Hi, when I install node-red on a raspberry pi, or some other devices I get a neat code editor with autocomplete, code hints etc, kind of like a Visual Studio environment. However on my main machine I only have a older looking more simple editor. What do I need to update in order to get this to be the new editor?
My old looking editor:
The newer looking editor
My node-red version is 3.1.9, NodeJs: 20.12.2 and npm: 10.6.0.
Thanks in advance!
In your machines with the older ACE editor, your node-red version is either v2.x or there is a setting in settings.js forcing the old editor to be used.
See this: Getting the monaco editor to work in NR 2.x - #33 by Steve-Mcl
Ps: did you also update Node-RED on the main machine?
Thanks, my editor lib in settings.js was indeed set to "ace". Setting it to "monaco" gave me the new editor.
codeEditor: {
/** Select the text editor component used by the editor.
* Defaults to "ace", but can be set to "ace" or "monaco"
lib: "monaco",
options: {
/** The follow options only apply if the editor is set to "monaco"
* theme - must match the file name of a theme in
* packages/node_modules/@node-red/editor-client/src/vendor/monaco/dist/theme
* e.g. "tomorrow-night", "upstream-sunburst", "github", "my-theme"
theme: "vs",
/** other overrides can be set e.g. fontSize, fontFamily, fontLigatures etc.
* for the full list, see https://microsoft.github.io/monaco-editor/api/interfaces/monaco.editor.istandaloneeditorconstructionoptions.html
//fontSize: 14,
//fontFamily: "Cascadia Code, Fira Code, Consolas, 'Courier New', monospace",
//fontLigatures: true,
