Dashboard menu icons - not showing as expected
I have made a lot of advancement with the menu on the dashboard and using other icons than the default.
But this one isn't wanting to play the game.
The material design drag_indicator icon.
It isn't showing correctly.
I've copy/pasted the name from the web page, but that didn't change.
And as you can see the other two (Telemetry and Logging) are working.
Screenshot%20from%202019-07-07%2018-56-19
try mi-drag_indicator
(Dumb question) (But I always ask that kind)
Why does this one need the mi- prefix and the others don't?
The built in set (without mi) only have these icons
https://klarsys.github.io/angular-material-icons/
If you want the full latest set then we have to go get them from the internet, and the mi- is the trigger to do that. (And these won't work if you are not connected to the internet)
Ah. I guess I should have worked that out.
Thanks.
(Up to my neck in Arduino stuff too just now.)
