hi everyone, sorry is there anyone who knows how to change the color of sidenav dashboards texts
What are sidenav dashboards texts?
Edit: only 3 words and yet I transcribed one of them wrong. ![]()
Add a style that targets them in a ui-template set for "head" mode.
how can i do that
Do what?
- Add a ui-template set for head mode?
- Add a style that targets the text?
- Set CSS that changes text colour?
i managed to change background color of side menu by using this css code below
body.nr-dashboard-theme md-sidenav {
color: rgb(255, 255, 255);
but am not able to change texts color of side menu
then you likely need a more specific specifier.
body.nr-dashboard-theme md-sidenav ul > li > span {
NOTE: I made that specifier ^ up - I dont use dashboard so cant tell you what a more specific specifier might be
If all else fails, hack it with an !important directive
color: rgb(255, 255, 255) !important;
what does that codes do?
Sorry, what is your question?
You do know what CSS is right?
What are you asking - about which part?
- specificity ?
- the
>? - the
!important? - all of it ?
I needto change the color of each side menu dashboards texts
Then write CSS with a more specific CSS selector that targets the text items.
Use the browsers devtools to find & determine what the selector looks like.
Then add a CSS class that set the color
i gave you an example already BUT since i dont use dashboard I CANNOT tell you what the more specific selector would be - you will need to determine that using the browsers devtools.
example: web scraping - How can I get the CSS Selector in Chrome? - Stack Overflow
I don't believe that CSS changes the background color of the dashboard side menu.
However, referring you back to an answer I gave when you were trying to change the background color (which, like my question above, you didn't bother to respond to)
I think the relevant bit of the template theme now is Group Text.
A quick search of the forum reveals many solutions.
Here are 2:
