Searching through forum trying to learn CSS sheets. Found an example from @Steve-Mcl that was excellent and I think I learned quite a bit but.....
I can get the styles to carry over across multiple tabs but I cannot get the button pushes to work across the tabs.
[{"id":"2cd4854b.62f9c2","type":"tab","label":"Relays","disabled":false,"info":""},{"id":"6f5fd6af.84e7b","type":"rpi-gpio out","z":"2cd4854b.62f9c2","name":"2","pin":"21","set":true,"level":"1","freq":"","out":"out","x":870,"y":400,"wires":[]},{"id":"9e68b6b1.05229","type":"rpi-gpio out","z":"2cd4854b.62f9c2","name":"3","pin":"23","set":true,"level":"1","freq":"","out":"out","x":870,"y":460,"wires":[]},{"id":"d9922a41.8cf6e","type":"rpi-gpio out","z":"2cd4854b.62f9c2","name":"4","pin":"29","set":true,"level":"1","freq":"","out":"out","x":870,"y":520,"wires":[]},{"id":"79862602.87e538","type":"rpi-gpio out","z":"2cd4854b.62f9c2","name":"5","pin":"31","set":true,"level":"1","freq":"","out":"out","x":870,"y":580,"wires":[]},{"id":"b233f2b5.51d888","type":"rpi-gpio out","z":"2cd4854b.62f9c2","name":"6","pin":"33","set":true,"level":"1","freq":"","out":"out","x":870,"y":640,"wires":[]},{"id":"3aa5842b.3a2a74","type":"rpi-gpio out","z":"2cd4854b.62f9c2","name":"7","pin":"35","set":true,"level":"1","freq":"","out":"out","x":870,"y":700,"wires":[]},{"id":"2f65c7ea.37787","type":"rpi-gpio out","z":"2cd4854b.62f9c2","name":"1","pin":"19","set":true,"level":"1","freq":"","out":"out","x":870,"y":340,"wires":[]},{"id":"8009c551.b16728","type":"rpi-gpio out","z":"2cd4854b.62f9c2","name":"8","pin":"37","set":true,"level":"1","freq":"","out":"out","x":870,"y":760,"wires":[]},{"id":"90ac3607.3e9478","type":"function","z":"2cd4854b.62f9c2","name":"toggle relays","func":"let z = msg.payload;\n\nswitch (z) {\n case 1:\n msg1 = {payload: 0};\n msg2 = {payload: 1};\n msg3 = {payload: 1};\n msg4 = {payload: 1};\n msg5 = {payload: 1};\n msg6 = {payload: 1};\n msg7 = {payload: 1};\n msg8 = {payload: 1};\n break;\n case 2:\n msg1 = {payload: 1};\n msg2 = {payload: 0};\n msg3 = {payload: 1};\n msg4 = {payload: 1};\n msg5 = {payload: 1};\n msg6 = {payload: 1};\n msg7 = {payload: 1};\n msg8 = {payload: 1};\n break;\n case 3:\n msg1 = {payload: 1};\n msg2 = {payload: 1};\n msg3 = {payload: 0};\n msg4 = {payload: 1};\n msg5 = {payload: 1};\n msg6 = {payload: 1};\n msg7 = {payload: 1};\n msg8 = {payload: 1};\n break;\n case 4:\n msg1 = {payload: 1};\n msg2 = {payload: 1};\n msg3 = {payload: 1};\n msg4 = {payload: 0};\n msg5 = {payload: 1};\n msg6 = {payload: 1};\n msg7 = {payload: 1};\n msg8 = {payload: 1};\n break;\n case 5:\n msg1 = {payload: 1};\n msg2 = {payload: 1};\n msg3 = {payload: 1};\n msg4 = {payload: 1};\n msg5 = {payload: 0};\n msg6 = {payload: 1};\n msg7 = {payload: 1};\n msg8 = {payload: 1};\n break;\n case 6:\n msg1 = {payload: 1};\n msg2 = {payload: 1};\n msg3 = {payload: 1};\n msg4 = {payload: 1};\n msg5 = {payload: 1};\n msg6 = {payload: 0};\n msg7 = {payload: 1};\n msg8 = {payload: 1};\n break;\n case 7:\n msg1 = {payload: 1};\n msg2 = {payload: 1};\n msg3 = {payload: 1};\n msg4 = {payload: 1};\n msg5 = {payload: 1};\n msg6 = {payload: 1};\n msg7 = {payload: 0};\n msg8 = {payload: 1};\n break;\n case 8:\n msg1 = {payload: 1};\n msg2 = {payload: 1};\n msg3 = {payload: 1};\n msg4 = {payload: 1};\n msg5 = {payload: 1};\n msg6 = {payload: 1};\n msg7 = {payload: 1};\n msg8 = {payload: 0};\n}\n\nreturn [msg1,msg2,msg3,msg4,msg5,msg6,msg7,msg8];","outputs":8,"noerr":0,"x":550,"y":240,"wires":[["2f65c7ea.37787"],["6f5fd6af.84e7b"],["9e68b6b1.05229"],["d9922a41.8cf6e"],["79862602.87e538"],["b233f2b5.51d888"],["3aa5842b.3a2a74"],["8009c551.b16728"]]},{"id":"41578335.0e55bc","type":"function","z":"2cd4854b.62f9c2","name":"count up / dn","func":"var dir = context.get(\"dir\") || 0;\nvar count = context.get(\"counter\") || 0;\nif(dir === 0){\n count = (count+1);\n context.set(\"counter\", count);\n if(count > 7){\n context.set(\"dir\", 1);\n dir = 1;\n } \n msg.payload = count;\n node.status({fill:\"blue\",shape:\"dot\",text: msg.payload});\n return msg;\n}\nif(dir === 1){\n count = (count-1);\n context.set(\"counter\", count);\n if(count === 1){\n context.set(\"dir\", 0);\n dir = 0;\n } \n msg.payload = count;\n node.status({fill:\"blue\",shape:\"dot\",text: msg.payload});\n return msg;\n}","outputs":1,"noerr":0,"x":350,"y":240,"wires":[[]]},{"id":"1b5d777a.1d06c9","type":"inject","z":"2cd4854b.62f9c2","name":"2 seconds","topic":"","payload":"1","payloadType":"num","repeat":"2","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":240,"wires":[["41578335.0e55bc"]]},{"id":"b4d8996b.39ef3","type":"function","z":"2cd4854b.62f9c2","name":"Relay logic","func":"\nvar i;\n\nMyMsg = new Array(8);\n\nfor (i = 1; i < 9; i++) {\n if (msg.topic == i){\n MyMsg[i] = {\n payload: msg.payload, \n }\n } \n}\n\nreturn [MyMsg[1],MyMsg[2],MyMsg[3],MyMsg[4],MyMsg[5],MyMsg[6],MyMsg[7],MyMsg[8]];","outputs":8,"noerr":0,"x":550,"y":520,"wires":[["2f65c7ea.37787"],["6f5fd6af.84e7b"],["9e68b6b1.05229"],["d9922a41.8cf6e"],["79862602.87e538"],["b233f2b5.51d888"],["3aa5842b.3a2a74"],["8009c551.b16728"]]},{"id":"f97943e4.0012c8","type":"comment","z":"2cd4854b.62f9c2","name":"","info":"<style>\n \n .myButtonAB {\n\tbox-shadow: ;\n\tbackground:linear-gradient(to bottom, #ededed 5%, #bab1ba 100%);\n\tbackground-color:#ededed;\n\tborder-radius:15px;\n\tborder:4px solid #006400; \n\tdisplay:inline-block;\n\tcursor:pointer;\n\tcolor:#000000;\n\tfont-family:Arial;\n\tfont-size:17px;\n\tpadding:7px 25px;\n\ttext-decoration:none;\n\ttext-shadow:0px 1px 0px #e1e2ed;\n}\n.myButtonAB:hover {\n\tbackground:linear-gradient(to bottom, #bab1ba 5%, #ededed 100%);\n\tbackground-color:#bab1ba;\n}\n.myButtonAB:active {\n\tposition:relative;\n\ttop:1px;\n}\n \n</style>\n\n<button class= \"myButtonAB\" ng-click=\"send({topic:'on', payload:1})\">{{msg.label}}</button>\n","x":260,"y":140,"wires":[]},{"id":"11e1db24.df9d4d","type":"ui_template","z":"2cd4854b.62f9c2","group":"3c514747.a2de9","name":"CSS only ","order":2,"width":0,"height":0,"format":"<style id=\"remote-buttons\">\n :root {\n --dashboard-unit-width: 48px;\n --dashboard-unit-height: 40px;\n --remote-button-background: green;\n --remote-button-foreground: white;\n }\n .nr-dashboard-template {\n padding: 0px;\n }\n \n .remote-button.disabled{\n cursor: not-allowed;\n pointer-events: none;\n color: #aaaaaa !important;\n }\n \n .remote-button:not([disabled]):hover{\n background-color: darkcyan !important;\n }\n\n /* This is the normal button definition */\n .remote-button{\n background-color: var(--remote-button-background) !important;\n color: var(--remote-button-foreground) !important;\n height: var(--dashboard-unit-height);\n width: 100%;\n border-radius: 8px;\n font-size:8px;\n font-weight:normal;\n margin: 0;\n min-height: 36px;\n min-width: unset;\n line-height: unset;\n \n box-shadow: 0px 6px 4px 0px #1c1b18;\n\t background:#eae0c2;\n\t /*border:6px solid #333029;*/\n\t display:inline-block;\n\t cursor:pointer;\n\t font-family:Arial;\n\t padding:4px 6px;\n\t text-decoration:none;\n }\n /* This is a sub-set which is invoked by */\n /* <md-button class=\"md-button remote-button bigger\"> */\n /* note the (space) \"bigger\" at the end. */\n .remote-button.bigger{\n font-weight:bold;\n font-size:1.5em;\n }\n /* This is for buttons with a lot of text. `font-size:0.7em` */\n /* makes the font 70% normal size */\n .remote-button.small{\n font-size:0.7em;\n }\n /* This is for buttons with just icons, to upsize the size */\n /* of the icon with the line: */\n /* <i class=\"fa fa-fw fa-plus remote-icon\"> in the other node */\n .remote-icon{\n font-size:2.0em;\n }\n /* This is the same as the other one, but it makes the icon smaller */\n .remote-iconS{\n font-size:0.5em;\n }\n\n .remote-button.black{\n background-color: var(--remote-button-background) !important;\n color: var(--remote-button-foreground) !important;\n }\n\n .remote-button.red{\n background-color: red !important;\n color: var(--remote-button-foreground) !important;\n }\n .remote-button.red:not([disabled]):hover{\n background-color: orange !important;\n }\n\n .remote-button.blinking{\n \tanimation:blinkingAnim1 0.8s infinite;\n }\n @keyframes blinkingAnim1{\n \t0%{\t\tbackground-color: var(--remote-button-background); color:var(--remote-button-foreground);}\n \t50%{\tbackground-color: var(--remote-button-foreground); color:var(--remote-button-background);}\n \t100%{\tbackground-color: var(--remote-button-background);\tcolor:var(--remote-button-foreground);}\n } \n \n .remote-button.red.blinking{\n \tanimation:blinkingAnim2 0.8s infinite;\n }\n @keyframes blinkingAnim2{\n \t0%{\t\tbackground-color: red; color:#cccccc;}\n \t50%{\tbackground-color: #cccccc; color:red;}\n \t100%{\tbackground-color: red;\tcolor:#cccccc;}\n } \n</style>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"global","x":120,"y":340,"wires":[[]]},{"id":"137e719a.c254d6","type":"ui_template","z":"2cd4854b.62f9c2","group":"3c514747.a2de9","name":"1","order":6,"width":0,"height":0,"format":"<div>\n <md-button class=\"md-button remote-button\" \n data-payload=\"1\" \n data-buttontype=\"toggle\"\n data-topic=\"1\"\n data-icon0=\"Relay 1 On\"\n data-icon1=\"Relay 1 Off\"\n aria-label=\"Relay 1\"\n >\n <i class=\"material-icons md-48\">Relay 1</i>\n </md-button>\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":110,"y":380,"wires":[[]]},{"id":"a9130e77.78a168","type":"ui_template","z":"2cd4854b.62f9c2","group":"3c514747.a2de9","name":"2","order":7,"width":0,"height":0,"format":"<div>\n <md-button class=\"md-button remote-button\" \n data-payload=\"1\" \n data-buttontype=\"toggle\"\n data-topic=\"2\"\n data-icon0=\"Relay 2 On\"\n data-icon1=\"Relay 2 Off\"\n aria-label=\"Relay 2\"\n >\n <i class=\"material-icons md-48\">Relay 2</i>\n </md-button>\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":110,"y":420,"wires":[[]]},{"id":"892e0683.d36dc8","type":"ui_template","z":"2cd4854b.62f9c2","group":"3c514747.a2de9","name":"3","order":8,"width":0,"height":0,"format":"<div>\n <md-button class=\"md-button remote-button\" \n data-payload=\"1\" \n data-buttontype=\"toggle\"\n data-topic=\"3\"\n data-icon0=\"Relay 3 On\"\n data-icon1=\"Relay 3 Off\"\n aria-label=\"Relay 3\"\n >\n <i class=\"material-icons md-48\">Relay 3</i>\n </md-button>\n</div>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":110,"y":460,"wires":[[]]},{"id":"b7defb7b.d33c","type":"ui_template","z":"2cd4854b.62f9c2","group":"3c514747.a2de9","name":"4","order":9,"width":0,"height":0,"format":"<div>\n <md-button class=\"md-button remote-button\" \n data-payload=\"1\" \n data-buttontype=\"toggle\"\n data-topic=\"4\"\n data-icon0=\"Relay 4 On\"\n data-icon1=\"Relay 4 Off\"\n aria-label=\"Relay 4\"\n >\n <i class=\"material-icons md-48\">Relay 4</i>\n </md-button>\n</div>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":110,"y":500,"wires":[[]]},{"id":"f18c8cfd.f8eb48","type":"ui_template","z":"2cd4854b.62f9c2","group":"3c514747.a2de9","name":"5","order":10,"width":0,"height":0,"format":"<div>\n <md-button class=\"md-button remote-button\" \n data-payload=\"1\" \n data-buttontype=\"toggle\"\n data-topic=\"5\"\n data-icon0=\"Relay 5 On\"\n data-icon1=\"Relay 5 Off\"\n aria-label=\"Relay 5\"\n >\n <i class=\"material-icons md-48\">Relay 5</i>\n </md-button>\n</div>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":110,"y":540,"wires":[[]]},{"id":"fd28abf2.27d4e","type":"ui_template","z":"2cd4854b.62f9c2","group":"3c514747.a2de9","name":"6","order":11,"width":0,"height":0,"format":"<div>\n <md-button class=\"md-button remote-button\" \n data-payload=\"1\" \n data-buttontype=\"toggle\"\n data-topic=\"6\"\n data-icon0=\"Relay 6 On\"\n data-icon1=\"Relay 6 Off\"\n aria-label=\"Relay 6\"\n >\n <i class=\"material-icons md-48\">Relay 6</i>\n </md-button>\n</div>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":110,"y":580,"wires":[[]]},{"id":"88b8477e.10dd2","type":"ui_template","z":"2cd4854b.62f9c2","group":"3c514747.a2de9","name":"7","order":12,"width":0,"height":0,"format":"<div>\n <md-button class=\"md-button remote-button\" \n data-payload=\"1\" \n data-buttontype=\"toggle\"\n data-topic=\"7\"\n data-icon0=\"Relay 7 On\"\n data-icon1=\"Relay 7 Off\"\n aria-label=\"Relay 7\"\n >\n <i class=\"material-icons md-48\">Relay 7</i>\n </md-button>\n</div>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":110,"y":620,"wires":[[]]},{"id":"870db3b8.a774a8","type":"ui_template","z":"2cd4854b.62f9c2","group":"3c514747.a2de9","name":"8","order":13,"width":0,"height":0,"format":"<div>\n <md-button class=\"md-button remote-button\" \n data-payload=\"1\" \n data-buttontype=\"toggle\"\n data-topic=\"8\"\n data-icon0=\"Relay 8 On\"\n data-icon1=\"Relay 8 Off\"\n aria-label=\"Relay 8\"\n >\n <i class=\"material-icons md-48\">Relay 8</i>\n </md-button>\n</div>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":110,"y":660,"wires":[[]]},{"id":"ab2c8f92.e36a9","type":"ui_template","z":"2cd4854b.62f9c2","group":"3c514747.a2de9","name":"button script","order":1,"width":0,"height":0,"format":"<div>\n<!--diliberately emtpy - only need the script below -->\n</div>\n\n<script>\n\n(function($scope) {\n//debugger\n\n //cause a small delay while things load \n //ideally this would be an init event or on all parts of document loaded\n //(may not be necessary!)\n setTimeout(function() {\n //debugger\n $scope.init();\n },100);\n \n var BUTTON_CLASS = \".remote-button\";\n\n /** \n * Initialise all buttons with class BUTTON_CLASS\n */\n $scope.init = function () {\n //debugger\n console.log(\"$scope.init called. Adding event handlers to all buttons with class '\" + BUTTON_CLASS + \"'.\");\n var clickButtons = $(BUTTON_CLASS + \":not([data-buttontype='repeater'])\") \n clickButtons.click(function(e){\n //debugger\n var btn = $(this)\n var type = btn.data(\"buttontype\");//get the button type from attribute data-buttontype=\"xxxxx\"\n var topic = btn.data(\"topic\");//get the topic from attribute data-topic=\"xxxxx\"\n var payload = btn.data(\"payload\");//get the payload from attribute data-payload=\"xxxxx\"\n \n if(type == \"toggle\"){\n var newPayload = payload == 1 ? 0 : 1;\n setButtonState(btn,newPayload)\n $scope.send({\"topic\":topic,\"payload\":newPayload, \"event\": \"click\"})\n } else {\n $scope.send({\"topic\":topic,\"payload\":payload})\n }\n }); \n \n\n var repeatButtons = $(BUTTON_CLASS + \"[data-buttontype='repeater']\") \n repeatButtons.on('mousedown touchstart',function(e) {\n e.preventDefault();\n e.stopPropagation();\n console.log(e.type);//remove me after debugging\n var btn = this;\n var $btn = $(btn);\n if(btn._intervalId) return; //already in operation\n btn._topic = $btn.data(\"topic\");//get the topic from attribute data-topic=\"xxxxx\"\n btn._payload = $btn.data(\"payload\");//get the payload from attribute data-payload=\"xxxxx\"\n btn._interval = $btn.data(\"interval\");//get the desired repeat duration\n if(isNumeric(btn._interval) == false || btn._interval < 1) btn._interval = 300;//prevent zero & non numeric timeout value\n var max = $btn.data(\"max\");//get the max repeat count\n if(isNumeric(max) && max > 0) \n btn._max = parseInt(max);\n else\n btn._max = undefined;\n btn._count = 1;\n $scope.send({\"topic\":btn._topic,\"payload\":btn.payload,\"event\":\"down\", \"count\": btn._count})\n btn._lastevent = \"down\";\n //remove any existing timer\n if(btn._intervalId){\n clearInterval(btn._intervalId);\n btn._intervalId = null;\n }\n //start the timer if conditions are ok\n if(!btn._max || (btn._max && btn._count < btn._max)){\n btn._intervalId = setInterval(function() {\n if(btn._max && btn._count >= btn._max){\n clearInterval(btn._intervalId);\n btn._intervalId = null;\n return;\n } \n btn._count = btn._count + 1;\n $scope.send({\"topic\":btn._topic,\"payload\":btn.payload,\"event\":\"down\", \"count\": btn._count})\n },btn._interval); \n }\n }).on('mouseup blur focusout mouseout touchend',function(e) {\n e.preventDefault();\n e.stopPropagation();\n console.log(e.type);//remove me after debugging\n var btn = this;\n var $btn = $(btn);\n \n //next, if data-fireonup == true, then fire up event\n var sendUpEvent = $btn.data(\"fireonup\") == true;\n if(sendUpEvent && btn._lastevent === \"down\"){\n btn._lastevent = \"up\"\n $scope.send({\"topic\":btn._topic,\"payload\":btn._payload,\"event\":\"up\"})\n }\n \n //finally, if the timer id is still valid, clear it (stop repeater)\n if(btn._intervalId){\n clearInterval(btn._intervalId);//stop timer\n btn._intervalId = null;//clear timer id\n }\n });\n \n };\n \n //watch for node-red msgs\n $scope.$watch('msg', function(msg) {\n //debugger\n if(!msg){ //if no msg \n console.log(\"$scope.$watch('msg', ...) - msg is empty\");\n return;\n }\n if(!msg.topic){ //if no topic set found\n console.log(\"msg.topic is empty - cannot match this to any button\")\n return; //stop processing!\n }\n\n var buttonSelector = BUTTON_CLASS + \"[data-topic='\" + msg.topic + \"']\" \n var $btn = $(buttonSelector);//get the button\n \n if(!$btn.length){ //if no button found\n console.log(buttonSelector + \" not found - cannot set state\")\n return; //stop processing!\n }\n \n if($btn.length > 1){ //if MORE than one button found\n console.log(buttonSelector + \" found more than 1 button - is this intended? Do you have the same data-topic set on multiple buttons?\")\n }\n \n //see if this is a command - if so, process the command\n if(typeof msg.payload === \"object\" && msg.payload.command){\n processCommand($btn, msg.payload)\n return;\n } \n \n if($btn.data(\"buttontype\") === \"toggle\"){\n if(msg.payload == \"1\"){\n setButtonState($btn, 1);\n } else if(msg.payload == \"0\"){\n setButtonState($btn, 0);\n } else {\n console.log(\"Invalid toggle value in msg.payload, cannot set \" + buttonSelector + \". Ensure msg.payload is either 0 or 1\") \n }\n }\n\n }); \n \n /** \n * helper function to set the correct icon & update the \"data-payload\" memory \n */\n function setButtonState($btn, state){\n \n $btn.data(\"payload\", state);//set data-payload to new state value (used as a memory)\n \n //determine the opposite state\n var oppositeState;\n if(state == \"1\" || state === 1){\n state = 1; //normalise to a number\n oppositeState = 0;\n } else {\n state = 0; //normalise to a number\n oppositeState = 1;\n }\n \n var $icon = $btn.find(\"i\"); //get the <i> element\n if(!$icon.length){\n $icon = $btn.find(\"span\"); //get the <span> element instead!\n }\n if(!$icon.length){\n console.log(\"<i> or <span> not found inside button - cant toggle the icon!\")\n return;//exit this function - nothing to toggle!\n }\n \n //get the old icon and new icon names\n var oldIcon = $btn.data(\"icon\" + oppositeState); //get icon1 or icon2 depending on oppositeState\n var newIcon = $btn.data(\"icon\" + state); //get icon1 or icon2 depending on newPayload\n \n //if we have newIcon and an actual DOM element ($icon) - update it...\n if(newIcon && $icon.length){\n if(newIcon.includes(\"fa-\")){ \n $icon.removeClass(oldIcon).addClass(newIcon); // fontawesome\n } else { \n $icon.text(newIcon); // MDI\n }\n }\n }\n \n function processCommand($btn, payload){\n //first check payload is correct format...\n if(!payload || !payload.command || !payload.value){\n console.log(\"Cannot process command. Expected a payload object with .command and .value. \")\n }\n var cmd = payload.command.trim();\n switch(cmd){\n case \"addClass\":\n $btn.addClass(payload.value); //this calls the jquery function by name (specified in .command) on the $btn and passes in .value\n break;\n case \"toggleClass\":\n $btn.toggleClass(payload.value); //this calls the jquery function by name (specified in .command) on the $btn and passes in .value\n break;\n case \"removeClass\":\n $btn.removeClass(payload.value); //this calls the jquery function by name (specified in .command) on the $btn and passes in .value\n break;\n default:\n console.log(\"command '\" + payload.command + \"' is not supported\")\n }\n } \n \n /** \n * helper function to determine a value is REALLY a number \n */\n function isNumeric(n){\n if(n === \"\") return false;\n if(n === true || n === false) return false;\n return !isNaN(parseFloat(n)) && isFinite(n);\n }\n \n\n})(scope);\n</script>","storeOutMessages":true,"fwdInMessages":false,"resendOnRefresh":true,"templateScope":"local","x":330,"y":520,"wires":[["60836cd0.7cf2e4"]]},{"id":"60836cd0.7cf2e4","type":"debug","z":"2cd4854b.62f9c2","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":440,"y":400,"wires":[]},{"id":"3c514747.a2de9","type":"ui_group","z":"","name":"Relay","tab":"a7a682c.d6ee88","order":1,"disp":false,"width":"6","collapse":false},{"id":"a7a682c.d6ee88","type":"ui_tab","z":"","name":"Relay","icon":"fa-fire","disabled":false,"hidden":false}]
next flow
[{"id":"25ef7209.834bc6","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"6612f299.67988c","type":"ui_template","z":"25ef7209.834bc6","group":"d143d188.631108","name":"","order":4,"width":0,"height":0,"format":"<div>\n <md-button class=\"md-button remote-button\" \n data-payload=\"1\" \n data-buttontype=\"toggle\"\n data-topic=\"8\"\n data-icon0=\"Relay 8 On\"\n data-icon1=\"Relay 8 Off\"\n aria-label=\"Relay 8\"\n >\n <i class=\"material-icons md-48\">Relay 8</i>\n </md-button>\n</div>","storeOutMessages":true,"fwdInMessages":false,"resendOnRefresh":true,"templateScope":"local","x":220,"y":160,"wires":[["136fb2fe.b14fdd"]]},{"id":"136fb2fe.b14fdd","type":"debug","z":"25ef7209.834bc6","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":460,"y":160,"wires":[]},{"id":"d143d188.631108","type":"ui_group","z":"","name":"css test","tab":"b766fd45.6bcf7","order":1,"disp":true,"width":"6","collapse":false},{"id":"b766fd45.6bcf7","type":"ui_tab","z":"","name":"css testing","icon":"dashboard","disabled":false,"hidden":false}]
