Hi folks,
My first question on this new forum ...
I'm currently developing a new contribution to control IP devices using the OnVif protocol. For example you should be able to add new users to the IP device, which I could implement using following code snippet:
var params = {
'User' : [
{'Username': 'user1', 'Password' : 'pwd1', 'UserLevel': 'Administrator'},
{'Username': 'user2', 'Password' : 'pwd2', 'UserLevel': 'Operator'},
{'Username': 'user3', 'Password' : 'pwd3', 'UserLevel': 'User'}
someIpDevice.createUsers(params);
Since I have a lot of available actions, the 'create users' can be selected on the config screen:
But what is the best way to offer those 'params' to my node?
- Should I provide a table on the node's config screen with an 'add user' button (which becomes only visible when 'add users' is selected in the dropdown). But that seems a bit weird, since you need to redeploy the flow to set those new users? Or am I completely mistaken about this?
- Should the payload of the input message contain the entire JSON.
- Both 1 and 2 ?
- Others ?
Thanks a lot !!!
Bart
It has been a while since I looked at this so sorry, I’m rather rusty.
However, if you look at some of the built-in nodes, they are also building a nested dataset like yours. So the best thing to do is to find a node that requires similar settings and then copy that. I can’t think of a specific example off the top of my head, hopefully someone with a better memory will chip in. But if I think of one, I will update.
Hi Julian,
Appreciate your help !!
Have been doing some homework by examing other nodes...
I could show a list of users on the node's config screen:
As soon as an input message triggers this node, those specified users will be created on the OnVif-compatible IP device. And when list of users on the config screen is empty, the input message should contain a user list in JSON format.
P.S. When I need to pass a JSON with more levels (to the IP camera), I'm scr*wed with this table design ...
Thanks !!
Bart
I remember seeing some nodes with nested config, I just can’t remember where I’m afraid.
Good old MQTT
with TLS enabled - gives you a 2nd config for the TLS part.
Hi Julian, Dave,
New forum, old acquaintances
The MQTT broker config node indeed seems to have a nested config node. For anybody reading this, this is the field Dave is talking about:
Thanks !
Bart
Hi guys,
My Onvif implementation for Node-Red is growing, but still a lot of work. For each OnVif function, the user can select an action from a combobox, and then corresponding input fields become visible (i.e. the input for that function).
Now I need to add the setVideoEncoder action, which needs a lot of input:
- This is the OnVif function, with options as parameter
- The user can select a corresponding action from the combobox
- The input fields become visible for all the (required or optional) options. For the options of depth 1 (i.e. option.xxx) this is no problem: I just show them below the combobox.
- However some options have more than 1 level depth (options.mpeg4.profile). How could I visualize this? Can I have some indentation ?
Can't remember that I have seen other nodes with such a config screen ...
Thanks !!!!
Bart
Wow ! Thanks ! I have to see how it works, I thought I read somewhere it was not possible to have a config-node within another config-node …
Hi Bart,
I’m using a camera just with the RTSP stream starting with the tutorial/flow done by Csongor at https://www.youtube.com/watch?v=ihZWrJmbGFY&t=228s however I just ordered a cheap NVR/onvif compatble camera and will play a bit.
Will be great if you share your job a bit when you have something so it will help other ppl like me, will be much appreciated.
Regards
Hi David,
I will release the OnVif node suite as soon as it is ready. The code is at node-red-contrib-onvif, but it is far from finished (missing functionality, lot of bugs, …). It will change a lot soon, so don’t use it yet !!! Give me a couple of weeks …
Bart
Thanks a lot mate, take it easy is not urgent at all but a nice flow will guide a lot other people like me.
Regards
Hey boss, remember to let me know when it’s released so I can play a bit with it if you don’t mind.
Thanks in advance
