Is the old dashboard included by default with Node-Red?
This does not make sense to my brain
You have to install a dashboard - it is not bundled-in during a Node-RED install.
You are correct in your statement - Dashboard 1 is deprecated.
Dashboard-2 is available here
Note: Both dashboards can co-exist happily together (whilst people make the transition).
Note: I have no idea what those 'stats' mean in this situation.
So more users are installing the old deprecated no longer supported dashboard than the shiny new supported dashboard 2 unless those download figures are
Recently there was a posting from SmithTek about their SCADA 3DM node that makes creating a floating visually attractive dashboard very easy.
I used their node to try it out on my home network.
Looking at NPM, please note that this page is not updated in real time. It is only maintained until the new version is released.
The current weekly data can be found here:
@flowfuse/node-red-dashboard - npm
Dashboard 1 is running on the old Angular version, while Dashboard 2 has already been build on Vue.
Dashboard 1 on npm
I've seen those NPM stats. I'm just thinking it's odd that if you search for node-red-dashboard on the nodered site you have to go to page 4 of 6 before you find it and it's clearly marked
whereas the flowfuse dashboard is the first node in the search results. so either those download stats are rubbish or users are still downloading the old dashboard. Myself, I migrated to the new dashboard many months ago. It's just an observation really. And I believe dashboard 2 is built on vue.js ![]()
Right, it’s on Vue. Sorry
I noticed that a few weeks back.
The consensus was:
By the way, these numbers are far higher than actual installations. I think this is another fallout from AI use and possibly more cloud-based CI use as well. I suspect that some AI's grab another copy of the source when they are trying to answer some questions.
Both of your assumptions are correct. People ARE still downloading the old version since it is simpler and it does work - though obviously not being actively updated any more. However, the absolute numbers are rubbish now. They are massively inflated all round, as JBudd says, most likely due to AI downloads.
If we are going to mention other alternatives, lets not forget that UIBUILDER has been in active and stable development for over a decade. It does not have any front-end framework dependencies unlike the Dashboards (though, of course, you can add them if you like). You can use general web development tools to design and build interfaces then integrate to Node-RED using the UIBUILDER interface.
Dashboard 1 user for life here. Much better in my opinion…
But please make sure that you do not expose a D1 Dashboard to the Internet or low-security environments. It is no longer being actively maintained and so cannot be guaranteed not to have issues.
Another Dashboard 1 user here back from earliest NR days. I have some 7 dash pages working happily so it is easier just to tweak it. Also use several user contrib dashboard 1 nodes for which I haven't seen a dash 2 equivalent.
As result will stick to dash 1 for the time being, until I find some time and mental capacity to come up to speed and put effort into making transition.
So glad it is a add on I choose to use and it remains available for many years. Happy it is depreciated so no long is being developed, so your energies can focus on dash2.
Oneday there will be a dash 2 feature I want, and I will find time to make the move.
What might help, is a hybrid, where the das menu, could take a dash 1 or dash 2 page, then one cou,d transition a page at a time.
Thanks to the developers of both.
Which ones are missing?
Note that you can install both at once, though you can't mix pages from one in the other, except, I suppose, by using iframes.
This is the other ui nodes I used, I have not checked recently if a DB2 version or similar is now available, just know in the early days of DB2 that some of these were not supported.
node-red-contrib-ui-state-trail
node-red-node-ui-table
node-red-contrib-ui-multistate-switch
node-red-contrib-ui-led
But at this time the biggest constraint in transition to DB2 is time, and mental capacity to get my head around how DB2 does things. would love a good tutorial. Did try the automated migration (back in early days of DB2, but it just made a mess and left me to sort the more difficult parts!)
So one day I will switch, in the meantime I appreciate the original DB remains and is compatible with latest NR versions.
I am not certain, but possibly node-red-dashboard-2-ui-state-timeline (node) - Node-RED will do what you want
There is a table node built in, and also node-red-dashboard-2-table-tabulator (node) - Node-RED if you need additional features
The builtin button-group node
Might be a good idea to have a comparison table in the D2 docs?
node-red-contrib-ui-time-scheduler available in D1 is missing in D2.
The main reason I stick to D1.
You can achieve something similar (or better) in Dashboard 2 - with a little vue work and cron-plus!
This could also probably be made into a subflow if you wanted multiple schedules on one dashboard page (bit more work)
[{"id":"795366fbdbd28961","type":"inject","z":"7f5380ac4139f5dc","name":"Load saved schedules","props":[{"p":"payload","v":"","vt":"str"},{"p":"topic","v":"scheduler/load","vt":"str"}],"repeat":"","crontab":"","once":true,"onceDelay":0.2,"topic":"","payload":"","payloadType":"date","x":200,"y":220,"wires":[["312c5804d05e0e59"]]},{"id":"9aebfa031e7faa3c","type":"function","z":"7f5380ac4139f5dc","name":"Load and sync schedules from flow context","func":"const SCHEDULE_STORE_NAME = env.get('SCHEDULE_STORE_NAME') || 'memory'\nconst SCHEDULE_STORE_KEY = env.get('SCHEDULE_STORE_KEY') || 'scheduler'\nconst storedSchedules = flow.get(`${SCHEDULE_STORE_KEY}.schedules`, SCHEDULE_STORE_NAME) || []\nconst schedules = Array.isArray(storedSchedules)\n ? storedSchedules.map(({ timezone, ...schedule }) => schedule)\n : []\n\nconst stateMsg = { ...msg, topic: 'scheduler/state', payload: schedules }\nconst syncMsg = { ...msg, topic: 'scheduler/change', payload: schedules }\nreturn [stateMsg, syncMsg];","outputs":2,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":270,"y":340,"wires":[["1eaebae768e4cd80"],["38f0e17bcc28d077"]]},{"id":"1eaebae768e4cd80","type":"ui-template","z":"7f5380ac4139f5dc","group":"5014dff1900520a3","page":"","ui":"","name":"Scheduler Manager","order":0,"width":12,"height":0,"head":"","format":"<template>\n <v-card class=\"scheduler-card\" variant=\"flat\">\n <v-card-title class=\"d-flex align-center justify-space-between\">\n <div>\n <div class=\"text-h6\">Schedule manager</div>\n <div class=\"text-caption text-medium-emphasis\">\n Named windows and solar/lunar events\n </div>\n </div>\n\n <v-btn\n color=\"primary\"\n prepend-icon=\"mdi-plus\"\n @click=\"newSchedule\"\n >\n Schedule\n </v-btn>\n </v-card-title>\n\n <v-divider></v-divider>\n\n <v-card-text class=\"scheduler-body\">\n <v-snackbar\n v-model=\"showStatus\"\n location=\"top\"\n :timeout=\"10000\"\n :color=\"statusType\"\n >\n <div class=\"d-flex align-center ga-3\">\n <v-icon :icon=\"statusIcon\"></v-icon>\n <span>{{ status }}</span>\n </div>\n\n <template #actions>\n <v-btn\n icon=\"mdi-close\"\n variant=\"text\"\n size=\"small\"\n @click=\"status = ''\"\n ></v-btn>\n </template>\n </v-snackbar>\n\n <v-row class=\"scheduler-row\">\n <!-- Schedule list -->\n <v-col\n cols=\"12\"\n md=\"4\"\n class=\"schedule-list\"\n >\n <v-list\n class=\"schedule-list\"\n lines=\"two\"\n >\n <v-list-subheader>Schedules</v-list-subheader>\n\n <v-list-item\n v-for=\"schedule in schedules\"\n :key=\"schedule.id\"\n :active=\"schedule.id === selectedId\"\n rounded=\"lg\"\n @click=\"selectedId = schedule.id\"\n >\n <template #prepend>\n <v-avatar\n :color=\"schedule.enabled ? 'primary' : 'grey'\"\n size=\"34\"\n >\n <v-icon>\n {{ schedule.enabled ? 'mdi-calendar-clock' : 'mdi-calendar-remove' }}\n </v-icon>\n </v-avatar>\n </template>\n\n <v-list-item-title>\n {{ schedule.name }}\n </v-list-item-title>\n\n <v-list-item-subtitle>\n {{ schedule.rules.length }}\n rule{{ schedule.rules.length === 1 ? '' : 's' }}\n </v-list-item-subtitle>\n\n <template #append>\n <v-switch\n v-model=\"schedule.enabled\"\n color=\"primary\"\n hide-details\n density=\"compact\"\n @click.stop\n @update:model-value=\"emitState\"\n ></v-switch>\n </template>\n </v-list-item>\n\n <v-list-item\n v-if=\"!schedules.length\"\n class=\"text-medium-emphasis\"\n >\n No schedules configured.\n </v-list-item>\n </v-list>\n </v-col>\n\n <!-- Selected schedule -->\n <v-col\n cols=\"12\"\n md=\"8\"\n class=\"selected-schedule\"\n >\n <template v-if=\"selected\">\n <div class=\"d-flex align-center justify-space-between mb-3\">\n <div>\n <div class=\"text-h6\">\n {{ selected.name }}\n </div>\n\n <div class=\"text-caption text-medium-emphasis\">\n {{ selected.description || 'No description' }}\n </div>\n </div>\n\n <div>\n <v-btn\n icon=\"mdi-pencil\"\n variant=\"text\"\n @click=\"editSchedule(selected)\"\n ></v-btn>\n\n <v-btn\n icon=\"mdi-delete-outline\"\n color=\"error\"\n variant=\"text\"\n @click=\"removeSchedule(selected.id)\"\n ></v-btn>\n </div>\n </div>\n\n <!-- Schedule status -->\n <v-card\n variant=\"tonal\"\n class=\"mb-4\"\n >\n <v-card-text class=\"d-flex flex-wrap ga-2\">\n <v-chip\n size=\"small\"\n :color=\"selected.enabled ? 'success' : 'grey'\"\n >\n {{ selected.enabled ? 'Enabled' : 'Disabled' }}\n </v-chip>\n\n <v-chip size=\"small\">\n {{ selected.rules.length }} rules\n </v-chip>\n </v-card-text>\n </v-card>\n\n <!-- Rules heading -->\n <div class=\"d-flex align-center justify-space-between mb-2\">\n <div class=\"text-subtitle-1\">Rules</div>\n\n <v-btn\n size=\"small\"\n variant=\"tonal\"\n prepend-icon=\"mdi-plus\"\n @click=\"newRule\"\n >\n Add rule\n </v-btn>\n </div>\n\n <!-- Rules -->\n <v-card\n v-for=\"rule in selected.rules\"\n :key=\"rule.id\"\n variant=\"outlined\"\n class=\"rule-card mb-3\"\n :class=\"{ 'rule-card--disabled': !rule.enabled }\"\n >\n <v-card-text>\n <div class=\"d-flex justify-space-between\">\n <div>\n <div class=\"d-flex align-center ga-2\">\n <span class=\"font-weight-medium\">\n {{ rule.name }}\n </span>\n\n <v-chip\n v-if=\"!rule.enabled\"\n size=\"x-small\"\n color=\"grey\"\n variant=\"flat\"\n >\n Disabled\n </v-chip>\n </div>\n\n <div class=\"text-body-2 text-medium-emphasis\">\n {{ summary(rule) }}\n </div>\n </div>\n\n <div>\n <v-btn\n icon=\"mdi-pencil-outline\"\n size=\"small\"\n variant=\"text\"\n @click=\"editRule(rule)\"\n ></v-btn>\n\n <v-btn\n icon=\"mdi-delete-outline\"\n size=\"small\"\n color=\"error\"\n variant=\"text\"\n @click=\"removeRule(rule.id)\"\n ></v-btn>\n </div>\n </div>\n\n <div class=\"d-flex align-center justify-space-between mt-3\">\n <div class=\"d-flex flex-wrap ga-1\">\n <v-chip\n v-for=\"day in rule.days\"\n :key=\"day\"\n size=\"x-small\"\n :color=\"rule.enabled ? 'primary' : 'grey'\"\n variant=\"tonal\"\n >\n {{ dayLabel(day) }}\n </v-chip>\n </div>\n\n <v-switch\n v-model=\"rule.enabled\"\n class=\"rule-toggle\"\n color=\"primary\"\n hide-details\n density=\"compact\"\n @update:model-value=\"emitState\"\n ></v-switch>\n </div>\n </v-card-text>\n </v-card>\n\n <v-alert\n v-if=\"!selected.rules.length\"\n type=\"info\"\n variant=\"tonal\"\n >\n Add a rule to define the active window.\n </v-alert>\n </template>\n\n <v-alert\n v-else\n type=\"info\"\n variant=\"tonal\"\n >\n Create or select a schedule to begin.\n </v-alert>\n </v-col>\n </v-row>\n </v-card-text>\n </v-card>\n\n <!-- Schedule dialog -->\n <v-dialog\n v-model=\"scheduleDialog\"\n max-width=\"520\"\n >\n <v-card>\n <v-card-title>\n {{ editingSchedule ? 'Edit schedule' : 'New schedule' }}\n </v-card-title>\n\n <v-card-text>\n <v-text-field\n v-model=\"scheduleForm.name\"\n label=\"Schedule name\"\n autofocus\n ></v-text-field>\n\n <v-textarea\n v-model=\"scheduleForm.description\"\n label=\"Description\"\n rows=\"2\"\n ></v-textarea>\n\n <v-switch\n v-model=\"scheduleForm.enabled\"\n label=\"Schedule enabled\"\n color=\"primary\"\n ></v-switch>\n </v-card-text>\n\n <v-card-actions>\n <v-spacer></v-spacer>\n\n <v-btn\n variant=\"text\"\n @click=\"scheduleDialog = false\"\n >\n Cancel\n </v-btn>\n\n <v-btn\n color=\"primary\"\n type=\"button\"\n @click.stop.prevent=\"saveSchedule()\"\n >\n Save\n </v-btn>\n </v-card-actions>\n </v-card>\n </v-dialog>\n\n <!-- Rule dialog -->\n <v-dialog\n v-model=\"ruleDialog\"\n max-width=\"620\"\n >\n <v-card>\n <v-card-title>\n {{ editingRule ? 'Edit rule' : 'New rule' }}\n </v-card-title>\n\n <v-card-text>\n <v-text-field\n v-model=\"ruleForm.name\"\n label=\"Rule name\"\n ></v-text-field>\n\n <!-- Days -->\n <div class=\"text-subtitle-2 mb-2\">\n Days\n </div>\n\n <div class=\"d-flex flex-wrap ga-2 mb-4\">\n <v-chip\n v-for=\"day in dayOptions\"\n :key=\"day.value\"\n :color=\"ruleForm.days.includes(day.value) ? 'primary' : undefined\"\n :variant=\"ruleForm.days.includes(day.value) ? 'flat' : 'outlined'\"\n @click=\"toggleDay(day.value)\"\n >\n {{ day.label }}\n </v-chip>\n </div>\n\n <!-- Start event -->\n <v-select\n v-model=\"ruleForm.start.kind\"\n label=\"Start event\"\n :items=\"eventItems\"\n item-title=\"label\"\n item-value=\"value\"\n ></v-select>\n\n <v-text-field\n v-if=\"ruleForm.start.kind === 'fixed'\"\n v-model=\"ruleForm.start.time\"\n label=\"Start time\"\n type=\"time\"\n ></v-text-field>\n\n <v-text-field\n v-else\n v-model.number=\"ruleForm.start.offsetMinutes\"\n label=\"Start offset, minutes\"\n type=\"number\"\n ></v-text-field>\n\n <!-- End event -->\n <v-select\n v-model=\"ruleForm.end.kind\"\n label=\"End event\"\n :items=\"eventItems\"\n item-title=\"label\"\n item-value=\"value\"\n ></v-select>\n\n <v-text-field\n v-if=\"ruleForm.end.kind === 'fixed'\"\n v-model=\"ruleForm.end.time\"\n label=\"End time\"\n type=\"time\"\n ></v-text-field>\n\n <v-text-field\n v-else\n v-model.number=\"ruleForm.end.offsetMinutes\"\n label=\"End offset, minutes\"\n type=\"number\"\n ></v-text-field>\n\n <v-switch\n v-model=\"ruleForm.enabled\"\n label=\"Rule enabled\"\n color=\"primary\"\n ></v-switch>\n </v-card-text>\n\n <v-card-actions>\n <v-spacer></v-spacer>\n\n <v-btn\n variant=\"text\"\n @click=\"ruleDialog = false\"\n >\n Cancel\n </v-btn>\n\n <v-btn\n color=\"primary\"\n @click=\"saveRule()\"\n >\n Save rule\n </v-btn>\n </v-card-actions>\n </v-card>\n </v-dialog>\n</template>\n\n<script>\nexport default {\n data() {\n return {\n schedules: [],\n selectedId: null,\n status: '',\n statusType: 'info',\n scheduleDialog: false,\n ruleDialog: false,\n editingSchedule: false,\n editingRule: false,\n\n scheduleForm: {\n id: '',\n name: '',\n description: '',\n enabled: true,\n rules: []\n },\n\n ruleForm: {\n id: '',\n name: '',\n enabled: true,\n days: [1, 2, 3, 4, 5],\n start: {\n kind: 'fixed',\n time: '08:00',\n offsetMinutes: 0\n },\n end: {\n kind: 'fixed',\n time: '17:00',\n offsetMinutes: 0\n }\n },\n\n dayOptions: [\n { label: 'Mon', value: 1 },\n { label: 'Tue', value: 2 },\n { label: 'Wed', value: 3 },\n { label: 'Thu', value: 4 },\n { label: 'Fri', value: 5 },\n { label: 'Sat', value: 6 },\n { label: 'Sun', value: 0 }\n ],\n\n eventItems: [\n { label: 'Fixed time', value: 'fixed' },\n { label: 'Sunrise', value: 'sunrise' },\n { label: 'Sunset', value: 'sunset' },\n { label: 'Moonrise', value: 'moonrise' },\n { label: 'Moonset', value: 'moonset' }\n ]\n }\n },\n\n computed: {\n selected() {\n return this.schedules.find(item => item.id === this.selectedId) || null\n },\n\n showStatus: {\n get() {\n return !!this.status\n },\n\n set(value) {\n if (!value) this.status = ''\n }\n },\n\n statusIcon() {\n return {\n error: 'mdi-close-circle',\n warning: 'mdi-alert',\n success: 'mdi-check-circle'\n }[this.statusType] || 'mdi-information'\n }\n },\n\n watch: {\n msg: {\n immediate: true,\n deep: true,\n\n handler(msg) {\n if (Array.isArray(msg?.payload)) {\n this.schedules = this.clone(msg.payload)\n\n if (!this.selected) {\n this.selectedId = this.schedules[0]?.id || null\n }\n }\n }\n }\n },\n\n methods: {\n clone(value) {\n return JSON.parse(JSON.stringify(value))\n },\n\n newId() {\n return `${Date.now()}-${Math.random().toString(36).slice(2)}`\n },\n\n nextName(prefix, items) {\n const taken = new Set(\n items.map(item => String(item.name || '').trim().toLowerCase())\n )\n\n let n = items.length + 1\n\n while (taken.has(`${prefix} ${n}`.toLowerCase())) {\n n++\n }\n\n return `${prefix} ${n}`\n },\n\n newSchedule() {\n this.editingSchedule = false\n\n this.scheduleForm = {\n id: this.newId(),\n name: this.nextName('Schedule', this.schedules),\n description: '',\n enabled: true,\n rules: []\n }\n\n this.scheduleDialog = true\n },\n\n editSchedule(schedule) {\n this.editingSchedule = true\n this.scheduleForm = this.clone(schedule)\n this.scheduleDialog = true\n },\n\n saveSchedule() {\n const name = String(this.scheduleForm.name || '').trim()\n || this.nextName('Schedule', this.schedules)\n\n const duplicate = this.schedules.some(item =>\n item.id !== this.scheduleForm.id &&\n String(item.name || '').trim().toLowerCase() === name.toLowerCase()\n )\n\n if (duplicate) {\n this.statusType = 'error'\n this.status = `A schedule named \"${name}\" already exists.`\n return\n }\n\n const saved = this.clone(this.scheduleForm)\n saved.name = name\n\n const index = this.schedules.findIndex(item => item.id === saved.id)\n\n if (index < 0) {\n this.schedules.push(saved)\n } else {\n this.schedules[index] = saved\n }\n\n this.selectedId = saved.id\n this.scheduleDialog = false\n this.emitState()\n },\n\n removeSchedule(id) {\n this.schedules = this.schedules.filter(item => item.id !== id)\n this.selectedId = this.schedules[0]?.id || null\n this.emitState()\n },\n\n newRule() {\n if (!this.selected) return\n\n this.editingRule = false\n\n this.ruleForm = {\n id: this.newId(),\n name: this.nextName('Rule', this.selected.rules),\n enabled: true,\n days: [1, 2, 3, 4, 5],\n start: {\n kind: 'fixed',\n time: '08:00',\n offsetMinutes: 0\n },\n end: {\n kind: 'fixed',\n time: '17:00',\n offsetMinutes: 0\n }\n }\n\n this.ruleDialog = true\n },\n\n editRule(rule) {\n this.editingRule = true\n this.ruleForm = this.clone(rule)\n this.ruleDialog = true\n },\n\n saveRule() {\n if (!this.selected) return\n\n const name = String(this.ruleForm.name || '').trim()\n || this.nextName('Rule', this.selected.rules)\n\n const duplicate = this.selected.rules.some(item =>\n item.id !== this.ruleForm.id &&\n String(item.name || '').trim().toLowerCase() === name.toLowerCase()\n )\n\n if (duplicate) {\n this.statusType = 'error'\n this.status = `A rule named \"${name}\" already exists in this schedule.`\n return\n }\n\n const saved = this.clone(this.ruleForm)\n saved.name = name\n\n const index = this.selected.rules.findIndex(item => item.id === saved.id)\n\n if (index < 0) {\n this.selected.rules.push(saved)\n } else {\n this.selected.rules[index] = saved\n }\n\n this.ruleDialog = false\n this.emitState()\n },\n\n removeRule(id) {\n if (!this.selected) return\n\n this.selected.rules = this.selected.rules.filter(item => item.id !== id)\n this.emitState()\n },\n\n toggleDay(day) {\n this.ruleForm.days = this.ruleForm.days.includes(day)\n ? this.ruleForm.days.filter(value => value !== day)\n : [...this.ruleForm.days, day].sort((a, b) => a - b)\n },\n\n emitState() {\n const scheduleNames = new Set()\n\n for (const schedule of this.schedules) {\n const scheduleKey = String(schedule.name || '').trim().toLowerCase()\n\n if (scheduleKey && scheduleNames.has(scheduleKey)) {\n this.statusType = 'error'\n this.status = `Duplicate schedule name: ${String(schedule.name || '').trim()}`\n return\n }\n\n scheduleNames.add(scheduleKey)\n\n const ruleNames = new Set()\n\n for (const rule of (schedule.rules || [])) {\n const ruleKey = String(rule.name || '').trim().toLowerCase()\n\n if (ruleKey && ruleNames.has(ruleKey)) {\n this.statusType = 'error'\n this.status = `Duplicate rule name in ${String(schedule.name || '').trim()}: ${String(rule.name || '').trim()}`\n return\n }\n\n ruleNames.add(ruleKey)\n }\n }\n\n this.status = ''\n\n this.send({\n topic: 'scheduler/change',\n payload: this.clone(this.schedules)\n })\n },\n\n dayLabel(day) {\n return this.dayOptions.find(item => item.value === day)?.label || String(day)\n },\n\n summary(rule) {\n const format = event => {\n return event.kind === 'fixed'\n ? (event.time || '--:--')\n : event.kind + (\n Number(event.offsetMinutes || 0)\n ? ` ${Number(event.offsetMinutes) > 0 ? '+' : ''}${event.offsetMinutes}m`\n : ''\n )\n }\n\n return `${format(rule.start)} → ${format(rule.end)}`\n }\n }\n}\n</script>\n\n<style scoped>\n.scheduler-card {\n grid-row: 1 / -1;\n align-self: start;\n min-height: 100%;\n}\n\n.schedule-list {\n background: transparent;\n}\n\n.v-row.scheduler-row {\n align-content: flex-start;\n}\n\n.rule-card {\n border-radius: 12px;\n}\n\n.rule-card--disabled {\n opacity: 0.6;\n border-style: dashed;\n}\n\n.rule-toggle {\n flex: 0 0 auto;\n}\n</style>","storeOutMessages":true,"passthru":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":570,"y":300,"wires":[["38f0e17bcc28d077"]]},{"id":"38f0e17bcc28d077","type":"function","z":"7f5380ac4139f5dc","name":"Save and reconcile schedules","func":"const SCHEDULE_STORE_NAME = env.get('SCHEDULE_STORE_NAME') || 'memory'\nconst SCHEDULE_STORE_KEY = env.get('SCHEDULE_STORE_KEY') || 'scheduler'\n\nif (msg.topic !== 'scheduler/change' || !Array.isArray(msg.payload)) return null\n\nconst schedules = msg.payload.map(({ timezone, ...schedule }) => schedule)\nconst scheduleNames = new Set()\nfor (const schedule of schedules) {\n const scheduleName = String(schedule?.name || '').trim()\n if (!scheduleName) continue\n const scheduleKey = scheduleName.toLowerCase()\n if (scheduleNames.has(scheduleKey)) return null\n scheduleNames.add(scheduleKey)\n\n const ruleNames = new Set()\n for (const rule of Array.isArray(schedule.rules) ? schedule.rules : []) {\n const ruleName = String(rule?.name || '').trim()\n if (!ruleName) continue\n const ruleKey = ruleName.toLowerCase()\n if (ruleNames.has(ruleKey)) return null\n ruleNames.add(ruleKey)\n }\n}\n\nflow.set(`${SCHEDULE_STORE_KEY}.schedules`, schedules, SCHEDULE_STORE_NAME)\n\n// Dashboard day values are 1=Monday through 7=Sunday.\nconst dayNames = ['SUN', 'MON', 'TUE', 'WED', 'THU', 'FRI', 'SAT']\nconst cronForFixed = (event, days) => {\n const [hour, minute] = String(event?.time || '00:00').split(':').map(Number)\n const selectedDays = Array.isArray(days) && days.length\n ? days.map(day => dayNames[Number(day)] || dayNames[Number(day) % 7]).join(',')\n : '*'\n return `0 ${Number.isFinite(minute) ? minute : 0} ${Number.isFinite(hour) ? hour : 0} * * ${selectedDays}`\n}\n\nconst commands = [{ command: 'remove-all-dynamic' }]\n\nfor (const schedule of schedules) {\n if (!schedule?.enabled || !Array.isArray(schedule.rules)) continue\n for (const rule of schedule.rules) {\n if (!rule?.enabled) continue\n const scheduleName = String(schedule.name || '').trim()\n const ruleName = String(rule.name || '').trim()\n if (!scheduleName || !ruleName) continue\n\n const event = rule.start || rule.event || {}\n const command = {\n command: 'add',\n name: `${scheduleName}:${ruleName}`,\n topic: `${scheduleName}:${ruleName}`,\n payloadType: 'default'\n }\n\n if (event.kind === 'solar') {\n command.expressionType = 'solar'\n command.solarType = event.solarType || 'selected'\n command.solarEvents = event.solarEvents || event.events || 'sunrise,sunset'\n command.location = event.location || schedule.location\n command.offset = Number(event.offsetMinutes || event.offset || 0)\n } else if (event.kind === 'lunar') {\n command.expressionType = 'lunar'\n command.lunarType = event.lunarType || 'selected'\n command.lunarEvents = event.lunarEvents || event.events || 'rise,set'\n command.location = event.location || schedule.location\n command.offset = Number(event.offsetMinutes || event.offset || 0)\n } else {\n command.expressionType = 'cron'\n command.expression = cronForFixed(event, rule.days)\n }\n commands.push(command)\n }\n}\n\nmsg.topic = ''\nmsg.payload = commands\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":850,"y":340,"wires":[["5b52acefd64d1624"]]},{"id":"5b52acefd64d1624","type":"cronplus","z":"7f5380ac4139f5dc","name":"","outputField":"payload","timeZone":"","storeName":"","commandResponseMsgOutput":"output2","defaultLocation":"54.906619584490926 -0.87890625","defaultLocationType":"fixed","outputs":2,"options":[],"x":520,"y":480,"wires":[["870a95c6b9f72c59"],["c0108b937810343a"]]},{"id":"870a95c6b9f72c59","type":"debug","z":"7f5380ac4139f5dc","name":"Schedule Triggered --> do something","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":950,"y":460,"wires":[]},{"id":"c0108b937810343a","type":"debug","z":"7f5380ac4139f5dc","name":"Command result","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":880,"y":500,"wires":[]},{"id":"5df88676dad45a98","type":"ui-control","z":"7f5380ac4139f5dc","name":"","ui":"7d1cf88ae6633d29","events":"all","x":240,"y":260,"wires":[["312c5804d05e0e59"]]},{"id":"0b34021d7c42c0d7","type":"inject","z":"7f5380ac4139f5dc","name":"","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"status-all","x":300,"y":480,"wires":[["5b52acefd64d1624"]]},{"id":"312c5804d05e0e59","type":"junction","z":"7f5380ac4139f5dc","x":340,"y":240,"wires":[["9aebfa031e7faa3c"]]},{"id":"5014dff1900520a3","type":"ui-group","name":"Schedule Manager","page":"c8328d009d4025df","width":12,"height":8,"order":0,"showTitle":false,"className":"","visible":true,"disabled":false,"groupType":"default","tab":""},{"id":"7d1cf88ae6633d29","type":"ui-base","name":"Scheduler Dashboard","path":"/dashboard","appIcon":"","includeClientData":true,"acceptsClientConfig":["ui-notification","ui-control"],"showPathInSidebar":true,"headerContent":"page","navigationStyle":"default","titleBarStyle":"default","showReconnectNotification":true,"notificationDisplayTime":1,"showDisconnectNotification":true,"allowInstall":false},{"id":"c8328d009d4025df","type":"ui-page","name":"Scheduler","ui":"7d1cf88ae6633d29","path":"/scheduler","icon":"calendar-clock","layout":"grid","theme":"5b7e0fda452f3f96","breakpoints":[{"name":"Default","px":0,"cols":3},{"name":"Tablet","px":576,"cols":6},{"name":"Small Desktop","px":768,"cols":9},{"name":"Desktop","px":1024,"cols":12}],"tabs":[],"order":0,"className":"","visible":"true","disabled":"false"},{"id":"5b7e0fda452f3f96","type":"ui-theme","name":"Scheduler Theme","colors":{"surface":"#ffffff","primary":"#4568dc","bgPage":"#f5f7fb","groupBg":"#ffffff","groupOutline":"#e5e7eb"},"sizes":{"density":"default","pagePadding":"16px","groupGap":"16px","groupBorderRadius":"12px","widgetGap":"12px"}},{"id":"2a9b15ef21053d6c","type":"global-config","env":[],"modules":{"@flowfuse/node-red-dashboard":"1.33.0","node-red-contrib-cron-plus":"3.2.0"}}]
Ditto, especially since D2 doesn't work in Firefox.
