Dashboard and MS SQL database - number and text input nodes
Hi I am very new to node-red. Im testing something with MS SQL.
I made a dashboard with numeric and text input. (User_ID,First_Name,Last_Name) .
I want it to insert the information into MS SQL.
So I was wondering what is the easiest way to do this ? Can I somehow use the name of my inputs and tell it that's my value when I do a insert?
What I have been trying is connecting the input nodes to a button called Done. When I press the button its sends it to a function node that's processing it and is connected to MS SQL node. Haven't got it to work yet.
Using inject nodes works great so I know my database is working but the point is I want the data from the input from dashboard.
My function looks like this:
msg.topic="INSERT INTO [Test_03].[dbo].[User_Name] (User_ID,First_Name,Last_Name) VALUES ('" + msg.payload.User_ID + "','" + msg.payload.First_Name + "','" + msg.payload.Last_Name + "')";
Hi Naz.
Firstly, one thing to realise is that messages NEVER arrive at the same time. So where you have user_id, first_name and last_name linked to a done button - this is never going to work.
Secondly, you risk sql injection by concatinating strings to generate SQL Queries.
To simplify user input and to avoid SQL Injection, use the ui_form - it has sends all values entered in one msg. Also, use node-red-contrib-mssql-plus as it allows you to use parameters (that negate SQL injection)
Example...
WcueduFvDl
I recommend every new user watches this playlist: Node-RED Essentials. The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot more in about 1 hour. A small investment for a lot of gain.
If you dont want to use the ui_form then you need to store the individual values entered and recover them when the done button is pressed e.g....
