I have a "change" node with 4 rules that I have customized for my special purpose. AS I need to use that node several times in my flows, is there a way to save it and re-use it when I need?
Yes, create a subflow.
Select the change node, then from the hamburger top right select subflow & Selection to Subflow. It will then appear at the top of your node palette, where you can then edit it and add input & output pins, and give it a name.
Cool (and easy)!
Thank you.
