Dashboard 2.0 Template - pause until external library is loaded
I have a template which uses the plotly library and when the page loads, I am getting an error in the console which I would like to eliminate. It appears the plotly library has not loaded prior to the template loading:
errorCaptured ReferenceError: Plotly is not defined
I would like to know what I am missing in order to have the library load prior to the call being made.
I have this template which is loading the library:
In a second template I am defining and displaying my graph:
This is an abbreviated version of the code:
<template>
    <h1>MMWave 2</h1>
    <div style='height: 100%;'>
        <!-- Had to set the height here to get the chart div to grow and fit the Plotly chart -->
        <div id='mmwave_chart'>
            <!-- Plotly chart will be drawn inside this DIV -->
        </div>
    </div>
</template>
<script>
    export default {
        data() {
            return {
                zone1: {
                    x: 0,
                    y: 0,...
        watch: {
            //Watch for any changes to msg and act on them.
            //This is run when the dashboard is loaded as well
            msg: function () {
                this.draw();
        mounted() {
            // code here when the component is first loaded
            //setTimeout(this.draw(),2000);
                //this.draw();
        methods: {
            draw () {
                var traceCoveredArea = {...
                var traceZone1 = {
                    x: [...
                var data = [traceCoveredArea, traceZone1];
                var layout = {
                    xaxis: {
                        side: 'top'
                Plotly.react('mmwave_chart', data, layout) ;
                // Plotly.react is the same as Plotly.newPlot except that
                // when it receives a request to redraw it only calculates the changed data
</script>
Export of both templates and the associated dashboard page items:
[{"id":"6f6bd4033ec6b55b","type":"ui-template","z":"01a9e096a69c7202","group":"","page":"","ui":"4c2bb00f7172c414","name":"Load Plotly CDN 2.3","order":0,"width":0,"height":0,"head":"","format":"\n<script src='https://cdn.plot.ly/plotly-2.35.0.min.js'></script>\n\n","storeOutMessages":true,"passthru":true,"resendOnRefresh":true,"templateScope":"widget:ui","className":"","x":2120,"y":320,"wires":[[]]},{"id":"1c84643e64afa80e","type":"ui-template","z":"01a9e096a69c7202","group":"0db8d9f5bdc794eb","page":"","ui":"","name":"Plotly mmwave test 2","order":3,"width":"12","height":"6","head":"","format":"<template>\n    <h1>MMWave 2</h1>\n    <div style='height: 100%;'>\n        <!-- Had to set the height here to get the chart div to grow and fit the Plotly chart -->\n        <div id='mmwave_chart'>\n            <!-- Plotly chart will be drawn inside this DIV -->\n        </div>\n    </div>\n</template>\n\n<script>\n    export default {\n        data() {\n            return {\n                zone1: {\n                    x: 0,\n                    y: 0,\n                    height: 0,\n                    width: 0,\n                    timeout: 0,\n                    presence: 'OFF',\n                    target_counts: 0,\n                    info:'none'\n                }\n            }\n        },\n        watch: {\n            //Watch for any changes to msg and act on them.\n            //This is run when the dashboard is loaded as well\n            msg: function () {\n                this.draw();\n            }\n        },\n        mounted() {\n            // code here when the component is first loaded\n            //setTimeout(this.draw(),2000);\n                //this.draw();\n         },\n        methods: {\n            draw () {\n                var traceCoveredArea = {\n                    x: [0, 7500 * Math.sin((2 * Math.PI)/360 * 60), 6500, 5500, 4500, 4000, 3000, 2000, 1000, 0, -1000, -2000, -3000, -4000,\n                    -4500, -5500, -6500, -7500 * Math.sin((2 * Math.PI)/360 * 60), 0],\n                    y: [0, 7500 * Math.cos((2 * Math.PI)/360 * 60), Math.sqrt( 7500**2 - 6500**2 ),Math.sqrt( 7500**2 - 5500**2 ),\n                    Math.sqrt( 7500**2 - 4500**2 ), Math.sqrt( 7500**2 - 4000**2 ), Math.sqrt( 7500**2 - 3000**2 ), Math.sqrt( 7500**2 -\n                    2000**2 ), Math.sqrt( 7500**2 - 1000**2 ), 7500, Math.sqrt( 7500**2 - 1000**2 ), Math.sqrt( 7500**2 - 2000**2 ),\n                    Math.sqrt( 7500**2 - 3000**2 ), Math.sqrt( 7500**2 - 4000**2 ), Math.sqrt( 7500**2 - 4500**2 ), Math.sqrt( 7500**2 -\n                    5500**2 ), Math.sqrt( 7500**2 - 6500**2 ), 7500 * Math.cos((2 * Math.PI)/360 * 60), 0],\n                    mode: 'lines',\n                    name: 'Covered Area',\n                    line: {shape: 'linear', dash: 'dash', color:'gainsboro'},\n                    type: 'scatter'\n                };\n                var traceZone1 = {\n                    x: [\n                        this.zone1.x,\n                        this.zone1.x - this.zone1.width * Math.cos((this.sensor_angle)*3.1415/180),\n                        this.zone1.x - this.zone1.width * Math.cos((this.sensor_angle)*3.1415/180) + this.zone1.height\n                        * Math.cos((this.sensor_angle*1-90)*3.1415/180),\n                        this.zone1.x*1 + this.zone1.height * Math.cos((this.sensor_angle*1-90)*3.1415/180),\n                        this.zone1.x*1\n                    ],\n                    y: [\n                        this.zone1.y*1,\n                        this.zone1.y*1 + this.zone1.width * Math.sin((this.sensor_angle)*3.1415/180),\n                        this.zone1.y*1 + this.zone1.width * Math.sin((this.sensor_angle)*3.1415/180) +\n                        this.zone1.height * Math.sin((this.sensor_angle*1+90)*3.1415/180),\n                        this.zone1.y*1 + this.zone1.height * Math.sin((this.sensor_angle*1+90)*3.1415/180),\n                        this.zone1.y*1\n                    ],\n                    mode: 'lines+markers',\n                    name: 'Zone 1',\n                    line: {shape: 'linear', color:'MediumAquaMarine'},\n                    fill: \"toself\",\n                    type: 'scatter'\n                };\n\n                var data = [traceCoveredArea, traceZone1];\n\n                var layout = {\n                    xaxis: {\n                        side: 'top'\n                    }\n                };\n\n                Plotly.react('mmwave_chart', data, layout) ;\n                // Plotly.react is the same as Plotly.newPlot except that\n                // when it receives a request to redraw it only calculates the changed data, making it faster\n            },\n        }\n    }\n</script>","storeOutMessages":true,"passthru":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":2120,"y":360,"wires":[[]]},{"id":"4c2bb00f7172c414","type":"ui-base","name":"My 1st 2.0 Dashboard","path":"/dashboard","includeClientData":true,"acceptsClientConfig":["ui-notification","ui-control"],"showPathInSidebar":false,"headerContent":"page","navigationStyle":"default","titleBarStyle":"default","notificationDisplayTime":5},{"id":"0db8d9f5bdc794eb","type":"ui-group","name":"My Group","page":"92d2e5483adf6001","width":"12","height":"6","order":1,"showTitle":true,"className":"","visible":"true","disabled":"false","groupType":"default"},{"id":"92d2e5483adf6001","type":"ui-page","name":"Simulation","ui":"4c2bb00f7172c414","path":"/page7","icon":"home","layout":"grid","theme":"d8f055e104cc1454","breakpoints":[{"name":"Default","px":"0","cols":"3"},{"name":"Tablet","px":"576","cols":"6"},{"name":"Small Desktop","px":"768","cols":"9"},{"name":"Desktop","px":"1024","cols":"12"}],"order":2,"className":"","visible":true,"disabled":"false"},{"id":"d8f055e104cc1454","type":"ui-theme","name":"Default Theme","colors":{"surface":"#ffffff","primary":"#0094CE","bgPage":"#eeeeee","groupBg":"#ffffff","groupOutline":"#cccccc"},"sizes":{"pagePadding":"12px","groupGap":"12px","groupBorderRadius":"4px","widgetGap":"12px"}}]
This example loads echarts - look at how it checks for the thing to be loaded before usage : How to configure Echarts in Dashboard 2? - #4 by Steve-Mcl
I have not tested this yet, but seen documentation stating that the readyState property indicates full page load (including external imports) as follows:
export default {
  mounted() {
    if (document.readyState === "complete")
      this.init();
    else
      window.addEventListener("load", this.init);
  methods: {
    init: function () {
   // Start here
However, I'm not sure if this takes in account async fetches of external packages.
Edit:
Did some testing. Don't rely on document.readyState. It is set to "complete" before external packages finish loading.
