Darken background behind notification window
is it possible to darken the background behind the notification window so that the notification window is better highlighted?
Some some css in a ui-template will do that.
Use your browsers dev tools to find the class / variable that affects it. Once you have that, make a ui-template with the necessary CSS override.
I found the necessary CCS:
.v-snackbar {
    background-color: rgba(0, 0, 0, 0.7);
    margin: 0px !important;
