CSS in dashboard 2.0
Hi, I'm trying to customize some CSS attributes in Dashboard 2.0, but some changes aren't taking effect. Here's an example:
When the opacity change is applied correctly, but the background color modification only affects the background of the entire group, not individual elements within it:
Ps: I tested the 2 attributes separately.
The class on the widgets gets applied to the parent of the widget.
It is up to you to target elements within the widget accordingly.
What is this "Vaga 1" - a template? a ui-text? something else?
How are you adding the CSS - in a separate template? in a template with a div containing "Vaga 1"
Details are important.
PS in future, please paste code as text (saves whoever is helping out from retyping what you already wrote!)
Sorry, I forgot to include the code earlier. Here it is:
        "id": "0a0eceda8b27bc87",
        "type": "tab",
        "label": "Duvidas de Forum",
        "disabled": false,
        "info": "",
        "env": []
        "id": "1e0c41d5ba45d92c",
        "type": "ui-template",
        "z": "0a0eceda8b27bc87",
        "group": "cb0da117407ae8ae",
        "page": "",
        "ui": "",
        "order": 1,
        "width": 0,
        "height": 0,
        "head": "",
        "format": "<style>\n    /* define any styles here - supports raw CSS */\n    .carro {\n        background-color: red;\n    }\n</style>",
        "storeOutMessages": true,
        "passthru": true,
        "resendOnRefresh": true,
        "templateScope": "local",
        "className": "",
        "x": 140,
        "y": 60,
        "id": "cb0da117407ae8ae",
        "type": "ui-group",
        "name": "Vaga 1",
        "page": "562207807c69e32e",
        "width": "6",
        "height": "1",
        "order": 1,
        "showTitle": true,
        "className": "carro",
        "visible": "true",
        "disabled": "false",
        "groupType": "default"
        "id": "562207807c69e32e",
        "type": "ui-page",
        "name": "Estacionamento",
        "ui": "3691f8773d02ba1a",
        "path": "/page1",
        "icon": "home",
        "layout": "grid",
        "theme": "a86bbef1ce30531e",
        "breakpoints": [
                "name": "Default",
                "px": "0",
                "cols": "3"
                "name": "Tablet",
                "px": "576",
                "cols": "6"
                "name": "Small Desktop",
                "px": "768",
                "cols": "9"
                "name": "Desktop",
                "px": "1024",
                "cols": "12"
        "order": 1,
        "className": "",
        "visible": "true",
        "disabled": "false"
        "id": "3691f8773d02ba1a",
        "type": "ui-base",
        "name": "Playground",
        "path": "/dashboard",
        "includeClientData": true,
        "acceptsClientConfig": [
            "ui-notification",
            "ui-control"
        "showPathInSidebar": false,
        "navigationStyle": "default"
        "id": "a86bbef1ce30531e",
        "type": "ui-theme",
        "name": "Theme Name",
        "colors": {
            "surface": "#ffffff",
            "primary": "#0094ce",
            "bgPage": "#eeeeee",
            "groupBg": "#ffffff",
            "groupOutline": "#cccccc"
        "sizes": {
            "density": "default",
            "pagePadding": "12px",
            "groupGap": "12px",
            "groupBorderRadius": "4px",
            "widgetGap": "12px"
You have only exported a single ui-template with the <style> inside. Where is the thing that shows "Vaga 1"?
There was nothing in "VAGA 1", now I added a text input to make it easier to understand.
Here is the new code:
        "type": "tab",
        "disabled": false,
        "info": "",
        "env": []
        "page": "",
        "ui": "",
        "order": 2,
        "width": 0,
        "height": 0,
        "head": "",
        "passthru": true,
        "className": "",
        "x": 140,
        "y": 60,
        "id": "36afbc8e9f09b9e9",
        "type": "ui-text-input",
        "label": "Test",
        "order": 1,
        "width": 0,
        "height": 0,
        "topic": "topic",
        "topicType": "msg",
        "mode": "text",
        "tooltip": "",
        "delay": 300,
        "passthru": true,
        "sendOnDelay": false,
        "sendOnBlur": true,
        "sendOnEnter": true,
        "className": "",
        "clearable": false,
        "sendOnClear": false,
        "icon": "",
        "iconPosition": "left",
        "iconInnerPosition": "inside",
        "x": 130,
        "y": 120,
        "type": "ui-group",
        "name": "Vaga 1",
        "width": "6",
        "height": "1",
        "order": 1,
        "showTitle": true,
        "visible": "true",
        "type": "ui-page",
        "path": "/page1",
        "icon": "home",
        "layout": "grid",
        "breakpoints": [
                "name": "Default",
                "px": "0",
                "cols": "3"
                "name": "Tablet",
                "px": "576",
                "cols": "6"
                "px": "768",
                "cols": "9"
                "name": "Desktop",
                "px": "1024",
                "cols": "12"
        "order": 1,
        "className": "",
        "visible": "true",
        "disabled": "false"
        "type": "ui-base",
            "ui-notification",
            "ui-control"
        "type": "ui-theme",
        "colors": {
        "sizes": {
            "groupGap": "12px",
            "widgetGap": "12px"
1st, you should set the template node to CSS (site or page)
chrome_Ek2qxy4Xsw
Then, apply your class to the widget
Result
