Change dashboard name size
Hi there,
I've been using Node-red for quite a long time but it's the first time I come across an issue I can't find the solution to, so here I am asking it to you the experts.
Is there a way to increase the size of the dashboard name shown in the upper left corner, right next to the 3 horizontal lines? I'm projecting different dashboards in different screens, all look pretty much the same, so showing that name bigger would make a difference.
Thanks for your help!
Apparently, there is a similar question answer here:
I believe my quoted answer is not suitable here.
@xors: you can put template node in your NR and add custom CSS there:
<style>
#nr-dashboard-toolbar h1 {
    font-size: 30px;
</style>
As CSS is global, it will affect Dashboard UI so you can tweak it as you wish.
Great solution, thanks for your swift reply!!
