Dashboard 2.0 - format table
I want to reduce the height of the rows in a table to have a more compact view of the table.
The table has 12 rows so it covers more than a 13" screen
I've tired using a template node with the following code
<template>
    <v-table density="compact">
    </v-table>
</template>
<style>
    .v-table {
        border-collapse: collapse;
        font-family: Arial, sans-serif;
    .v-table th {
        background-color: #4CAF50;
        color: white !important;
        font-weight: bold;
</style>
The section is taken from vuetifyjs but it has no impact
The section does modify the table (colours & fonts) but I've not found a way to change the row height and I've tested adding the following code in the section
.v-table tr {
        line-height: 0.8; /* Reduces row height */
        height: 15px !important; /* Forces row height reduction */
Any idea on what I can do have more compact table?
Under the Theming Tab for dashboard 2.0 there is a general setting with this regard (Row Height = Compact). Probably this is already sufficient for your needs:
Perfect. Many thanks @ceysa75
Just in case, further compactness needed,..
