Hello everyone,
Searching in the forum for post about graphs and found this thread.
i'm using dashboard 2 and the chart node.
my flow is simple as below, generating 3 numbers and set the topic for each.
"id": "bcec8084ca96a7c2",
"type": "ui-chart",
"z": "83d956278f9f3685",
"group": "9004f5edd0e95e52",
"label": "chart 3",
"order": 2,
"chartType": "line",
"category": "topic",
"categoryType": "msg",
"xAxisLabel": "x label",
"xAxisProperty": "",
"xAxisPropertyType": "timestamp",
"xAxisType": "category",
"xAxisFormat": "",
"xAxisFormatType": "auto",
"xmin": "",
"xmax": "",
"yAxisLabel": "y label",
"yAxisProperty": "payload",
"yAxisPropertyType": "msg",
"ymin": "0",
"ymax": "",
"bins": 10,
"action": "append",
"stackSeries": false,
"pointShape": "circle",
"pointRadius": "4",
"showLegend": true,
"removeOlder": "3",
"removeOlderUnit": "3600",
"removeOlderPoints": "500",
"colors": [
"#0095ff",
"#ff0000",
"#ff7f0e",
"#2ca02c",
"#a347e1",
"#d62728",
"#ff9896",
"#9467bd",
"#c5b0d5"
"textColor": [
"#666666"
"textColorDefault": true,
"gridColor": [
"#e5e5e5"
"gridColorDefault": true,
"width": "6",
"height": "5",
"className": "",
"interpolation": "smooth",
"x": 1010,
"y": 1100,
"id": "31cddf47a8477dd4",
"type": "random",
"low": "1000",
"high": "800",
"inte": "false",
"property": "payload",
"x": 460,
"y": 1020,
"1494e29ad94063a2"
"id": "6388f53450f758b8",
"type": "inject",
"props": [
"p": "timestamp",
"v": "object",
"vt": "date"
"repeat": "1",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"x": 150,
"y": 1100,
"31cddf47a8477dd4",
"4e7b079075a8388b",
"a614216567bb667e"
"id": "4e7b079075a8388b",
"type": "random",
"low": "400",
"high": "500",
"inte": "false",
"x": 460,
"y": 1100,
"48aaa827dbfc873d"
"id": "a614216567bb667e",
"type": "random",
"low": "420",
"high": "480",
"inte": "false",
"x": 460,
"y": 1180,
"8683b3520479d214"
"id": "1494e29ad94063a2",
"type": "change",
"rules": [
"t": "set",
"p": "topic",
"pt": "msg",
"to": "irradiance",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 670,
"y": 1020,
"bcec8084ca96a7c2"
"id": "48aaa827dbfc873d",
"type": "change",
"rules": [
"t": "set",
"p": "topic",
"pt": "msg",
"to": "dso setpoint",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 670,
"y": 1100,
"bcec8084ca96a7c2"
"id": "8683b3520479d214",
"type": "change",
"rules": [
"t": "set",
"p": "topic",
"pt": "msg",
"to": "Pout",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 670,
"y": 1180,
"bcec8084ca96a7c2"
"id": "9004f5edd0e95e52",
"type": "ui-group",
"name": "Group Name",
"page": "799cb85d9de3dd81",
"width": 6,
"height": 1,
"order": 1,
"showTitle": true,
"className": "",
"visible": "true",
"disabled": "false",
"groupType": "default"
"id": "799cb85d9de3dd81",
"type": "ui-page",
"name": "group3",
"ui": "fe44d2b524e4d1ed",
"path": "/page1",
"icon": "home",
"layout": "grid",
"theme": "34d4bfb4554e23c8",
"breakpoints": [
"name": "Default",
"px": "0",
"cols": "3"
"name": "Tablet",
"px": "576",
"cols": "6"
"name": "Small Desktop",
"px": "768",
"cols": "9"
"name": "Desktop",
"px": "1024",
"cols": "12"
"order": 2,
"className": "",
"visible": "true",
"disabled": "false"
"id": "fe44d2b524e4d1ed",
"type": "ui-base",
"name": "view5",
"path": "/dashboard",
"appIcon": "",
"includeClientData": true,
"acceptsClientConfig": [
"ui-notification",
"ui-control"
"showPathInSidebar": true,
"headerContent": "dashpage",
"navigationStyle": "default",
"titleBarStyle": "default",
"showReconnectNotification": true,
"notificationDisplayTime": 1,
"showDisconnectNotification": true,
"allowInstall": true
"id": "34d4bfb4554e23c8",
"type": "ui-theme",
"name": "Default Theme",
"colors": {
"surface": "#ffffff",
"primary": "#0094ce",
"bgPage": "#eeeeee",
"groupBg": "#ffffff",
"groupOutline": "#cccccc"
"sizes": {
"density": "default",
"pagePadding": "12px",
"groupGap": "12px",
"groupBorderRadius": "4px",
"widgetGap": "12px"
the injection is happening with the same inject node, but still the data points are not aligned.
Also the time is not displayed correctly.
I would expect each point to be aligned on the X axis that is the timestamp.
The 3 different series are recognised by msg.topic (3 different topics)
Does the graph node takes more settings somehow to do that ?
If anyone notice the time (ms before epoch) actually are not sorted oldest to newest.
Is there any problem with how i feed the data ?
the settings on the graph node are:
My target is to present those values as timeseries from oldest to newest and each data point to get the same vertical point on the graph and show the 3 graphs in parallel. Also to show the time correctly. Any suggestions appreciated.
