Hi, I'm creating a new node that has a RED.editor in it set to ace/mode/html mode.
I copied the code from the core template node but annoyingly, while everything is otherwise working, the resulting saved code keeps removing newlines.
Does anyone know what I've done wrong?
This is where the editor is created:
const stateId = RED.editor.generateViewStateId('node', node, '')
node.editor = RED.editor.createEditor({
mode: 'ace/mode/html',
stateId: stateId,
value: node.html
And this is the oneditsave function:
function onEditSave(node) {
const html = node.editor.getValue()
$('#node-input-html').val(html)
updateTab(html)
node.editor.destroy()
delete node.editor
Everything works correctly except for the HTML code being flattened each time. ![]()
In case it matters, I'm using Monaco for the editor.
