":400,"wires":[["d8659836df555d35","bb62ae8041230ee9","f45bb5538c399362"]]},{"id":"3d0f6abf36a48fc7","type":"link out","z":"a5b9f027282f32b3","name":"language-selected","mode":"link","links":["6292bfe897385f0a"],"x":535,"y":200,"wires":[]},{"id":"1888ef3d01b34367","type":"link out","z":"a5b9f027282f32b3","name":"dashboard-events","mode":"link","links":["6292bfe897385f0a"],"x":255,"y":160,"wires":[]},{"id":"5898950bd97524e2","type":"ui-group","name":"Group","page":"38cec68f083871ad","width":"6","height":"1","order":1,"showTitle":true,"className":"","visible":"true","disabled":"false","groupType":"default"},{"id":"29792df7d7b05e2e","type":"ui-base","name":"My Dashboard","path":"/dashboard","appIcon":"","includeClientData":false,"acceptsClientConfig":[],"showPathInSidebar":false,"showPageTitle":true,"navigationStyle":"default","titleBarStyle":"default"},{"id":"38cec68f083871ad","type":"ui-page","name":"Multi Language","ui":"29792df7d7b05e2e","path":"/page6","icon":"home","layout":"grid","theme":"813ec6b2ff1699c4","breakpoints":[{"name":"Default","px":"0","cols":"3"},{"name":"Tablet","px":"576","cols":"6"},{"name":"Small Desktop","px":"768","cols":"9"},{"name":"Desktop","px":"1024","cols":"12"}],"order":1,"className":"","visible":"true","disabled":"false"},{"id":"813ec6b2ff1699c4","type":"ui-theme","name":"Default Theme","colors":{"surface":"#ffffff","primary":"#0094ce","bgPage":"#eeeeee","groupBg":"#ffffff","groupOutline":"#cccccc"},"sizes":{"density":"default","pagePadding":"12px","groupGap":"12px","groupBorderRadius":"4px","widgetGap":"12px"}}]
