Dashboard Chart set x length from UI
It is the first time I am using this node. Is it possible to set the length/duration/points of the x axis from the UI?
Not at this point, you must set it up in the node
Possible if historical data.
Thanks. So there is no way from the UI to pass back to the node the parameter to set the x axis.
:frowning_face:
