TOSHI1
26 September 2019 07:36
1
Can the size of the text (Label) be increased when using the button node in the node-red dashboard? please tell me.
Is it possible to paste a photo on the dashboard? There is no node designation here. Thank you for your cooperation.
Welcome to the forum, it's always worth searching to see if someone has asked the question before...
This isn't too important but it is a bit "niggily" for me.
(See attached)
All those buttons!
Most of them are ok. Their names are visible.
But then there are the ones with the yellow around them.
The text is just a bit too big for the button.
The only way I can think of to fix it is to make the font a bit smaller.
But that is a but beyond me at this point.
Could someone help with this problem? (Either: The text being too big and another way of doing it or a smaller font)
[Screens…
The javascript == operator should return true when comparing the number 1 to the string '1' -- but perhaps the ng-if expression evaluator does something slightly different... did you try removing the single quotes from the ng-if test? If so, did that make a difference? The other thing to try is to wrap the expression in curly braces (sorry, but i can't remember the syntax.. i always have to look it up).
For more information about what makes a valid angular "expression" and where you can use th…
