I have created a custom node and in the .JS file there is a line of code which accepts the User Input Data from the HTML dialog.
This is the line of code I m referring:
this.applicationHash = config.applicationHash;
How can I override the user's data and accept data from an input that I pass in the msg object?
well.... our basic rules is actually the opposite of that...
If the user has set a parameter then they actually want that value and so it should not be overridden. If they leave it blank then it should be set by a msg property...
usually in the on input handler you set a new variable
var appHash = node.applicationHash || msg.applicationHash || "my_safe_default";
