Daily Schedule with Gate Control
[{"id":"ce75c26918b78527","type":"gate","z":"c83d72886d5b02c0","name":"","controlTopic":"control","defaultState":"closed","openCmd":"open","closeCmd":"close","toggleCmd":"toggle","defaultCmd":"default","statusCmd":"status","persist":false,"storeName":"default","x":960,"y":310,"wires":[[]]},{"id":"0878e020e1a53ff7","type":"inject","z":"c83d72886d5b02c0","name":"Open Gate","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"control","payload":"open","payloadType":"str","x":750,"y":360,"wires":[["ce75c26918b78527"]]},{"id":"f1ac77770884333f","type":"inject","z":"c83d72886d5b02c0","name":"Close Gate","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"control","payload":"close","payloadType":"str","x":750,"y":260,"wires":[["ce75c26918b78527"]]},{"id":"b175219513ad65b0","type":"trigger","z":"c83d72886d5b02c0","name":"Open, Wait and Close","op1":"open","op2":"close","op1type":"str","op2type":"str","duration":"5","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":710,"y":310,"wires":[["ce75c26918b78527"]]},{"id":"bb40b54e5b5cfbb0","type":"change","z":"c83d72886d5b02c0","name":"Gate Control","rules":[{"t":"set","p":"topic","pt":"msg","to":"control","tot":"str"},{"t":"set","p":"payload","pt":"msg","to":"open","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":510,"y":310,"wires":[["b175219513ad65b0"]]},{"id":"ac710bce85890ac2","type":"cronplus","z":"c83d72886d5b02c0","name":"@ 07:15","outputField":"payload","timeZone":"","persistDynamic":false,"commandResponseMsgOutput":"output1","outputs":1,"options":[{"name":"schedule1","topic":"schedule1","payloadType":"str","payload":"open","expressionType":"cron","expression":"0 15 7 * * * *","location":"","offset":"0","solarType":"all","solarEvents":"sunrise,sunset"}],"x":350,"y":310,"wires":[["bb40b54e5b5cfbb0"]]},{"id":"dc4b6debfedd4f51","type":"inject","z":"c83d72886d5b02c0","name":"Start Schedule","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.1,"topic":"start","payload":"schedule1","payloadType":"str","x":140,"y":270,"wires":[["ac710bce85890ac2"]]},{"id":"77049032345f5f2d","type":"inject","z":"c83d72886d5b02c0","name":"Stop Schedule","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"stop","payload":"schedule1","payloadType":"str","x":140,"y":310,"wires":[["ac710bce85890ac2"]]},{"id":"9825e01365ec99a0","type":"inject","z":"c83d72886d5b02c0","name":"Manual Trigger","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"trigger","payload":"schedule1","payloadType":"str","x":140,"y":350,"wires":[["ac710bce85890ac2"]]}]
contrib nodes used.
node-red-contrib-simple-gate 0.5.2
node-red-contrib-cron-plus 1.5.5
Hi. Thanks for sharing. It would be useful to list out the contrib nodes used.
Thanks a lot for the tip. This was my first attempt. will keep that in mind. Have edited this post.
Wow, that's great. Thank you for sharing this, I'm considering enrolling in computer science this year, and now I'm trying to learn and prepare in programming as much as possible.
