Custom node: chart in my editor
Hello everybody,
You guys helped me so well with my custom nodes so far! In the editor of my node I want to display a dynamic chart whichs depends on the node properties. I have absolutely no idea how to do this.
<!-- <script type="text/javascript"> part -->
<script type="text/x-red" data-template-name="custom-node">
    // script with <div>'s for the node property editors
    // <div> for chart. I was thinking about maybe using chart.js, however I have no idea how to integrate this in the node-red editor and I hope someone can help me with this.
    <div id="chart">
    </div>
</script>
<!-- <script type="text/x-red" data-help-name="custom-node"> part -->
The editor is NOT intended to be a dashboard... what is the use case for showing charts in an editor node ? How do they help you configure a node ?
Yes. It will show the motion when you're configuring the node. So it would be very usefull.
OK - the geofence node - https://github.com/hardillb/node-red-node-geofence has a good example of including extra JS libraries - so you could look at that for inspiration. chart.js will add a few MB to your download though.
Also, don't use an id of chart as there is already an element on the page with that id and it will clash and break things!
I SOLVED IT!!!
The mistake that I made was actually really simple. I did not link the chart.js code in my settings file using httpStatic, but I solved that problem with this (Import JavaScript library into node-red) post.
So the httpStatic thing is very easy to do:
  1. create a directory with a beautiful name, like C:/node-red-static/chartjs and put your Chart.js files here
  2. go to your .node-red folder and open settings.js, set httpStatic to C:/node-red-static
  3. restart node-red
  4. load http://localhost:1880/chartjs/dist/Chart.js, you should see your Chart.js code here
In your html code link Chart.js using
<script src="http://localhost:1880/chartjs/dist/Chart.js"></script>
and my total html code is shown below. I hope this can help someone!
<script src="http://localhost:1880/chartjs/dist/chart.js"></script>
	RED.nodes.registerType('test-chart',{
		category: 'test',
		color: '#a6bbcf',
		defaults: {
			someProps: {value:0}
		inputs:1,
		outputs:1,
		label: function(){ return this.name || 'test-chart';},
		oneditprepare: function(){
			var canvas = document.getElementById("myChart");
			var ctx = canvas.getContext("2d");
			//ctx.font = "30px Verdana";
			//ctx.fillStyle = "red";
			//ctx.textAlign = "center";
			//ctx.fillText("Hello World!", canvas.width/2, canvas.height/2);
			var myChart = new Chart(ctx, {
				type: 'bar',
				data: {
					labels: ['Red', 'Blue', 'Yellow', 'Green', 'Purple', 'Orange'],
					datasets: [{
						label: '# of Votes',
						data: [12, 19, 3, 5, 2, 3],
						backgroundColor: [
							'rgba(255, 99, 132, 0.2)',
							'rgba(54, 162, 235, 0.2)',
							'rgba(255, 206, 86, 0.2)',
							'rgba(75, 192, 192, 0.2)',
							'rgba(153, 102, 255, 0.2)',
							'rgba(255, 159, 64, 0.2)'
						borderColor: [
							'rgba(255, 99, 132, 1)',
							'rgba(54, 162, 235, 1)',
							'rgba(255, 206, 86, 1)',
							'rgba(75, 192, 192, 1)',
							'rgba(153, 102, 255, 1)',
							'rgba(255, 159, 64, 1)'
						borderWidth: 1
				options: {
					scales: {
						yAxes: [{
							ticks: {
								beginAtZero: true
</script>
<script type="text/x-red" data-template-name="test-chart">
	<div id="test-chart">
	<canvas id="myChart" width="400" height="400"></canvas>
	</div>
</script>
<script type="text/x-red" data-help-name="test-chart">
	<p> helup </p>
</script>
