Dashboard 2.0: Drop down highlight color changeable?
Hi folks,
I'm wondering if it is possible to change the highlight color of the search fonction using CSS. I can't figure witch class i should play with.
Any one have an idea about that ?
thank !
You should be able to use the browser developer tool to inspect the dropdown element and corresponding css.
I have a distant memory this was raised and fixed some time back. What version are you on?
Maybe not - doesn't look like the op bothered to raise an issue.
There is a workaround in this thread: Dropdown search string color theme
many thanks, it worked perfectly, I coudn't use the browser inspect function because it keep closing the dropdown ahah.
