Dashboard 2.0 gauge
I want to set the gauge segment colors via function but cannot get it to work.
This is my code:
msg.ui_update =
{"segments" :
        { color: "blue", from: 0 },
        { color: "green", from: 15 },
        { color: "red", from: 35 }
What am I doing wrong?
And:
According to google this should work but it causes an error:
msg.ui_update.segments = [
  { color: "red", from: 0 },
  { color: "blue", from: 10 },
  { color: "green", from: 20 }
thanks for your help.
It is always helpful to include the error - however I imagine this one fails because ui_update is undefined. i.e. add msg.ui_update = {} on the line before so that ui_update is an object.
That looks ok, but what are you doing with it? Do you return the msg? have you checked with a debug node that the msg contains the "right stuff"? did you wire it into the gauge node? Have you tried sending a new value along with it in the payload?
Hello Steve.
Thanks for your help
msg.ui_update = {} solved my problem.
cheers,
Bernard.
