Dashboard 2 - Socket emit from ui-template
Hello everyone !
In a D2 ui-template node, I created a button that opens a dialog containing two sliders and a switch ; I managed to dynamically change the slider values with two inject nodes, but when I change the slider values from the dashboard, I can't get their values out and into a debug node.
I'm having trouble with the " this.$socket.emit " I think, am I using it wrong ? (Sorry if this is a dumb question)
        "id": "cb52285651c139ca",
        "type": "ui-template",
        "z": "4e58b6fb.8aa1b",
        "group": "099be5983fda69d4",
        "page": "",
        "ui": "",
        "name": "Bouton magasin",
        "order": 0,
        "width": "6",
        "height": "1",
        "head": "",
        "format": "<template>\n  <div>\n    <v-btn\n      :class=\"buttonClass\"\n      @click=\"showDialog = true\"\n    >Référence AAA</v-btn>\n\n    <v-dialog v-model=\"showDialog\" max-width=\"600px\">\n      <v-card>\n        <v-card-title class=\"text-h5\">Référence AAA</v-card-title>\n        <v-card-text>\n          <v-row>\n            <v-col cols=\"6\">\n              <div>Gauche : {{ gaucheValue }}</div>\n              <v-slider\n                v-model=\"gaucheValue\"\n                thumb-label=\"always\"\n                step=\"1\"\n                min=\"0\"\n                max=\"2\"\n                @change=\"sendValue('gauche', gaucheValue)\"\n              ></v-slider>\n            </v-col>\n            <v-col cols=\"6\">\n              <div>Droite : {{ droiteValue }}</div>\n              <v-slider\n                v-model=\"droiteValue\"\n                thumb-label=\"always\"\n                step=\"1\"\n                min=\"0\"\n                max=\"2\"\n                @change=\"sendValue('droite', droiteValue)\"\n              ></v-slider>\n            </v-col>\n          </v-row>\n          <v-row>\n            <v-col cols=\"12\">\n              <v-switch\n                v-model=\"ruptureSwitch\"\n                label=\"Rupture\"\n                @change=\"sendValue('rupture', ruptureSwitch)\"\n              ></v-switch>\n            </v-col>\n          </v-row>\n        </v-card-text>\n        <v-card-actions>\n          <v-btn color=\"blue darken-1\" text @click=\"showDialog = false\">Close</v-btn>\n        </v-card-actions>\n      </v-card>\n    </v-dialog>\n  </div>\n</template>\n\n<script>\nexport default {\n  data() {\n    return {\n      showDialog: false,\n      gaucheValue: 1,\n      droiteValue: 1,\n      ruptureSwitch: false,\n      state: '', // Initial state\n    };\n  },\n  computed: {\n    buttonClass() {\n      if (this.ruptureSwitch && this.gaucheValue + this.droiteValue === 0) {\n        return 'greydisabled';\n      } else if (!this.ruptureSwitch && this.gaucheValue + this.droiteValue === 0) {\n        return 'red';\n      } else if (this.ruptureSwitch) {\n        return 'grey';\n      } else {\n        return 'green';\n      }\n    },\n  },\n  mounted() {\n    this.$socket.on(\"msg-input:\" + this.id, (msg) => {\n      this.gaucheValue = msg.gauche || this.gaucheValue;\n      this.droiteValue = msg.droite || this.droiteValue;\n    });\n  },\n  methods: {\n    sendValue(type, value) {\n      this.$socket.emit(\"msg-output\", { topic: type, payload: value });\n    },\n  },\n};\n</script>\n\n<style>\n.greydisabled {\n  // pointer-events: none;\n  background-color: grey;\n  color: black;\n}\n\n.grey {\n  background-color: grey;\n  color: black;\n}\n\n.green {\n  background-color: #55aa73;\n  color: black;\n}\n\n.red {\n  // pointer-events: none;\n  background-color: #e14c42;\n  color: black;\n}\n\n.switch {\n  color: black;\n  font-size: 1.3em;\n}\n</style>\n",
        "storeOutMessages": true,
        "passthru": true,
        "resendOnRefresh": true,
        "templateScope": "local",
        "className": "",
        "x": 360,
        "y": 1260,
                "799c9583a4639b69"
        "id": "24692592e592a3ec",
        "type": "inject",
        "name": "gauche 2",
        "props": [
                "p": "gauche",
                "v": "2",
                "vt": "num"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "x": 180,
        "y": 1260,
                "cb52285651c139ca"
        "id": "1840fea357e8c84a",
        "type": "inject",
        "name": "droite 2",
        "props": [
                "p": "droite",
                "v": "2",
                "vt": "num"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "x": 190,
        "y": 1300,
                "cb52285651c139ca"
        "id": "799c9583a4639b69",
        "type": "debug",
        "name": "debug 371",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "statusType": "auto",
        "x": 530,
        "y": 1260,
        "id": "099be5983fda69d4",
        "type": "ui-group",
        "name": "Référence XXX",
        "page": "f7c84ba6694cf8fd",
        "width": "6",
        "height": "1",
        "order": -1,
        "showTitle": true,
        "className": "cxxx",
        "visible": "true",
        "disabled": "false"
        "id": "f7c84ba6694cf8fd",
        "type": "ui-page",
        "name": "MAG",
        "ui": "f4139e7488bf5f07",
        "path": "/MAG",
        "icon": "home",
        "layout": "grid",
        "theme": "684392cc1527bd04",
        "order": 2,
        "className": "",
        "visible": "true",
        "disabled": "false"
        "id": "f4139e7488bf5f07",
        "type": "ui-base",
        "name": "UI Name",
        "path": "/dashboard",
        "includeClientData": true,
        "acceptsClientConfig": [
            "ui-notification",
            "ui-control"
        "showPathInSidebar": false
        "id": "684392cc1527bd04",
        "type": "ui-theme",
        "name": "Theme Name",
        "colors": {
            "surface": "#7d7d7d",
            "primary": "#0094ce",
            "bgPage": "#a3a3a3",
            "groupBg": "#dedede",
            "groupOutline": "#dedede"
        "sizes": {
            "pagePadding": "12px",
            "groupGap": "12px",
            "groupBorderRadius": "4px",
            "widgetGap": "12px"
Thanks in advance !
You can use this.send() in order to pass output to Node-RED (docs), no need to call the raw $socket handler here.
No such thing as a "dumb question" - all are welcome.
Thank you for your answer ! I tried using this example but it doesn't seem to work (no msg.payload comes out of the ui-template) :
        "id": "27335c145badc531",
        "page": "",
        "ui": "",
        "name": "Example",
        "order": 0,
        "width": 0,
        "height": 0,
        "head": "",
        "format": "<template>\n  <v-rating hover :length=\"5\" :size=\"32\" v-model=\"value\"\n    active-color=\"primary\" @update:modelValue=\"send({payload: value})\"/>\n</template>",
        "passthru": true,
        "className": "",
        "x": 200,
        "y": 1460,
                "2ca2d8a83d456fdb"
        "id": "2ca2d8a83d456fdb",
        "type": "debug",
        "name": "debug 375",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "",
        "x": 350,
        "y": 1460,
        "type": "ui-group",
        "width": "6",
        "height": "1",
        "order": -1,
        "showTitle": true,
        "visible": "true",
        "disabled": "false"
        "type": "ui-page",
        "name": "MAG",
        "path": "/MAG",
        "icon": "home",
        "layout": "grid",
        "order": 2,
        "className": "",
        "visible": "true",
        "disabled": "false"
        "type": "ui-base",
        "name": "UI Name",
            "ui-notification",
            "ui-control"
        "type": "ui-theme",
        "colors": {
        "sizes": {
            "groupGap": "12px",
            "widgetGap": "12px"
Try @update:model-value instead. I will put a fix into the docs to update the example. Thanks for flagging.
This definitely used to work, not sure why it's changed.
That worked! Thanks a lot :grin:
I do have one last question about the data within the ui-template node ; Every time I re-deploy my flow or refresh the dashboard, all my variables are reset. Is there a way to fix that ? Thanks in advance !
If you use watch msg rather than direct socket input then the server will send the most recent message back to the template on a page refresh or deploy.
