Crop image node-red-contrib-image-tools
Hi all,
I am setting up a flow to take a photo and then crop to a certain size at a set point but I am not getting any output using the jimp-image node's crop function. I have used other flavours of function for this node without any problem.
Any help gratefully received.
Look at your screen shots - you have msg selected for the parameters x, y, w, h but are trying to set values. msg is for passing the parameters into node dynamically. Change msg to number.
Thanks, the answer was staring me in the face but I just couldn't see it
