How to change the buttons in dashboard
node red v3
id like to know how you change the boring buttons in dashboard - im making an 8 channel relay switch board via usb for my overlander car ... id like to change from this ..
to something like this style -
like simple easy read vehicle buttons .. got it all working so far and works fine just want to change buttons how is it done?
You've got the current Flow?
It''s not too difficult to add an icon and change the style of the buttons but only Font Awesome v4 icons are built into Node-red.
I think the ones in your post are v5 or v6 and they are not free.
an example how to style buttons
The third button is an ui-template node where the icon is included as svg (From newer font-awesome versions you could download the svg-icon). If you use that you should tweak the ripple to make it feel like the ui-buttons.
        "id": "76d2f79fde403ebf",
        "type": "tab",
        "label": "3 designed btns",
        "disabled": false,
        "info": "",
        "env": []
        "id": "8852173575bec666",
        "type": "ui_button",
        "z": "76d2f79fde403ebf",
        "name": "button 1",
        "group": "d921e9fe7b208126",
        "order": 1,
        "width": "2",
        "height": "2",
        "passthru": false,
        "label": "Assignment",
        "tooltip": "",
        "color": "",
        "bgcolor": "",
        "className": "styled-button",
        "icon": "mi-assignment",
        "payload": "",
        "payloadType": "str",
        "topic": "topic",
        "topicType": "msg",
        "x": 1240,
        "y": 480,
        "id": "ebdf05a4bb3726b4",
        "name": "button 2",
        "order": 2,
        "width": "2",
        "height": "2",
        "passthru": false,
        "label": "Basket",
        "tooltip": "",
        "color": "",
        "bgcolor": "",
        "icon": "fa-shopping-basket",
        "payload": "",
        "topic": "topic",
        "topicType": "msg",
        "x": 1240,
        "y": 560,
        "id": "5aa339a9467c6a4c",
        "type": "ui_template",
        "group": "c3bc11b854faa005",
        "order": 5,
        "width": 0,
        "height": 0,
        "format": "<style>\n    .styled-button button{\n        background-color: cadetblue !important;\n        border-radius: 8px !important;\n    }\n    \n    .styled-button ui-icon{\n        display:block;\n    }\n    \n    .styled-button img{\n        width = 50px;\n        height = 50px;\n    }\n    .styled-button span{\n        font-size: 14px;\n    }\n    \n    .styled-template{\n        padding:0 !important;\n        overflow-y:unset !important;\n        vertical-align:unset !important;\n    }\n    \n    .styled-template button{\n        line-height:36px;\n    }\n</style>",
        "storeOutMessages": true,
        "fwdInMessages": true,
        "resendOnRefresh": true,
        "templateScope": "global",
        "className": "",
        "x": 1240,
        "y": 400,
        "id": "a903d8fd0deadcf8",
        "name": "button 3",
        "order": 3,
        "width": "2",
        "height": "2",
        "format": "<style>\n    .button-ripple{\n        overflow:hidden;\n        width:100%;\n        height:100%;\n        left:0;\n        top: 0;\n        position:absolute;\n        display:block;\n        z-index:1;\n        border-radius: inhirit;\n        background-clip: padding-box;\n        background-color: rgba(255,255,255,0);\n        transition: all 0.55s cubic-bezier(0,0,0.2,1) ;\n        -webkit-transform: translateZ(1);\n    }\n    .button-ripple:active{\n        left:50%;\n        width:0%;\n        background-color: rgba(255,255,255,0.1);\n        transition: all 0s;\n    }\n    .s36{\n        display:block;\n        vertical-align:unset;\n        width: 36px;\n        height: 36px;\n        filter:saturate(0.0) brightness(10.0) !important;\n    }\n</style>\n<button id=\"cloudbutton\" class=\"md-raised md-button\" type=\"button\" ng-click=\"OnButtonClick($event)\" aria-label=\"cloudbutton\">\n    <md-icon  class=\"s36\" md-svg-src='data:image/svg+xml;utf8,<svg xmlns=\"http://www.w3.org/2000/svg\" viewBox=\"0 0 616 512\"><path d=\"M148.6 304c8.2 68.5 67.4 115.5 146 111.3 51.2 43.3 136.8 45.8 186.4-5.6 69.2 1.1 118.5-44.6 131.5-99.5 14.8-62.5-18.2-132.5-92.1-155.1-33-88.1-131.4-101.5-186.5-85-57.3 17.3-84.3 53.2-99.3 109.7-7.8 2.7-26.5 8.9-45 24.1 11.7 0 15.2 8.9 15.2 19.5v20.4c0 10.7-8.7 19.5-19.5 19.5h-20.2c-10.7 0-19.5-6-19.5-16.7V240H98.8C95 240 88 244.3 88 251.9v40.4c0 6.4 5.3 11.8 11.7 11.8h48.9zm227.4 8c-10.7 46.3 21.7 72.4 55.3 86.8C324.1 432.6 259.7 348 296 288c-33.2 21.6-33.7 71.2-29.2 92.9-17.9-12.4-53.8-32.4-57.4-79.8-3-39.9 21.5-75.7 57-93.9C297 191.4 369.9 198.7 400 248c-14.1-48-53.8-70.1-101.8-74.8 30.9-30.7 64.4-50.3 114.2-43.7 69.8 9.3 133.2 82.8 67.7 150.5 35-16.3 48.7-54.4 47.5-76.9l10.5 19.6c11.8 22 15.2 47.6 9.4 72-9.2 39-40.6 68.8-79.7 76.5-32.1 6.3-83.1-5.1-91.8-59.2zM128 208H88.2c-8.9 0-16.2-7.3-16.2-16.2v-39.6c0-8.9 7.3-16.2 16.2-16.2H128c8.9 0 16.2 7.3 16.2 16.2v39.6c0 8.9-7.3 16.2-16.2 16.2zM10.1 168C4.5 168 0 163.5 0 157.9v-27.8c0-5.6 4.5-10.1 10.1-10.1h27.7c5.5 0 10.1 4.5 10.1 10.1v27.8c0 5.6-4.5 10.1-10.1 10.1H10.1zM168 142.7v-21.4c0-5.1 4.2-9.3 9.3-9.3h21.4c5.1 0 9.3 4.2 9.3 9.3v21.4c0 5.1-4.2 9.3-9.3 9.3h-21.4c-5.1 0-9.3-4.2-9.3-9.3zM56 235.5v25c0 6.3-5.1 11.5-11.4 11.5H19.4C13.1 272 8 266.8 8 260.5v-25c0-6.3 5.1-11.5 11.4-11.5h25.1c6.4 0 11.5 5.2 11.5 11.5z\"/></svg>'>\n    </md-icon>\n    <span>Cloud</span>\n    <div class=\"button-ripple\"></div>\n</button>\n\n<script>\n    (function(scope) {\n        scope.GetIconColor = function(){return \"white\"}\n        scope.OnButtonClick = function(evt){\n            switch(evt.currentTarget.id){\n                case \"cloudbutton\":\n                    //alert(evt.currentTarget.id);\n                    scope.send({payload: \"Cloud Button clicked\"});\n                    break;\n                default:\n                    //console.log(evt.currentTarget.id);\n                    break;\n            }\n        }\n        scope.$watch('msg', function(msg) {\n            \n        });\n    })(scope);\n</script>",
        "templateScope": "local",
        "className": "nr-dashboard-button _md styled-button styled-template",
        "x": 1240,
        "y": 640,
        "id": "d921e9fe7b208126",
        "type": "ui_group",
        "name": "Buttons",
        "tab": "d0d82445ef65a632",
        "order": 1,
        "disp": true,
        "width": "6",
        "collapse": false,
        "className": ""
        "id": "c3bc11b854faa005",
        "type": "ui_group",
        "name": "Channel 1",
        "tab": "",
        "order": 1,
        "disp": true,
        "width": "13",
        "collapse": false,
        "className": ""
        "id": "d0d82445ef65a632",
        "type": "ui_tab",
        "name": "ButtonDesign",
        "icon": "dashboard",
        "order": 3,
        "disabled": false,
        "hidden": false
the third button (ui-template-node) with circular ripple effect:
        "id": "67e5a02dc04c0c98",
        "name": "button 3",
        "order": 3,
        "width": "2",
        "height": "2",
        "format": "<style>\n    #cloudbutton{\n        color:white!important;\n    }\n    .s36{\n        display:block;\n        vertical-align:unset;\n        width: 36px;\n        height: 36px;\n        filter:saturate(0.0) brightness(3.0) !important;\n    }\n    \n    .s36 md-icon{\n       \n    }\n</style>\n<button id=\"cloudbutton\" class=\"md-raised md-button md-ink-ripple\" type=\"button\" ng-click=\"OnButtonClick($event)\" aria-label=\"cloudbutton\">\n    <md-icon  class=\"s36\" md-svg-src='data:image/svg+xml;utf8,<svg xmlns=\"http://www.w3.org/2000/svg\" viewBox=\"0 0 616 512\"><path d=\"M148.6 304c8.2 68.5 67.4 115.5 146 111.3 51.2 43.3 136.8 45.8 186.4-5.6 69.2 1.1 118.5-44.6 131.5-99.5 14.8-62.5-18.2-132.5-92.1-155.1-33-88.1-131.4-101.5-186.5-85-57.3 17.3-84.3 53.2-99.3 109.7-7.8 2.7-26.5 8.9-45 24.1 11.7 0 15.2 8.9 15.2 19.5v20.4c0 10.7-8.7 19.5-19.5 19.5h-20.2c-10.7 0-19.5-6-19.5-16.7V240H98.8C95 240 88 244.3 88 251.9v40.4c0 6.4 5.3 11.8 11.7 11.8h48.9zm227.4 8c-10.7 46.3 21.7 72.4 55.3 86.8C324.1 432.6 259.7 348 296 288c-33.2 21.6-33.7 71.2-29.2 92.9-17.9-12.4-53.8-32.4-57.4-79.8-3-39.9 21.5-75.7 57-93.9C297 191.4 369.9 198.7 400 248c-14.1-48-53.8-70.1-101.8-74.8 30.9-30.7 64.4-50.3 114.2-43.7 69.8 9.3 133.2 82.8 67.7 150.5 35-16.3 48.7-54.4 47.5-76.9l10.5 19.6c11.8 22 15.2 47.6 9.4 72-9.2 39-40.6 68.8-79.7 76.5-32.1 6.3-83.1-5.1-91.8-59.2zM128 208H88.2c-8.9 0-16.2-7.3-16.2-16.2v-39.6c0-8.9 7.3-16.2 16.2-16.2H128c8.9 0 16.2 7.3 16.2 16.2v39.6c0 8.9-7.3 16.2-16.2 16.2zM10.1 168C4.5 168 0 163.5 0 157.9v-27.8c0-5.6 4.5-10.1 10.1-10.1h27.7c5.5 0 10.1 4.5 10.1 10.1v27.8c0 5.6-4.5 10.1-10.1 10.1H10.1zM168 142.7v-21.4c0-5.1 4.2-9.3 9.3-9.3h21.4c5.1 0 9.3 4.2 9.3 9.3v21.4c0 5.1-4.2 9.3-9.3 9.3h-21.4c-5.1 0-9.3-4.2-9.3-9.3zM56 235.5v25c0 6.3-5.1 11.5-11.4 11.5H19.4C13.1 272 8 266.8 8 260.5v-25c0-6.3 5.1-11.5 11.4-11.5h25.1c6.4 0 11.5 5.2 11.5 11.5z\"/></svg>'>\n    </md-icon>\n    <span>Cloud</span>\n</button>\n\n<script>\n    (function(scope) {\n        scope.InjectRipple = function() {\n           const injector = angular.element('#cloudbutton').injector();\n           injector.invoke(scope.AttachCloudbuttonToRipple,null,null);\n        };\n        scope.AttachCloudbuttonToRipple = function($mdInkRipple){\n            $mdInkRipple.attach(scope, angular.element('#cloudbutton'), { center: false });\n        }\n        scope.OnButtonClick = function(evt){\n            switch(evt.currentTarget.id){\n                case \"cloudbutton\":\n                    scope.send({payload: \"Cloud Button clicked\"});\n                    break;\n                default:\n                    break;\n            }\n        }\n        scope.InjectRipple();\n        \n        scope.$watch('msg', function(msg) {\n            \n        });\n    })(scope);\n</script>",
        "x": 500,
        "y": 520,
                "ef7b488547d946e5"
        "type": "ui_group",
        "name": "Buttons",
        "order": 1,
        "disp": true,
        "width": "6",
        "collapse": false,
        "className": ""
        "type": "ui_tab",
        "order": 3,
        "disabled": false,
        "hidden": false
