Is this possible to make in Node-red?
Thank you!
Thank you!
Yes the UI-template node can do what you want to do.
There are numerous examples on the forum
@E1cid, I tried that, but only a checkbox is displayed.
Did you add the css styling too?
Are you referring to this?
<style>
/*--- Toggle Switch CSS --- */
/* Settings */
:root{
/* Standard Toggle */
--tog-scale: 1;
--tog-height: 42px;
--tog-width: 84px;
--tog-knob-diameter: 36px;
--tog-background-inactive: rgb(182, 182, 182);
--tog-background-active: rgb(127, 180, 210);
--tog-knob-color-inactive: rgb(130, 130, 130);
--tog-knob-color-active: rgb(0, 107, 165);
--tog-text-color-inactive: black;
--tog-text-color-active: black;
--tog-text-size: 1rem;
--tog-transition-speed: 0.15s;
/* Power Toggle */
--pwr-tog-scale: 1;
--pwr-tog-height: 42px;
--pwr-tog-width: 84px;
--pwr-tog-knob-diameter: 36px;
--pwr-tog-background-inactive: rgb(182, 182, 182);
--pwr-tog-background-active: rgb(248, 154, 154);
--pwr-tog-knob-color-inactive: rgb(130, 130, 130);
--pwr-tog-knob-color-active: rgb(130, 130, 130); /*rgb(237, 24, 24);*/
--pwr-tog-knob-icon-color-active: orange;
--pwr-tog-knob-icon-color-inactive: lightgray;
--pwr-tog-text-color-inactive: black;
--pwr-tog-text-color-active: black;
--pwr-tog-text-size: 1rem;
--pwr-tog-transition-speed: 0.15s;
/* CSS Selector for toggle-widget settings */
.toggle-widget {
display: block;
padding: 0;
/* Standard Toggle switch body */
.toggle{
display: block;
appearance: none;
-webkit-appearance: none;
-moz-appearance: none;
width: var(--tog-width);
height: var(--tog-height);
background: var(--tog-background-inactive);
border-radius: calc(var(--tog-height) / 2);
position: relative;
transform: scale(var(--tog-scale));
transition-property: background;
transition-duration: var(--tog-transition-speed);
align-self: center;
vertical-align: center !important;
margin: 0px !important;
/* Standard Toggle switch knob */
.toggle:before{
content: "";
background: var(--tog-knob-color-inactive);
height: var(--tog-knob-diameter);
width: var(--tog-knob-diameter);
position: absolute;
border-radius: 50%;
top: calc((var(--tog-height) - var(--tog-knob-diameter)) / 2);
left: calc((var(--tog-height) - var(--tog-knob-diameter)) / 2);
transition: all var(--tog-transition-speed);
z-index: 2;
/* Standard Toggle switch inactive text */
.toggle:after{
content: "OFF";
position: absolute;
font-size: var(--tog-text-size);
color: var(--tog-text-color-inactive);
font-weight: bold;
top: 50%;
left: 50%;
transform: translate(8%, -43%);
z-index: 1;
/* Standard Toggle switch checked state */
.toggle:checked{
background: var(--tog-background-active);
/* Standard Toggle Switch Knob offset */
.toggle:checked::before{
background: var(--tog-knob-color-active);
left: calc((var(--tog-height) - var(--tog-knob-diameter)) / 2 + var(--tog-width) - var(--tog-height));
/* Standard Toggle Switch Active Text */
.toggle:checked::after{
content: "ON";
left: 5%;
color: var(--tog-text-color-active);
/* --- Power Toggle CSS --- */
/* Power Toggle switch body */
.toggle-pwr{
display: block;
appearance: none;
width: var(--pwr-tog-width);
height: var(--pwr-tog-height);
background: var(--pwr-tog-background-inactive);
border-radius: calc(var(--pwr-tog-height) / 2);
position: relative;
transform: scale(var(--pwr-tog-scale));
transition-duration: var(--pwr-tog-transition-speed);
align-self: center;
/* Power Toggle switch knob */
.toggle-pwr:before{
display: flex;
align-items: center;
justify-content: center;
font-family: "Material Icons";
content: "\e8ac";
font-size: 2rem;
color: var(--pwr-tog-knob-icon-color-inactive);
/* transition: color .35s ease; */
background: var(--pwr-tog-knob-color-inactive);
height: var(--pwr-tog-knob-diameter);
width: var(--pwr-tog-knob-diameter);
position: absolute;
border-radius: 50%;
top: calc((var(--pwr-tog-height) - var(--pwr-tog-knob-diameter)) / 2);
left: calc((var(--pwr-tog-height) - var(--pwr-tog-knob-diameter)) / 2);
transition: all var(--pwr-tog-transition-speed);
z-index: 2;
/* Power Toggle switch inactive text */
.toggle-pwr:after{
content: "OFF";
position: absolute;
font-size: var(--pwr-tog-text-size);
color: var(--pwr-tog-text-color-inactive);
font-weight: bold;
top: 50%;
left: 50%;
z-index: 1;
/* Power Toggle cwitch checked state */
.toggle-pwr:checked{
background: var(--pwr-tog-background-active);
/* Power Toggle Switch Knob offset */
.toggle-pwr:checked::before{
color: var(--pwr-tog-knob-icon-color-active);
/*text-shadow: 0 0 3px var(--pwr-tog-knob-icon-color-active);*/
/*text-shadow: 0 0 2px #fff, 0 0 4px #fff, 0 0 6px #e60073, 0 0 8px #e60073, 0 0 10px #e60073, 0 0 12px #e60073, 0 0 14px #e60073;*/
text-shadow: 0 0 2px var(--pwr-tog-knob-icon-color-active), 0 0 4px var(--pwr-tog-knob-icon-color-active), 0 0 6px #e60073, 0 0 8px #e60073, 0 0 10px #e60073, 0 0 12px #e60073, 0 0 14px #e60073;
background: var(--pwr-tog-knob-color-active);
left: calc((var(--pwr-tog-height) - var(--pwr-tog-knob-diameter)) / 2 + var(--pwr-tog-width) - var(--pwr-tog-height));
/* Power Toggle Switch Active Text */
.toggle-pwr:checked::after{
content: "ON";
left: 5%;
color: var(--pwr-tog-text-color-active);
</style>
Yes that should be in the template with the html and any Javascript.
It works now, but it makes my dashboard page smaller. How do I fix that?
Template node:
<label class="switch">
<input type="checkbox">
<span></span>
</label>
<!-- dribbble -->
<a class="dribbble" href="https://dribbble.com/shots/5449131-Switch-animation"
target="_blank"><img src="https://cdn.dribbble.com/assets/dribbble-ball-mark-2bd45f09c2fb58dbbfb44766d5d1d07c5a12972d602ef8b32204d28fa3dda554.svg" alt=""></a>
<style>
.switch {
cursor: pointer;
.switch input {
display: none;
.switch input + span {
width: 48px;
height: 28px;
border-radius: 14px;
transition: all 0.3s ease;
display: block;
position: relative;
background: #FF4651;
box-shadow: 0 8px 16px -1px rgba(255, 70, 81, 0.2);
.switch input + span:before, .switch input + span:after {
content: "";
display: block;
position: absolute;
.switch input + span:before {
top: 5px;
left: 5px;
width: 18px;
height: 18px;
border-radius: 9px;
border: 5px solid #fff;
top: 5px;
left: 32px;
width: 6px;
height: 18px;
border-radius: 40%;
transform-origin: 50% 50%;
background: #fff;
opacity: 0;
.switch input + span:active {
transform: scale(0.92);
.switch input:checked + span {
background: #48EA8B;
box-shadow: 0 8px 16px -1px rgba(72, 234, 139, 0.2);
.switch input:checked + span:before {
width: 0px;
border-radius: 3px;
margin-left: 27px;
border-width: 3px;
background: #fff;
.switch input:checked + span:after {
-webkit-animation: blobChecked 0.35s linear forwards 0.2s;
.switch input:not(:checked) + span:before {
-webkit-animation: blob 0.85s linear forwards 0.2s;
html {
-webkit-font-smoothing: antialiased;
box-sizing: border-box;
*:before, *:after {
body {
min-height: 100vh;
font-family: Roboto, Arial;
color: #ADAFB6;
display: flex;
background: #F5F9FF;
body .dribbble {
position: fixed;
display: block;
right: 20px;
bottom: 20px;
body .dribbble img {
display: block;
height: 28px;
</style>
I would say the css of the check box is messing with the css of dashboard. Css is not my thing i can fumble through it but would be guessing. Hopefully some other forum user maybe able to help here.
@E1cid, thank you for the help!
I was able to fix the dashboard size issue.
I am having a new issue. I am using ng-model to send output, but the switch is controlled through injected payload and manually clicking it. The switch does not register the new state when clicked after a state was injected. Any ideas?
Found the solution: setting the ng-checked="checkboxModel = msg.payload". This allowed me to use the toggle smoothly between injected payloads and manual switch control.
