Dark Mode Theme - Looking rather pale
I decided to delve further into the dark (mode) side :stuck_out_tongue: This time with the editor (BTW, the Dashboard is an easy to change Theme option, why not the Editor??)
But after repeatedly following the directions, and seemingly getting that right, I am not seeing any changes...
NOTE: I have installed this a few times already, so I guess that's why it looks like this?
pi@raspberrypi:~ $ npm install @node-red-contrib-themes/theme-collection
npm WARN saveError ENOENT: no such file or directory, open '/home/pi/package.json'
npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
npm WARN pi No description
npm WARN pi No repository field.
npm WARN pi No README data
npm WARN pi No license field.
+ @node-red-contrib-themes/theme-collection@2.0.3
updated 1 package and audited 7 packages in 3.257s
6 packages are looking for funding
  run `npm fund` for details
found 0 vulnerabilities
pi@raspberrypi:~ $
Edit the settings.js file...
Stop and restart NR...
pi@raspberrypi:~ $ node-red-stop
Stop Node-RED
Use   node-red-start   to start Node-RED again
pi@raspberrypi:~ $ node-red-start
Start Node-RED
Once Node-RED has started, point a browser at http://10.10.3.13:1880
On Pi Node-RED works better with the Firefox or Chrome browser
Use   node-red-stop                          to stop Node-RED
Use   node-red-log                           to view the recent log output
Use   sudo systemctl enable nodered.service  to autostart Node-RED at every boot
Use   sudo systemctl disable nodered.service to disable autostart on boot
To find more nodes and example flows - go to http://flows.nodered.org
Starting as a systemd service.
15 Aug 14:25:52 - [info]
Welcome to Node-RED
15 Aug 14:25:52 - [info] Node-RED version: v2.0.5
15 Aug 14:25:52 - [info] Node.js  version: v14.17.5
15 Aug 14:25:52 - [info] Linux 5.10.52-v7+ arm LE
15 Aug 14:25:54 - [info] Loading palette nodes
15 Aug 14:26:02 - [info] Worldmap version 2.15.5
15 Aug 14:26:02 - [info] Dashboard version 2.30.0 started at /ui
15 Aug 14:26:04 - [info] Settings file  : /home/pi/.node-red/settings.js
15 Aug 14:26:04 - [info] HTTP Static    : /home/pi/node-red-static
15 Aug 14:26:04 - [info] Context store  : 'default' [module=memory]
15 Aug 14:26:04 - [info] User directory : /home/pi/.node-red
15 Aug 14:26:04 - [warn] Projects disabled : editorTheme.projects.enabled=false
15 Aug 14:26:04 - [info] Flows file     : /home/pi/.node-red/flows.json
15 Aug 14:26:04 - [info] Server now running at http://127.0.0.1:1880/
your credentials.
15 Aug 14:26:05 - [info] Starting flows
creating LCD node
LCD node init @ i2c addr:63
15 Aug 14:26:10 - [info] Started flows
15 Aug 14:26:10 - [info] [remote-xy-dashboard:RemoteXY] listening on port 6377
15 Aug 14:26:12 - [info] [mqtt-broker:RPi Mosquitto broker] Connected to broker: mqtt://10.10.3.13:1883
15 Aug 14:26:12 - [info] [mqtt-broker:Local] Connected to broker: mqtt://127.0.0.1:1883
(node:3278) Warning: Setting the NODE_TLS_REJECT_UNAUTHORIZED environment variable to '0' makes TLS connections and HTTPS requests insecure by disabling certificate verification.
(Use `node --trace-warnings ...` to show where the warning was created)
Initialized PCA9685
2021-08-15 14:26:18.753872: W tensorflow/core/framework/allocator.cc:107] Allocation of 8640000 exceeds 10% of system memory.
2021-08-15 14:26:18.855964: W tensorflow/core/framework/allocator.cc:107] Allocation of 8640000 exceeds 10% of system memory.
2021-08-15 14:26:18.910742: W tensorflow/core/framework/allocator.cc:107] Allocation of 8640000 exceeds 10% of system memory.
2021-08-15 14:26:18.928450: W tensorflow/core/framework/allocator.cc:107] Allocation of 8640000 exceeds 10% of system memory.
But still the white hat on a pale horse version....
You have run the install in the wrong directory.
You need to be in ~/.node-red
Thanks, that worked... I guess I will post that needed tidbit with a github issue...
