How to set up a toggle button?
How do I go about setting up a toggle button? I realise switches toggle, but they get difficult to tell apart when there are any more than 1 next to each other. I want to make a button that toggles between on/off states and changes colour/text/icon for each state. I have tried the following:
[{"id":"29e7d45f.dea00c","type":"change","z":"adb29586.1f2388","name":"","rules":[{"t":"set","p":"toggle-me","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":880,"y":280,"wires":[["38a5d91c.0be77e"]]},{"id":"1b6fe3d1.5580a4","type":"switch","z":"adb29586.1f2388","name":"","property":"toggle-me","propertyType":"flow","rules":[{"t":"true"},{"t":"false"}],"checkall":"true","repair":false,"outputs":2,"x":670,"y":380,"wires":[["8991bf63.f4d578"],["5fec9b00.abd0d4"]]},{"id":"8cddecf3.4a24f","type":"change","z":"adb29586.1f2388","name":"","rules":[{"t":"set","p":"toggle-me","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1100,"y":420,"wires":[["38a5d91c.0be77e"]]},{"id":"1e692860.33a6d","type":"change","z":"adb29586.1f2388","name":"","rules":[{"t":"set","p":"toggle-me","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1100,"y":340,"wires":[["38a5d91c.0be77e"]]},{"id":"dc371121.720208","type":"inject","z":"adb29586.1f2388","name":"","topic":"","payload":"false","payloadType":"bool","repeat":"","crontab":"","once":true,"onceDelay":0.1,"x":550,"y":280,"wires":[["29e7d45f.dea00c"]]},{"id":"5fec9b00.abd0d4","type":"change","z":"adb29586.1f2388","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":870,"y":420,"wires":[["8cddecf3.4a24f"]]},{"id":"8991bf63.f4d578","type":"change","z":"adb29586.1f2388","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":870,"y":340,"wires":[["1e692860.33a6d"]]},{"id":"38a5d91c.0be77e","type":"ui_text_input","z":"adb29586.1f2388","name":"","label":"","tooltip":"","group":"65a72644.483318","order":3,"width":0,"height":0,"passthru":true,"mode":"text","delay":300,"topic":"","x":1340,"y":380,"wires":[[]]},{"id":"9af5b2c6.42c3d","type":"ui_button","z":"adb29586.1f2388","name":"","group":"65a72644.483318","order":1,"width":0,"height":0,"passthru":true,"label":"button","tooltip":"","color":"","bgcolor":"","icon":"","payload":"true","payloadType":"bool","topic":"","x":550,"y":380,"wires":[["1b6fe3d1.5580a4"]]},{"id":"f40c5c0.c964128","type":"comment","z":"adb29586.1f2388","name":"At startup set default value (false)","info":"","x":900,"y":240,"wires":[]},{"id":"e62c42b2.ed0408","type":"comment","z":"adb29586.1f2388","name":"if flow.state is true set it to false, if flow.state is false set it to true","info":"","x":990,"y":380,"wires":[]},{"id":"65a72644.483318","type":"ui_group","z":"","name":"Virtuelle Taste BidCoS-RF:1","tab":"fe205248.f04ed","disp":true,"width":"6","collapse":false},{"id":"fe205248.f04ed","type":"ui_tab","z":"","name":"Geräte","icon":"dashboard","order":1}]
It seems the sort of thing that should be simple, but I've only found convoluted flows or flows that don't work. For a button that toggles and shows it's toggled.
Take a look to this thread, maybe you gain some ideas from it.
Seems very simple to me
e.g.
[{"id":"8991bf63.f4d578","type":"change","z":"b9860b4b9de8c8da","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"false","tot":"bool"},{"t":"set","p":"toggle_me","pt":"flow","to":"payload","tot":"msg"},{"t":"set","p":"background","pt":"msg","to":"green","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":640,"y":2440,"wires":[["38a5d91c.0be77e","9af5b2c6.42c3d"]]},{"id":"38a5d91c.0be77e","type":"ui_text_input","z":"b9860b4b9de8c8da","name":"","label":"","tooltip":"","group":"65a72644.483318","order":3,"width":0,"height":0,"passthru":true,"mode":"text","delay":300,"topic":"","x":820,"y":2460,"wires":[[]]},{"id":"9af5b2c6.42c3d","type":"ui_button","z":"b9860b4b9de8c8da","name":"","group":"65a72644.483318","order":1,"width":0,"height":0,"passthru":false,"label":"button","tooltip":"","color":"","bgcolor":"{{background}}","className":"","icon":"","payload":"toggle_me","payloadType":"flow","topic":"","topicType":"str","x":350,"y":2460,"wires":[["d200931b81ac48f9"]]},{"id":"d200931b81ac48f9","type":"switch","z":"b9860b4b9de8c8da","name":"","property":"payload","propertyType":"msg","rules":[{"t":"true"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":470,"y":2460,"wires":[["8991bf63.f4d578"],["410e817c9d1d4ec6"]]},{"id":"410e817c9d1d4ec6","type":"change","z":"b9860b4b9de8c8da","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"true","tot":"bool"},{"t":"set","p":"toggle_me","pt":"flow","to":"payload","tot":"msg"},{"t":"set","p":"background","pt":"msg","to":"red","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":640,"y":2480,"wires":[["38a5d91c.0be77e","9af5b2c6.42c3d"]]},{"id":"65a72644.483318","type":"ui_group","name":"Virtuelle Taste BidCoS-RF:1","tab":"fe205248.f04ed","order":1,"disp":true,"width":"6","collapse":false},{"id":"fe205248.f04ed","type":"ui_tab","name":"Geräte","icon":"dashboard","order":1}]
Thank you very much for solving my problem - yours works perfectly, E1cid, and is simple and easy to follow and configure.
I have noticed the same bug present with other node-red toggle buttons sometimes occurs: if I switch FALSE and TRUE around on the change nodes, then the button becomes unresponsive. Hopefully it will work with number messages, as I am broadcasting numbers to control factory windows.
I'll use a variant, something like:
        "id": "748322ba933431e2",
        "type": "change",
        "z": "bb527881acb4097c",
        "name": "Switch ON",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "false",
                "tot": "bool"
                "t": "set",
                "p": "toggle_me",
                "pt": "flow",
                "to": "payload",
                "tot": "msg"
                "t": "set",
                "p": "background",
                "pt": "msg",
                "to": "Red",
                "tot": "str"
                "t": "set",
                "p": "icon",
                "pt": "msg",
                "to": "open_in_browser",
                "tot": "str"
                "t": "set",
                "p": "label",
                "pt": "msg",
                "to": "Open Windows",
                "tot": "str"
                "t": "set",
                "p": "tooltip",
                "pt": "msg",
                "to": "Click to open windows",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 470,
        "y": 1840,
                "9b2e25e671f3b8f2",
                "c61d0e46da1a5a4f"
        "id": "9b2e25e671f3b8f2",
        "type": "ui_text_input",
        "label": "",
        "tooltip": "",
        "group": "65a72644.483318",
        "order": 3,
        "width": 0,
        "height": 0,
        "passthru": true,
        "mode": "text",
        "delay": 300,
        "topic": "",
        "sendOnBlur": true,
        "className": "",
        "topicType": "str",
        "x": 640,
        "y": 1860,
                "4192771b9b04007b"
        "id": "c61d0e46da1a5a4f",
        "type": "ui_button",
        "order": 1,
        "width": 0,
        "height": 0,
        "passthru": false,
        "label": "{{label}}",
        "tooltip": "{{tooltip}}",
        "color": "",
        "bgcolor": "{{background}}",
        "className": "",
        "icon": "{{icon}}",
        "payload": "toggle_me",
        "payloadType": "flow",
        "topic": "",
        "topicType": "str",
        "x": 210,
        "y": 1860,
                "05dccf0103eec66c"
        "id": "05dccf0103eec66c",
        "type": "switch",
        "property": "payload",
        "propertyType": "msg",
        "rules": [
                "t": "true"
                "t": "else"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 330,
        "y": 1860,
                "748322ba933431e2"
                "98ee27c3a3c38e83"
        "id": "98ee27c3a3c38e83",
        "type": "change",
        "name": "Switch OFF",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "true",
                "tot": "bool"
                "t": "set",
                "p": "toggle_me",
                "pt": "flow",
                "to": "payload",
                "tot": "msg"
                "t": "set",
                "p": "background",
                "pt": "msg",
                "to": "Green",
                "tot": "str"
                "t": "set",
                "p": "icon",
                "pt": "msg",
                "to": "system_update_alt",
                "tot": "str"
                "t": "set",
                "p": "label",
                "pt": "msg",
                "to": "Close Windows",
                "tot": "str"
                "t": "set",
                "p": "tooltip",
                "pt": "msg",
                "to": "Click to close windows",
                "tot": "str"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 470,
        "y": 1880,
                "9b2e25e671f3b8f2",
                "c61d0e46da1a5a4f"
        "id": "1656c5b590fe9e63",
        "type": "comment",
        "name": "Toggle button, src:",
        "info": "https://discourse.nodered.org/t/how-to-set-up-a-toggle-button/80132/4\nE1cid, 28/07/2023",
        "x": 290,
        "y": 1820,
        "id": "96059bb091ae1952",
        "type": "inject",
        "name": "open",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "true",
        "payloadType": "bool",
        "x": 210,
        "y": 1900,
                "05dccf0103eec66c"
        "id": "0cc680f7f0c93235",
        "type": "inject",
        "name": "close",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "false",
        "x": 210,
        "y": 1940,
                "05dccf0103eec66c"
        "id": "4192771b9b04007b",
        "type": "debug",
        "name": "Window status",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "",
        "statusType": "auto",
        "x": 660,
        "y": 1920,
        "id": "65a72644.483318",
        "type": "ui_group",
        "name": "Virtuelle Taste BidCoS-RF:1",
        "tab": "fe205248.f04ed",
        "order": 3,
        "disp": true,
        "width": "6",
        "collapse": false,
        "className": ""
        "id": "fe205248.f04ed",
        "type": "ui_tab",
        "name": "Geräte",
        "icon": "dashboard",
        "order": 1
I noticed that perhaps the bug with the button becoming unresponsive on switching TRUE/FALSE around might be due to outdated cached CSS in the web browser for the nodered webpage - a SHIFT+Reload of the dashboard page, thus forcing a cache clear, got it working again for me.
Again, many thanks to E1cid!
I improved the flow to allow more easily configurable output payloads as well as debug control from the nodered backend:
        "id": "2aab0a5cfbf4b93a",
        "type": "change",
        "z": "3b105ee9362f5e1f",
        "rules": [
                "t": "set",
                "p": "toggle_me",
                "pt": "flow",
                "to": "false",
                "tot": "bool"
                "t": "set",
                "p": "background",
                "pt": "msg",
                "to": "Red",
                "tot": "str"
                "t": "set",
                "p": "icon",
                "pt": "msg",
                "tot": "str"
                "t": "set",
                "p": "label",
                "pt": "msg",
                "tot": "str"
                "t": "set",
                "p": "tooltip",
                "pt": "msg",
                "tot": "str"
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "100",
                "tot": "num"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1310,
        "y": 1500,
                "d3bbc89a2aa4572b",
                "d9f701d09a005a30"
        "id": "d3bbc89a2aa4572b",
        "label": "",
        "tooltip": "",
        "group": "ea8ce72e44594614",
        "order": 4,
        "width": 0,
        "height": 0,
        "passthru": true,
        "mode": "text",
        "delay": 300,
        "topic": "",
        "sendOnBlur": true,
        "className": "",
        "topicType": "str",
        "x": 1480,
        "y": 1520,
                "f1456e3ae48ef999"
        "id": "d9f701d09a005a30",
        "order": 3,
        "width": 0,
        "height": 0,
        "passthru": false,
        "color": "",
        "className": "",
        "icon": "{{icon}}",
        "topic": "",
        "topicType": "str",
        "x": 1050,
        "y": 1520,
                "39a54ec1bc843ac7"
        "id": "39a54ec1bc843ac7",
        "type": "switch",
        "rules": [
                "t": "true"
                "t": "else"
        "checkall": "true",
        "repair": false,
        "outputs": 2,
        "x": 1170,
        "y": 1520,
                "2aab0a5cfbf4b93a"
                "222efc0f4031d0d9"
        "id": "222efc0f4031d0d9",
        "type": "change",
        "rules": [
                "t": "set",
                "p": "toggle_me",
                "pt": "flow",
                "to": "true",
                "tot": "bool"
                "t": "set",
                "p": "background",
                "pt": "msg",
                "to": "Green",
                "tot": "str"
                "t": "set",
                "p": "icon",
                "pt": "msg",
                "tot": "str"
                "t": "set",
                "p": "label",
                "pt": "msg",
                "tot": "str"
                "t": "set",
                "p": "tooltip",
                "pt": "msg",
                "tot": "str"
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "1",
                "tot": "num"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 1310,
        "y": 1540,
                "d3bbc89a2aa4572b",
                "d9f701d09a005a30"
        "id": "1737227468d623b2",
        "type": "inject",
        "name": "open",
        "props": [
                "p": "logic",
                "v": "true",
                "vt": "bool"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "x": 1050,
        "y": 1560,
                "39a54ec1bc843ac7"
        "id": "9b26fb2a14514485",
        "type": "inject",
        "name": "close",
        "props": [
                "p": "logic",
                "v": "false",
                "vt": "bool"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "x": 1050,
        "y": 1600,
                "39a54ec1bc843ac7"
        "id": "f1456e3ae48ef999",
        "type": "debug",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 1500,
        "y": 1580,
        "id": "380f6561b3182ef8",
        "type": "comment",
        "name": "Improved window toggle button",
        "info": "Toggle button, src:\nhttps://discourse.nodered.org/t/how-to-set-up-a-toggle-button/80132/4\nE1cid & Darthagnon, 28/07/2023\n\nConfigurable in Switch ON/Switch OFF:\n- button icons\n- button colours\n- output msg.payload\n\n\nPossible icons:\n\nOpen windows:\nopen_in_browser\nfa-window-restore\n\nClose windows:\nsystem_update_alt\nfa-window-close\ninbox",
        "x": 1090,
        "y": 1480,
        "id": "ea8ce72e44594614",
        "type": "ui_group",
        "name": "Factory Windows",
        "tab": "7179c13.0628d4",
        "order": 6,
        "disp": true,
        "width": "6",
        "collapse": false,
        "className": ""
        "id": "7179c13.0628d4",
        "type": "ui_tab",
        "name": "Debug",
        "order": 5,
        "disabled": false,
        "hidden": false
Just tried and it has some slight problems. Maybe it's only for me but you can try. If you have more than 1 tab for dashboard and if you switch the tabs and then if you come back to the tab with the button - icons and the label doesn't change any more. It still fires correct payload but the button doesn't change those anyhow.
Not most reliable solution.
And the button of course can't reflect the real world situation cos it made to drive itself. But that's may not be case if it is not requirement.
I wonder if that's that CSS refresh situation? Switching tabs changes CSS, but does not refresh page. Full reload makes it work again. Seems like an underlying node-red issue?
Yes it can if you feed the real world value into the flow after the button
see example.
The issue you have highlighted seems to be a bug with dashboard button as the background colour changes but not label, unless you refresh the page. Might be worth raising an issue.
@Darren in example added a way to change the values i.e false, true or 1, 100. Just edit change node that sets msg.values.
[{"id":"a62d971593d371ba","type":"ui_button","z":"b9860b4b9de8c8da","name":"button one","group":"b9baaa26cb58043a","order":1,"width":0,"height":0,"passthru":false,"label":"{{label}}","tooltip":"{{tooltip}}","color":"","bgcolor":"{{background}}","className":"","icon":"{{icon}}","payload":"toggle_me","payloadType":"flow","topic":"","topicType":"str","x":350,"y":2380,"wires":[["b55fbcbde4804f18"]]},{"id":"754647e1d3d2d518","type":"change","z":"b9860b4b9de8c8da","name":"Switch ON","rules":[{"t":"set","p":"payload","pt":"msg","to":"values.off","tot":"msg"},{"t":"set","p":"toggle_me","pt":"flow","to":"payload","tot":"msg"},{"t":"set","p":"background","pt":"msg","to":"Red","tot":"str"},{"t":"set","p":"icon","pt":"msg","to":"open_in_browser","tot":"str"},{"t":"set","p":"label","pt":"msg","to":"Open Windows","tot":"str"},{"t":"set","p":"tooltip","pt":"msg","to":"Click to open windows","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":650,"y":2280,"wires":[["a62d971593d371ba","4029bfef97726be7","7869f9213316186e"]]},{"id":"54c4d4d32b5b2883","type":"change","z":"b9860b4b9de8c8da","name":"Switch OFF","rules":[{"t":"set","p":"payload","pt":"msg","to":"values.on","tot":"msg"},{"t":"set","p":"toggle_me","pt":"flow","to":"payload","tot":"msg"},{"t":"set","p":"background","pt":"msg","to":"Green","tot":"str"},{"t":"set","p":"icon","pt":"msg","to":"system_update_alt","tot":"str"},{"t":"set","p":"label","pt":"msg","to":"Close Windows","tot":"str"},{"t":"set","p":"tooltip","pt":"msg","to":"Click to close windows","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":650,"y":2480,"wires":[["a62d971593d371ba","4029bfef97726be7","7869f9213316186e"]]},{"id":"b55fbcbde4804f18","type":"change","z":"b9860b4b9de8c8da","name":"","rules":[{"t":"set","p":"values","pt":"msg","to":"button.one","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":520,"y":2380,"wires":[["27d07fcbbddee1a1"]]},{"id":"27d07fcbbddee1a1","type":"switch","z":"b9860b4b9de8c8da","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"values.on","vt":"msg"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":670,"y":2380,"wires":[["754647e1d3d2d518"],["54c4d4d32b5b2883"]]},{"id":"4029bfef97726be7","type":"ui_text_input","z":"b9860b4b9de8c8da","name":"","label":"","tooltip":"","group":"b9baaa26cb58043a","order":3,"width":0,"height":0,"passthru":true,"mode":"text","delay":300,"topic":"","sendOnBlur":true,"className":"","topicType":"str","x":840,"y":2380,"wires":[[]]},{"id":"7869f9213316186e","type":"debug","z":"b9860b4b9de8c8da","name":"debug 324","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":850,"y":2320,"wires":[]},{"id":"dc8536bc764b4e05","type":"change","z":"b9860b4b9de8c8da","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$flowContext(\"button.one\").*[$ != $$.payload]","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":560,"y":2540,"wires":[["b55fbcbde4804f18"]]},{"id":"2d181930a5325352","type":"ui_button","z":"b9860b4b9de8c8da","name":"","group":"b9baaa26cb58043a","order":2,"width":0,"height":0,"passthru":false,"label":"1","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"1","payloadType":"num","topic":"topic","topicType":"msg","x":390,"y":2520,"wires":[["dc8536bc764b4e05"]]},{"id":"5f87df6ba54ca19b","type":"ui_button","z":"b9860b4b9de8c8da","name":"","group":"b9baaa26cb58043a","order":3,"width":0,"height":0,"passthru":false,"label":"100","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"100","payloadType":"num","topic":"topic","topicType":"msg","x":390,"y":2580,"wires":[["dc8536bc764b4e05"]]},{"id":"d0031228b2fb4651","type":"inject","z":"b9860b4b9de8c8da","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":400,"y":2620,"wires":[["2a9b534d4cfbcaf2"]]},{"id":"2a9b534d4cfbcaf2","type":"change","z":"b9860b4b9de8c8da","name":"set button 1 values","rules":[{"t":"set","p":"button.one","pt":"flow","to":"{\"off\":1, \"on\": 100}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":610,"y":2620,"wires":[[]]},{"id":"b9baaa26cb58043a","type":"ui_group","name":"Virtuelle Taste BidCoS-RF:1","tab":"fe205248.f04ed","order":3,"disp":true,"width":"6","collapse":false,"className":""},{"id":"fe205248.f04ed","type":"ui_tab","name":"Geräte","icon":"dashboard","order":1}]
[edit] fixed reversed real world values by reversing them
It can't happen if:
button is driven by real world situation and ui_control node is involved to refresh button states in case of tab changes / page reload / socket connects
Nothing related to CSS for sure.
It also can't happen when driven by itself and you use ui-control to reload on opening tab.
Even when driven by real world input the issue happens.
e.g.
[{"id":"1bb490b83ea31a72","type":"ui_text_input","z":"1aec8b4fbf3e71df","name":"","label":"","tooltip":"","group":"8b5cde76.edd58","order":3,"width":0,"height":0,"passthru":true,"mode":"text","delay":300,"topic":"","sendOnBlur":true,"className":"","topicType":"str","x":500,"y":220,"wires":[[]]},{"id":"a94fc2842bdc30a1","type":"ui_button","z":"1aec8b4fbf3e71df","name":"","group":"8b5cde76.edd58","order":1,"width":0,"height":0,"passthru":true,"label":"{{label}}","tooltip":"","color":"","bgcolor":"{{background}}","className":"","icon":"{{icon}}","payload":"toggle_me","payloadType":"flow","topic":"","topicType":"str","x":270,"y":220,"wires":[["1bb490b83ea31a72"]]},{"id":"ef09ff579e5b964b","type":"ui_button","z":"1aec8b4fbf3e71df","name":"false","group":"8b5cde76.edd58","order":0,"width":0,"height":0,"passthru":false,"label":"false","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"false","payloadType":"bool","topic":"topic","topicType":"msg","x":250,"y":300,"wires":[["997e6b65eb11bbbe"]]},{"id":"8f48faac0c8cf43f","type":"ui_button","z":"1aec8b4fbf3e71df","name":"true","group":"8b5cde76.edd58","order":2,"width":0,"height":0,"passthru":false,"label":"true","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"true","payloadType":"bool","topic":"topic","topicType":"msg","x":250,"y":340,"wires":[["4721aa82214536e0"]]},{"id":"997e6b65eb11bbbe","type":"change","z":"1aec8b4fbf3e71df","name":"","rules":[{"t":"set","p":"background","pt":"msg","to":"red","tot":"str"},{"t":"set","p":"label","pt":"msg","to":"open window","tot":"str"},{"t":"set","p":"icon","pt":"msg","to":"open_in_browser","tot":"str"},{"t":"set","p":"real","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":400,"y":300,"wires":[["a94fc2842bdc30a1"]]},{"id":"4721aa82214536e0","type":"change","z":"1aec8b4fbf3e71df","name":"","rules":[{"t":"set","p":"background","pt":"msg","to":"green","tot":"str"},{"t":"set","p":"label","pt":"msg","to":"close window","tot":"str"},{"t":"set","p":"icon","pt":"msg","to":"close_in_browser","tot":"str"},{"t":"set","p":"real","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":400,"y":340,"wires":[["a94fc2842bdc30a1"]]},{"id":"8b5cde76.edd58","type":"ui_group","name":"default","tab":"8f03e639.85956","order":1,"disp":false,"width":"12","collapse":false},{"id":"8f03e639.85956","type":"ui_tab","name":"Home","icon":"dashboard","order":3,"disabled":false,"hidden":false}]
Never said it was CSS related, just said it may be a bug as the background changes but not icon and label, which seem strange.
[edit] The issue does not happen if you remove the tool tip message and {{msg.tooltip}}
e.g.
[{"id":"0523a18a656e3643","type":"switch","z":"1aec8b4fbf3e71df","name":"","property":"payload","propertyType":"msg","rules":[{"t":"true"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":390,"y":220,"wires":[["54555e81ee83b983"],["d31222ae448735fc"]]},{"id":"3964b080f9d33cb2","type":"ui_button","z":"1aec8b4fbf3e71df","name":"","group":"1ed15b1f3efebbf1","order":1,"width":"0","height":"0","passthru":false,"label":"{{msg.label}}","tooltip":"","color":"","bgcolor":"{{background}}","className":"","icon":"{{msg.icon}}","payload":"toggle_me","payloadType":"flow","topic":"","topicType":"str","x":210,"y":220,"wires":[["0523a18a656e3643"]]},{"id":"54555e81ee83b983","type":"change","z":"1aec8b4fbf3e71df","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"false","tot":"bool"},{"t":"set","p":"toggle_me","pt":"flow","to":"payload","tot":"msg"},{"t":"set","p":"background","pt":"msg","to":"green","tot":"str"},{"t":"set","p":"icon","pt":"msg","to":"system_update_alt","tot":"str"},{"t":"set","p":"label","pt":"msg","to":"close window","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":560,"y":200,"wires":[["3964b080f9d33cb2","62c9a3427bb1fb1e"]]},{"id":"d31222ae448735fc","type":"change","z":"1aec8b4fbf3e71df","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"true","tot":"bool"},{"t":"set","p":"toggle_me","pt":"flow","to":"payload","tot":"msg"},{"t":"set","p":"background","pt":"msg","to":"red","tot":"str"},{"t":"set","p":"icon","pt":"msg","to":"open_in_browser","tot":"str"},{"t":"set","p":"label","pt":"msg","to":"open window","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":560,"y":240,"wires":[["3964b080f9d33cb2","62c9a3427bb1fb1e"]]},{"id":"62c9a3427bb1fb1e","type":"ui_text_input","z":"1aec8b4fbf3e71df","name":"","label":"","tooltip":"","group":"1ed15b1f3efebbf1","order":3,"width":0,"height":0,"passthru":true,"mode":"text","delay":300,"topic":"","sendOnBlur":true,"className":"","topicType":"str","x":740,"y":220,"wires":[[]]},{"id":"1ed15b1f3efebbf1","type":"ui_group","name":"Virtuelle Taste BidCoS-RF:1","tab":"fe205248.f04ed","order":1,"disp":true,"width":"6","collapse":false},{"id":"fe205248.f04ed","type":"ui_tab","name":"Geräte","icon":"dashboard","order":1}]
After experimentation, I found that making sure all references in the button to variables were e.g. {{msg.background}} instead of {{background}}, it seemed to make the button work even after switching tabs.
Reason I mention CSS is usually when I'm developing websites, if something is borked similar to this, it's usually because the browser is still serving the locally cached CSS rather than my fixed version.
