Hi, I need your help today because i have to commit my node red flow on gitlab.
But i don't understand how i can do it.
If someone could help me.
Thanks you.
Do you know how to commit code to GitLab?
Kind of. I've learned a lot about all this. Simply all the other projects I see contain .c .cpp .js files, with code compliant extensions. What I can't get with NR
I really need help please if someone can just give me some advices
Are you using the Projects feature in Node-RED? https://nodered.org/docs/user-guide/projects/
This video gives an introduction - https://www.youtube.com/watch?v=Bto2rz7bY3g
The process for Node-RED is the same for any other project.
The difference is that if you are not using NR's projects feature, you need to understand what files and folders you need to exclude.
