Dashboard 2.0 Chart - Remove dots on lines?
Is it possible to remove the dots on the line chart? I have a chart with a couple of hundred points and the effect on a small display is just a thick line as the dots merge together. D1 chart provided this via the Enlarge Points checkbox, which does not appear to be mentioned in the Migration Guide.
Not currently, and thanks for checking the migration guide. Not sure how I missed that in writing the guide. Could I trouble you to open an issue on the GH Repo please?
Done Add option to remove dots on line chart · Issue #447 · FlowFuse/node-red-dashboard · GitHub
