Dashboard 2.0 ui-chart timestamp format
I'm trying to display historized data on a line chart but running into issues with getting the values to show correctly.
In the screenshot below, you can see the data being returned from the database:
My goal is to trend these values on the chart, but so far I haven't been successful. Below is the current chart configuration:
I tried converting the datetime to UnixTimestamp, and it kinda works — the trends now display values, but the timestamps are shown in Unix format instead of a readable datetime format
        "id": "eb7baf9594b86c97",
        "type": "ui-form",
        "z": "temp_historian_flow",
        "name": "Date-Time Picker",
        "group": "2baf9c9d8f909ab3",
        "label": "",
        "order": 2,
        "width": 0,
        "height": 0,
        "options": [
                "label": "Start Date",
                "key": "Start Date",
                "type": "date",
                "required": true,
                "rows": null
                "label": "End Date",
                "key": "End Date",
                "type": "date",
                "required": true,
                "rows": null
                "label": "Start Time",
                "key": "Start Time",
                "type": "time",
                "required": false,
                "rows": null
                "label": "End Time",
                "key": "End Time",
                "type": "time",
                "required": false,
                "rows": null
        "formValue": {
            "Start Date": "",
            "End Date": "",
            "Start Time": "",
            "End Time": ""
        "payload": "",
        "submit": "Generate",
        "cancel": "Clear",
        "resetOnSubmit": false,
        "topic": "topic",
        "topicType": "msg",
        "splitLayout": true,
        "className": "",
        "passthru": false,
        "dropdownOptions": [],
        "x": 470,
        "y": 540,
                "a4d97ad20723270a"
        "id": "a4d97ad20723270a",
        "type": "function",
        "name": "Temp Data Return",
        "func": "\nfunction combineDateTime(date, time) {\n    return `${date} ${time}:00`;\n}\n\nlet startDateTime = combineDateTime(msg.payload['Start Date'], msg.payload['Start Time']);\nlet endDateTime = combineDateTime(msg.payload['End Date'], msg.payload['End Time']);\nlet selectedTags = flow.get('tagSelect');\n\n// Ensure selectedTags is always an array\nif (!Array.isArray(selectedTags)) {\n    selectedTags = selectedTags ? [selectedTags] : [1];\n}\n\n// Handle empty array case\nif (selectedTags.length === 0) {\n    selectedTags = [1];\n}\n\n// Get the selected table from flow context\nvar selectedTable = 'historian.temperature_history';\n\n// Build dynamic WHERE clause for multiple tags\nlet tagPlaceholders = selectedTags.map(() => '?').join(',');\nlet whereClause = `tag_name IN (${tagPlaceholders})`;\n\n// Build the SQL query to handle multiple tags\nmsg.topic = `SELECT tag_name, temperature_value as tempValue, DATE_FORMAT(Timestamp, '%Y-%m-%d %H:%i:%s') as datestamp \n             FROM ${selectedTable} \n             WHERE Timestamp BETWEEN ? AND ? AND ${whereClause}\n             ORDER BY tag_name, Timestamp`;\n\n// Prepare parameters array: [startDateTime, endDateTime, ...selectedTags]\nmsg.payload = [startDateTime, endDateTime, ...selectedTags];\n\nreturn msg;\n\n",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 730,
        "y": 540,
                "1165ed5841c50f6e"
        "id": "1165ed5841c50f6e",
        "type": "mysql",
        "mydb": "mysql_config",
        "name": "Industrial History DB",
        "x": 980,
        "y": 540,
                "bd53d45c3b4a499a"
        "id": "bd53d45c3b4a499a",
        "type": "ui-chart",
        "label": "chart",
        "order": 3,
        "chartType": "line",
        "category": "tag_name",
        "categoryType": "property",
        "xAxisLabel": "Timestamp",
        "xAxisProperty": "datestamp",
        "xAxisPropertyType": "property",
        "xAxisType": "linear",
        "xAxisFormat": "",
        "xAxisFormatType": "auto",
        "xmin": "",
        "xmax": "",
        "yAxisLabel": "F",
        "yAxisProperty": "tempValue",
        "yAxisPropertyType": "property",
        "ymin": "0",
        "ymax": "100",
        "bins": 10,
        "action": "replace",
        "stackSeries": false,
        "pointShape": "circle",
        "pointRadius": 4,
        "showLegend": true,
        "removeOlder": 1,
        "removeOlderUnit": "3600",
        "removeOlderPoints": "",
        "colors": [
            "#0095ff",
            "#ff0000",
            "#ff7f0e",
            "#2ca02c",
            "#a347e1",
            "#d62728",
            "#ff9896",
            "#9467bd",
            "#c5b0d5"
        "textColor": [
            "#666666"
        "textColorDefault": true,
        "gridColor": [
            "#e5e5e5"
        "gridColorDefault": true,
        "width": 6,
        "height": 8,
        "className": "",
        "interpolation": "linear",
        "x": 1270,
        "y": 540,
        "id": "d8f8b9173cc97d59",
        "type": "ui-button",
        "label": "Clear",
        "order": 0,
        "width": 0,
        "height": 0,
        "emulateClick": false,
        "tooltip": "",
        "color": "",
        "bgcolor": "",
        "className": "",
        "icon": "",
        "iconPosition": "left",
        "payload": "[]",
        "payloadType": "str",
        "topic": "topic",
        "topicType": "msg",
        "buttonColor": "",
        "textColor": "",
        "iconColor": "",
        "enableClick": true,
        "enablePointerdown": false,
        "pointerdownPayload": "",
        "pointerdownPayloadType": "str",
        "enablePointerup": false,
        "pointerupPayload": "",
        "pointerupPayloadType": "str",
        "x": 1270,
        "y": 600,
                "bd53d45c3b4a499a"
        "id": "2baf9c9d8f909ab3",
        "type": "ui-group",
        "name": "Group 15",
        "page": "25086a72528c822c",
        "width": 6,
        "height": 1,
        "order": 3,
        "showTitle": true,
        "className": "",
        "visible": "true",
        "disabled": "false",
        "groupType": "default"
        "id": "mysql_config",
        "type": "MySQLdatabase",
        "name": "Industrial History Database",
        "host": "localhost",
        "port": "3306",
        "db": "historian",
        "tz": "local",
        "charset": "UTF8"
        "id": "25086a72528c822c",
        "type": "ui-page",
        "name": "Temperature Trends",
        "ui": "ed79b03d683e2b34",
        "path": "/page7",
        "icon": "home",
        "layout": "grid",
        "theme": "6d8bff5f3fded5c2",
        "breakpoints": [
                "name": "Default",
                "px": "0",
                "cols": "3"
                "name": "Tablet",
                "px": "576",
                "cols": "6"
                "name": "Small Desktop",
                "px": "768",
                "cols": "9"
                "name": "Desktop",
                "px": "1024",
                "cols": "12"
        "order": 7,
        "className": "",
        "visible": true,
        "disabled": false
        "id": "ed79b03d683e2b34",
        "type": "ui-base",
        "name": "Siroflex Demo",
        "path": "/dashboard",
        "appIcon": "",
        "includeClientData": true,
        "acceptsClientConfig": [
            "ui-notification",
            "ui-control"
        "showPathInSidebar": false,
        "headerContent": "dashboard",
        "navigationStyle": "icon",
        "titleBarStyle": "default",
        "showReconnectNotification": true,
        "notificationDisplayTime": 1,
        "showDisconnectNotification": true
        "id": "6d8bff5f3fded5c2",
        "type": "ui-theme",
        "name": "FF Theme",
        "colors": {
            "surface": "#1f2937",
            "primary": "#8ce2e7",
            "bgPage": "#4b5563",
            "groupBg": "#ffffff",
            "groupOutline": "#cccccc"
I'd appreciate any suggestions on how to configure the chart to display this data. Thank you all.
You should not need to manipulate the timestamp values in your SQL query.
ie
SELECT tag_name, temperature_value, timestamp ...
Change the chart X-axis type from "Linear" to "Timescale"
I'd appreciated your help. Thanks @jbudd.
