Hello, I'm trying to style my "notification" node with the template node but I don't know why it's not changing the color and border
Follow my flow below:
[{"id":"e178618d12a06b0e","type":"tab","label":"Flow 1","disabled":false,"info":"","env":[]},{"id":"8d12b7c1d045061c","type":"inject","z":"e178618d12a06b0e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"true","payloadType":"bool","x":330,"y":260,"wires":[["d81e5c011568d706"]]},{"id":"4d89ea8d163d9ae3","type":"inject","z":"e178618d12a06b0e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"false","payloadType":"bool","x":330,"y":360,"wires":[["d81e5c011568d706"]]},{"id":"d81e5c011568d706","type":"rbe","z":"e178618d12a06b0e","name":"","func":"rbei","gap":"","start":"","inout":"out","septopics":true,"property":"payload","topi":"topic","x":610,"y":280,"wires":[["29c0b8921a82592c"]]},{"id":"29c0b8921a82592c","type":"function","z":"e178618d12a06b0e","name":"function 84","func":"if(msg.payload == true){\n msg.payload = \"Realizar troca do equipamento imediatamente.\"\n msg.topic = \"Atuador 1 necessita de manutenção!\"\n}\nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":770,"y":280,"wires":[["1a10779adaecfe2a"]]},{"id":"1a10779adaecfe2a","type":"switch","z":"e178618d12a06b0e","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Realizar troca do equipamento imediatamente.","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":910,"y":280,"wires":[["6d9a99f773591ec9"]]},{"id":"6d9a99f773591ec9","type":"ui_toast","z":"e178618d12a06b0e","position":"dialog","displayTime":"3","highlight":"","sendall":true,"outputs":1,"ok":"OK","cancel":"","raw":false,"className":"vor2","topic":"","name":"","x":990,"y":380,"wires":[[]]},{"id":"d52013405d3454db","type":"ui_template","z":"e178618d12a06b0e","group":"a3fa2dec44535f8f","name":"","order":69,"width":0,"height":0,"format":"<style>\n \n .vor2>.md-button {\n background-color: rgb(0, 250, 0) !important;\n /* add your custom css here */\n border-radius: 15px\n }\n\n </style","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":1020,"y":520,"wires":[[]]},{"id":"a3fa2dec44535f8f","type":"ui_group","name":"Monitoramento de vida útil","tab":"e92507140fa94b1e","order":1,"disp":true,"width":"30","collapse":false,"className":""},{"id":"e92507140fa94b1e","type":"ui_tab","name":"EEEEEEEE","icon":"dashboard","disabled":false,"hidden":false}]
