Let me give some background:
every dashboard node, is actually composed of 2 parts. the "backend" node which is part of the flow, and the "widget" which is an HTML object living in the dashboard page and interacting with its backend node.
for example, a button node:
backend node:
widget:
the widgets are created once their respective page opens, and destroyed when it closes. messages sent to a backend node while there is no open dashboard client, are ignored.
in our case, the actual ui-tabulator table object is a widget, so you cannot set data into it before the dashboard page is open and the table is initialized. The "preload" template you added is not useful since it opens an iframe (which has a different DOM & context), and moreover, this template is created only after the page is opened (i.e. chicken & egg).
What I propose to do here, is to listen to the notification "tableBuilt", and then set a flag which allows safe access to the table, as in the attached flow.
"id": "59f03b602ebe4496",
"type": "ui-template",
"z": "5130c95e050fe9b6",
"group": "",
"page": "3c88ebbd2d694eb8",
"ui": "",
"name": "Page Style PN STATION STATUS",
"order": 0,
"width": 0,
"height": 0,
"head": "",
"format": ".tabulator{\n font-size:16px !important;\n background-color:White !important;\n}\n.tabulator-header{\n background-color: White !important;\n color:steelblue !important;\n}\n.tabulator-row{\n background-color: White !important;\n}\n.tabulator-cell {\n border: 3px solid transparent;\n box-sizing: border-box;\n }\n\n.tabulator-cell:hover {\n border: 3px solid #585858;\n cursor: pointer;\n}\n",
"storeOutMessages": true,
"passthru": true,
"resendOnRefresh": true,
"templateScope": "page:style",
"className": "",
"x": 180,
"y": 560,
"id": "5a0a5c23725007be",
"type": "debug",
"name": "debug 2",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"targetType": "full",
"statusVal": "",
"statusType": "auto",
"x": 855,
"y": 700,
"wires": [],
"l": false
"id": "3dedf938038a815e",
"type": "ui-tabulator",
"name": "PN STATION STATUS",
"group": "f2df73be35a54955",
"initObj": "{\n \"height\": 900,\n \"layout\": \"fitColumns\",\n \"headerVisible\": true,\n \"columns\": [\n {\"title\":\"id\",\"field\":\"id\",\"visible\":false},\n {\"title\":\"C1\",\"field\":\"C1\",\"hozAlign\":\"left\",\"formatter\":\"html\"},\n {\"title\":\"C2\",\"field\":\"C2\",\"hozAlign\":\"left\",\"formatter\":\"html\"},\n {\"title\":\"C3\",\"field\":\"C3\",\"hozAlign\":\"left\",\"formatter\":\"html\"},\n {\"title\":\"C4\",\"field\":\"C4\",\"hozAlign\":\"left\",\"formatter\":\"html\"},\n {\"title\":\"C5\",\"field\":\"C5\",\"hozAlign\":\"left\",\"formatter\":\"html\"},\n {\"title\":\"C6\",\"field\":\"C6\",\"hozAlign\":\"left\",\"formatter\":\"html\"},\n {\"title\":\"C7\",\"field\":\"C7\",\"hozAlign\":\"left\",\"formatter\":\"html\"},\n {\"title\":\"C8\",\"field\":\"C8\",\"hozAlign\":\"left\",\"formatter\":\"html\"},\n {\"title\":\"C9\",\"field\":\"C9\",\"hozAlign\":\"left\",\"formatter\":\"html\"}\n ]\n}",
"funcs": "",
"allowMsgFuncs": false,
"maxWidth": "",
"events": "cellClick, tableBuilt",
"order": 2,
"multiUser": false,
"validateRowIds": false,
"themeCSS": "",
"themeFile": "",
"tblDivId": "",
"printToLog": false,
"width": "27",
"height": "15",
"x": 560,
"y": 640,
"cb474968c93d588f"
"id": "c4b668eb7261b006",
"type": "inject",
"props": [],
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": "0.3",
"topic": "",
"x": 75,
"y": 640,
"3e956c84e978d866"
"l": false
"id": "cb474968c93d588f",
"type": "switch",
"property": "payload",
"propertyType": "msg",
"rules": [
"t": "jsonata_exp",
"v": "msg.msgType = \"tbNotification\" and msg.event = \"tableBuilt\"",
"vt": "jsonata"
"t": "jsonata_exp",
"v": "msg.msgType = \"tbNotification\" and msg.event = \"cellClick\"",
"vt": "jsonata"
"t": "else"
"checkall": "false",
"repair": false,
"outputs": 3,
"x": 750,
"y": 640,
"024a7b5da1563c9c"
"f57a163a11487675"
"5a0a5c23725007be"
"id": "024a7b5da1563c9c",
"type": "function",
"name": "tableBuilt",
"func": "flow.set(\"tables\", { \"PN_STATION_STATUS\": true });\nreturn null; // or send a message to other initialization tasks",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "// Code added here will be run once\n// whenever the node is started.\nflow.set(\"tables\",{\"PN_STATION_STATUS\":false});",
"finalize": "",
"libs": [],
"x": 900,
"y": 580,
"id": "a44479a7ca51416e",
"type": "function",
"name": "Is table ready?",
"func": "const isReady = flow.get(\"tables.PN_STATION_STATUS\");\nif (isReady)\n return msg;\nelse\n node.error(\"table is not ready\",msg)\n",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 360,
"y": 640,
"3dedf938038a815e"
"id": "f57a163a11487675",
"type": "function",
"name": "cellClick",
"func": "\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 900,
"y": 640,
"ae7e36415dd33546"
"id": "ae7e36415dd33546",
"type": "debug",
"name": "Handle cell click...",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"statusVal": "",
"x": 1010,
"y": 780,
"id": "740f4f17ee12fec2",
"type": "catch",
"scope": [
"a44479a7ca51416e"
"uncaught": false,
"x": 330,
"y": 700,
"793c6daa45574e44"
"id": "793c6daa45574e44",
"type": "debug",
"name": "Table not ready",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"statusVal": "",
"x": 540,
"y": 700,
"id": "3e956c84e978d866",
"type": "function",
"name": "setData",
"func": "msg.tbCmd = \"setData\";\nmsg.tbArgs = [\n [\n {\n \"id\": 0,\n \"C0\": \"<div style=\\\"background-color: green; width: 100%; height: 75px; position: relative; color: white; font-family: sans-serif; font-size: 12px; overflow: hidden;\\\">\\n <div style=\\\"background-color: green; width: 15px; height: 15px; position: absolute; top: 0; right: 0;\\\">\\n </div>\\n <div style=\\\"background-color: green !important; padding: 12px 5px 5px 5px; height: 100%; overflow: hidden;\\\">\\n <div\\n style=\\\"display: flex; align-items: center; gap: 5px; white-space: nowrap; overflow: hidden; text-overflow: ellipsis;\\\">\\n <span\\n style=\\\" display: inline-block; width: 10px; height: 10px; border-radius: 50%; background-color: green; flex-shrink: 0; \\\"></span>\\n <span>192.168.0.7</span> </div>\\n <div style=\\\"white-space: nowrap; overflow: hidden; text-overflow: ellipsis;\\\">dev5</div>\\n <div style=\\\"white-space: nowrap; overflow: hidden; text-overflow: ellipsis;\\\">Buskoppler Profinet</div>\\n </div>\\n </div>\",\n \"C1\": \"<div style=\\\"background-color: green; width: 100%; height: 75px; position: relative; color: white; font-family: sans-serif; font-size: 12px; overflow: hidden;\\\">\\n <div style=\\\"background-color: green; width: 15px; height: 15px; position: absolute; top: 0; right: 0;\\\">\\n </div>\\n <div style=\\\"background-color: green !important; padding: 12px 5px 5px 5px; height: 100%; overflow: hidden;\\\">\\n <div\\n style=\\\"display: flex; align-items: center; gap: 5px; white-space: nowrap; overflow: hidden; text-overflow: ellipsis;\\\">\\n <span\\n style=\\\" display: inline-block; width: 10px; height: 10px; border-radius: 50%; background-color: green; flex-shrink: 0; \\\"></span>\\n <span>192.168.0.6</span> </div>\\n <div style=\\\"white-space: nowrap; overflow: hidden; text-overflow: ellipsis;\\\">dev4</div>\\n <div style=\\\"white-space: nowrap; overflow: hidden; text-overflow: ellipsis;\\\">IM151-3</div>\\n </div>\\n </div>\",\n \"C2\": \"<div style=\\\"background-color: green; width: 100%; height: 75px; position: relative; color: white; font-family: sans-serif; font-size: 12px; overflow: hidden;\\\">\\n <div style=\\\"background-color: green; width: 15px; height: 15px; position: absolute; top: 0; right: 0;\\\">\\n </div>\\n <div style=\\\"background-color: green !important; padding: 12px 5px 5px 5px; height: 100%; overflow: hidden;\\\">\\n <div\\n style=\\\"display: flex; align-items: center; gap: 5px; white-space: nowrap; overflow: hidden; text-overflow: ellipsis;\\\">\\n <span\\n style=\\\" display: inline-block; width: 10px; height: 10px; border-radius: 50%; background-color: green; flex-shrink: 0; \\\"></span>\\n <span>192.168.0.2</span> </div>\\n <div style=\\\"white-space: nowrap; overflow: hidden; text-overflow: ellipsis;\\\">dev1</div>\\n <div style=\\\"white-space: nowrap; overflow: hidden; text-overflow: ellipsis;\\\">IM151-3</div>\\n </div>\\n </div>\",\n \"C3\": \"<div style=\\\"background-color: green; width: 100%; height: 75px; position: relative; color: white; font-family: sans-serif; font-size: 12px; overflow: hidden;\\\">\\n <div style=\\\"background-color: green; width: 15px; height: 15px; position: absolute; top: 0; right: 0;\\\">\\n </div>\\n <div style=\\\"background-color: green !important; padding: 12px 5px 5px 5px; height: 100%; overflow: hidden;\\\">\\n <div\\n style=\\\"display: flex; align-items: center; gap: 5px; white-space: nowrap; overflow: hidden; text-overflow: ellipsis;\\\">\\n <span\\n style=\\\" display: inline-block; width: 10px; height: 10px; border-radius: 50%; background-color: green; flex-shrink: 0; \\\"></span>\\n <span>192.168.0.1</span> </div>\\n <div style=\\\"white-space: nowrap; overflow: hidden; text-overflow: ellipsis;\\\">pn-io</div>\\n <div style=\\\"white-space: nowrap; overflow: hidden; text-overflow: ellipsis;\\\">S7-300</div>\\n </div>\\n </div>\",\n \"C4\": \"<div style=\\\"background-color: green; width: 100%; height: 75px; position: relative; color: white; font-family: sans-serif; font-size: 12px; overflow: hidden;\\\">\\n <div style=\\\"background-color: green; width: 15px; height: 15px; position: absolute; top: 0; right: 0;\\\">\\n </div>\\n <div style=\\\"background-color: green !important; padding: 12px 5px 5px 5px; height: 100%; overflow: hidden;\\\">\\n <div\\n style=\\\"display: flex; align-items: center; gap: 5px; white-space: nowrap; overflow: hidden; text-overflow: ellipsis;\\\">\\n <span\\n style=\\\" display: inline-block; width: 10px; height: 10px; border-radius: 50%; background-color: yellow; flex-shrink: 0; \\\"></span>\\n <span>192.168.0.4</span> </div>\\n <div style=\\\"white-space: nowrap; overflow: hidden; text-overflow: ellipsis;\\\">dev2</div>\\n <div style=\\\"white-space: nowrap; overflow: hidden; text-overflow: ellipsis;\\\">SCALANCE X-200</div>\\n </div>\\n </div>\",\n \"C5\": \"<div style=\\\"background-color: green; width: 100%; height: 75px; position: relative; color: white; font-family: sans-serif; font-size: 12px; overflow: hidden;\\\">\\n <div style=\\\"background-color: green; width: 15px; height: 15px; position: absolute; top: 0; right: 0;\\\">\\n </div>\\n <div style=\\\"background-color: green !important; padding: 12px 5px 5px 5px; height: 100%; overflow: hidden;\\\">\\n <div\\n style=\\\"display: flex; align-items: center; gap: 5px; white-space: nowrap; overflow: hidden; text-overflow: ellipsis;\\\">\\n <span\\n style=\\\" display: inline-block; width: 10px; height: 10px; border-radius: 50%; background-color: yellow; flex-shrink: 0; \\\"></span>\\n <span>192.168.0.5</span> </div>\\n <div style=\\\"white-space: nowrap; overflow: hidden; text-overflow: ellipsis;\\\">dev3</div>\\n <div style=\\\"white-space: nowrap; overflow: hidden; text-overflow: ellipsis;\\\">SCALANCE X-200</div>\\n </div>\\n </div>\",\n \"C6\": \"<div style=\\\"background-color: green; width: 100%; height: 75px; position: relative; color: white; font-family: sans-serif; font-size: 12px; overflow: hidden;\\\">\\n <div style=\\\"background-color: green; width: 15px; height: 15px; position: absolute; top: 0; right: 0;\\\">\\n </div>\\n <div style=\\\"background-color: green !important; padding: 12px 5px 5px 5px; height: 100%; overflow: hidden;\\\">\\n <div\\n style=\\\"display: flex; align-items: center; gap: 5px; white-space: nowrap; overflow: hidden; text-overflow: ellipsis;\\\">\\n <span\\n style=\\\" display: inline-block; width: 10px; height: 10px; border-radius: 50%; background-color: green; flex-shrink: 0; \\\"></span>\\n <span>192.168.0.8</span> </div>\\n <div style=\\\"white-space: nowrap; overflow: hidden; text-overflow: ellipsis;\\\">dev6</div>\\n <div style=\\\"white-space: nowrap; overflow: hidden; text-overflow: ellipsis;\\\">KP8 PN 8KEYS 8DI/O DC24V</div>\\n </div>\\n </div>\"\n }\n ]\n];\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 180,
"y": 640,
"a44479a7ca51416e"
"id": "3c88ebbd2d694eb8",
"type": "ui-page",
"ui": "ui_base_01",
"path": "/pn_station_status",
"icon": "view-dashboard",
"layout": "grid",
"theme": "cf6324aece5445ca",
"breakpoints": [
"name": "Default",
"px": "0",
"cols": "3"
"name": "Tablet",
"px": "576",
"cols": "6"
"name": "Small Desktop",
"px": "768",
"cols": "9"
"name": "Desktop",
"px": "1024",
"cols": "12"
"order": 2,
"className": "",
"visible": true,
"disabled": false
"id": "f2df73be35a54955",
"type": "ui-group",
"name": "PN Station Status",
"width": "30",
"height": "16",
"order": 1,
"showTitle": false,
"className": "",
"visible": "true",
"disabled": "false",
"groupType": "default"
"id": "ui_base_01",
"type": "ui-base",
"name": "Dashboard Demo",
"path": "/dashboard",
"includeClientData": true,
"acceptsClientConfig": [
"ui-notification"
"showPathInSidebar": false,
"navigationStyle": "default",
"titleBarStyle": "default"
"id": "cf6324aece5445ca",
"type": "ui-theme",
"name": "Default Theme",
"colors": {
"surface": "#ffffff",
"primary": "#0094ce",
"bgPage": "#eeeeee",
"groupBg": "#ffffff",
"groupOutline": "#cccccc"
"sizes": {
"density": "default",
"pagePadding": "12px",
"groupGap": "12px",
"groupBorderRadius": "4px",
"widgetGap": "12px"
"id": "a31d09e1d6bc4c76",
"type": "global-config",
"env": [],
"modules": {
"@flowfuse/node-red-dashboard": "1.30.2",
"@omrid01/node-red-dashboard-2-table-tabulator": "0.9.0"
[Edit] the table was configured for "Multi-user" mode. changed back to "Shared".
One more thing: I believe it would be easier & safer to format the table in the table configuration (using cssClass properties or formatter functions), or using the ui-tabulator command tbSetStyle, instead of overriding native tabulator classes. you can refer to the Table Styling section in the help.
