Add Monaco Editor - how?
hello
on a VM i installed node Red 2
so far it works!
i wish to change to the monaco editor
node-red -v
[info] Einstellungsdatei: /root/.node-red/settings.js
so i edited the file and aroud line 353
i changed the lib acs to monaco
did a reboot
but still the editor did not change
so i belive i would have to install it too so i did a
npm i monaco-editor
restarted node red but still the editor is not monaco
so what do i miss?
have a nice day
vinc
This is not necessary and won't work. Monaco was specially prepared/compiled for use in node-red & is included in the installation of node-red.
My guess is you have once started node red as root (that's why there is a .node-red folder there) BUT I suspect node-red starts up automatically as a different non root user. In essence, you have modified the wrong settings.js file.
This rings a bell :point_up:
What user were you logged in as when you installed node-red? Log in as that user & modify settings.js in the ~/.node-red folder
you are fast @Steve-Mcl
Merci for your feedback.
is it documented which file to use?
# find / -name settings.js
/home/nodered/.node-red/settings.js
/usr/lib/node_modules/node-red/settings.js
/usr/lib/node_modules/node-red/node_modules/node-red-admin/settings.js
/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/settings.js
/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/api/settings.js
/usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/storage/localfilesystem/settings.js
/usr/lib/node_modules/node-red/node_modules/@node-red/editor-api/lib/editor/settings.js
/usr/lib/node_modules/node-red/node_modules/@node-red/editor-api/lib/admin/settings.js
See my previous reply.
it runs under nodered
nodered 4212 1.0 4.9 876660 101124 ? SNsl 23:52 0:03 node-red
So log in as that user & edit the settings as I described.
i think i messed up - it start as user nodered but was installed as root. so i will have to set up it again it seems.
Node-RED logs the path to its settings file when it starts.
From the files you've listed, /home/nodered/.node-red/settings.js will be the right one.
No need to reinstall if you aren't running as root.
@knolleary thanks for your feedback.
Done so at line
353 lib: "monaco",
only to stop and start the service did not work. Reboot of the VM seems to have activated Monaco.
But using a new function, i am able to add the name but can't add or edit the text in function itself
have a nice day
vinc
You have a node or nodes that are breaking it.
See this link for how to fix.
@Steve-Mcl Merci
node-red-contrib-zigbee2mqtt 1 - issue raised 2 - fixed in v0.6.9
OK
node-red-contrib-deconz 1 - Issue raised 3 - fixed in v1.3.3
the deconz update is not showing Up in the GUI, so i still have v1.3.2 and this make the brake.
Try updating again in 20 mins, just refreshed the node on flows library (refresh browser before each attempt)
i removed deconz on node red 2 and now it works
so this part will stay on my old node Red 1.x
and i can go on with moving my nodes to Node Red 2 and cleaning up the nodes :wink:
