Hi, i created some small buttons.
But the font awesome is not so awesome is the alignment of the buttons.
Is it possible to adjust this?
Probably.
cool, but how is the question then... how can i fix it?
No idea . How have you created then in the first place ? Give us a clue
the button size is 1x1 and size setting is 27x25
just normal button with a icon.
nothing special or different
this is the code, hope this clears more, don't know what to tell more about it to make it more clear, sorry
[{"id":"6c2ec436.5c570c","type":"ui_text_input","z":"86829614.e78918","name":"Hint 1","label":"Hint 1","tooltip":"tooltip","group":"9bce1c47.a279c","order":10,"width":"24","height":"2","passthru":true,"mode":"text","delay":300,"topic":"","x":270,"y":100,"wires":[[]]},{"id":"b5f040f.26fa6c","type":"ui_text_input","z":"86829614.e78918","name":"Hint 2","label":"Hint 2","tooltip":"tooltip","group":"9bce1c47.a279c","order":11,"width":"24","height":"2","passthru":true,"mode":"text","delay":300,"topic":"","x":270,"y":160,"wires":[[]]},{"id":"d5161954.eb33c","type":"ui_text_input","z":"86829614.e78918","name":"Hint 3","label":"Hint 3","tooltip":"tooltip","group":"9bce1c47.a279c","order":12,"width":"24","height":"2","passthru":true,"mode":"text","delay":300,"topic":"","x":270,"y":220,"wires":[[]]},{"id":"27667717.864ae8","type":"ui_text_input","z":"86829614.e78918","name":"Antwoord","label":"Antwoord","tooltip":"tooltip","group":"9bce1c47.a279c","order":13,"width":"24","height":"2","passthru":true,"mode":"text","delay":300,"topic":"","x":280,"y":280,"wires":[[]]},{"id":"7d61bf28.0d4e7","type":"ui_dropdown","z":"86829614.e78918","name":"Audio theme select","label":"Audio theme","tooltip":"Selecteer audio thema","place":"Select option","group":"9bce1c47.a279c","order":16,"width":"5","height":"1","passthru":true,"options":[{"label":"","value":"","type":"str"}],"payload":"","topic":"","x":310,"y":340,"wires":[[]]},{"id":"6a6d18c2.55c75","type":"ui_dropdown","z":"86829614.e78918","name":"Audio hint select","label":"Audio hint","tooltip":"Selecteer audio hint","place":"Select option","group":"9bce1c47.a279c","order":18,"width":"5","height":"1","passthru":true,"options":[{"label":"","value":"","type":"str"}],"payload":"","topic":"","x":310,"y":400,"wires":[[]]},{"id":"3ac1ae80.a193a2","type":"ui_dropdown","z":"86829614.e78918","name":"Audio background select","label":"Audio background","tooltip":"Selecteer audio background","place":"Select option","group":"9bce1c47.a279c","order":22,"width":"5","height":"1","passthru":true,"options":[{"label":"","value":"","type":"str"}],"payload":"","topic":"","x":330,"y":460,"wires":[[]]},{"id":"c7407d1f.a310a8","type":"ui_dropdown","z":"86829614.e78918","name":"game template select","label":"template","tooltip":"Selecteer game template","place":"Select option","group":"9bce1c47.a279c","order":7,"width":"8","height":"1","passthru":true,"options":[{"label":"","value":"","type":"str"}],"payload":"","topic":"","x":320,"y":40,"wires":[[]]},{"id":"958d06af.88e83","type":"ui_button","z":"86829614.e78918","name":"stop theme","group":"9bce1c47.a279c","order":15,"width":"1","height":"1","passthru":false,"label":"","tooltip":"","color":"","bgcolor":"","icon":"fa-stop","payload":"stop","payloadType":"str","topic":"","x":830,"y":340,"wires":[[]]},{"id":"2662a1ae.e9c536","type":"ui_button","z":"86829614.e78918","name":"play theme","group":"9bce1c47.a279c","order":14,"width":"1","height":"1","passthru":false,"label":"","tooltip":"","color":"","bgcolor":"","icon":"fa-play","payload":"play","payloadType":"str","topic":"","x":610,"y":340,"wires":[[]]},{"id":"4c8c11fd.0f22b","type":"ui_button","z":"86829614.e78918","name":"stop hint","group":"9bce1c47.a279c","order":20,"width":"1","height":"1","passthru":false,"label":"","tooltip":"","color":"","bgcolor":"","icon":"fa-stop","payload":"stop","payloadType":"str","topic":"","x":820,"y":400,"wires":[[]]},{"id":"898dc98d.7f31e","type":"ui_button","z":"86829614.e78918","name":"play hint","group":"9bce1c47.a279c","order":19,"width":"1","height":"1","passthru":false,"label":"","tooltip":"","color":"","bgcolor":"","icon":"fa-play","payload":"play","payloadType":"str","topic":"","x":600,"y":400,"wires":[[]]},{"id":"bcf87f77.df5418","type":"ui_button","z":"86829614.e78918","name":"stop background","group":"9bce1c47.a279c","order":24,"width":"1","height":"1","passthru":false,"label":"","tooltip":"","color":"","bgcolor":"","icon":"fa-stop","payload":"stop","payloadType":"str","topic":"","x":850,"y":460,"wires":[[]]},{"id":"b76869f4.5aeb88","type":"ui_button","z":"86829614.e78918","name":"play background","group":"9bce1c47.a279c","order":23,"width":"1","height":"1","passthru":false,"label":"","tooltip":"","color":"","bgcolor":"","icon":"fa-play","payload":"play","payloadType":"str","topic":"","x":630,"y":460,"wires":[[]]},{"id":"c30a04ef.30a83","type":"ui_slider","z":"86829614.e78918","name":"theme volume","label":"slider","tooltip":"","group":"9bce1c47.a279c","order":17,"width":"5","height":"1","passthru":true,"outs":"end","topic":"","min":0,"max":10,"step":1,"x":1060,"y":340,"wires":[[]]},{"id":"13367898.686ccf","type":"ui_slider","z":"86829614.e78918","name":"hint volume","label":"slider","tooltip":"","group":"9bce1c47.a279c","order":21,"width":"5","height":"1","passthru":true,"outs":"end","topic":"","min":0,"max":10,"step":1,"x":1050,"y":400,"wires":[[]]},{"id":"511a0383.04e3dc","type":"ui_slider","z":"86829614.e78918","name":"background volume","label":"slider","tooltip":"","group":"9bce1c47.a279c","order":25,"width":"5","height":"1","passthru":true,"outs":"end","topic":"","min":0,"max":10,"step":1,"x":1080,"y":460,"wires":[[]]},{"id":"d6412814.1015a8","type":"ui_dropdown","z":"86829614.e78918","name":"next step select","label":"next step","tooltip":"Volgende stap","place":"Select option","group":"9bce1c47.a279c","order":8,"width":"8","height":"1","passthru":true,"options":[{"label":"","value":"","type":"str"}],"payload":"","topic":"","x":560,"y":40,"wires":[[]]},{"id":"60bd4ec6.d7cb58","type":"ui_switch","z":"86829614.e78918","name":"","label":"Show timer?","tooltip":"Timer zichtbaar?","group":"9bce1c47.a279c","order":26,"width":"6","height":"1","passthru":true,"decouple":"false","topic":"","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","x":310,"y":560,"wires":[[]]},{"id":"3e7c101e.64f8c8","type":"ui_switch","z":"86829614.e78918","name":"","label":"Final step","tooltip":"Laatste opdracht","group":"9bce1c47.a279c","order":27,"width":"6","height":"1","passthru":true,"decouple":"false","topic":"","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","x":300,"y":620,"wires":[[]]},{"id":"c95cb0b.77c82d","type":"ui_dropdown","z":"86829614.e78918","name":"photo function","label":"photo","tooltip":"Foto functie","place":"Select option","group":"9bce1c47.a279c","order":9,"width":"8","height":"1","passthru":true,"options":[{"label":"","value":"","type":"str"}],"payload":"","topic":"","x":780,"y":40,"wires":[[]]},{"id":"9c7b2bdb.782ba8","type":"ui_button","z":"86829614.e78918","name":"save","group":"9bce1c47.a279c","order":1,"width":"4","height":"1","passthru":false,"label":"SAVE","tooltip":"","color":"","bgcolor":"","icon":"fa-save","payload":"save","payloadType":"str","topic":"","x":250,"y":700,"wires":[[]]},{"id":"347da4f1.57c8f4","type":"ui_button","z":"86829614.e78918","name":"new","group":"9bce1c47.a279c","order":2,"width":"4","height":"1","passthru":false,"label":"","tooltip":"","color":"","bgcolor":"","icon":"fa-save","payload":"NEW","payloadType":"str","topic":"","x":410,"y":700,"wires":[[]]},{"id":"6c10604e.38b18","type":"ui_button","z":"86829614.e78918","name":"save","group":"9bce1c47.a279c","order":3,"width":"4","height":"1","passthru":false,"label":"","tooltip":"","color":"","bgcolor":"","icon":"fa-save","payload":"Load","payloadType":"str","topic":"","x":570,"y":700,"wires":[[]]},{"id":"8ce5495e.848df","type":"ui_button","z":"86829614.e78918","name":"save","group":"9bce1c47.a279c","order":4,"width":"4","height":"1","passthru":false,"label":"","tooltip":"","color":"","bgcolor":"","icon":"fa-save","payload":"save","payloadType":"str","topic":"","x":710,"y":700,"wires":[[]]},{"id":"81a36e21.a4f2a","type":"ui_button","z":"86829614.e78918","name":"save","group":"9bce1c47.a279c","order":5,"width":"4","height":"1","passthru":false,"label":"","tooltip":"","color":"","bgcolor":"","icon":"fa-save","payload":"save","payloadType":"str","topic":"","x":850,"y":700,"wires":[[]]},{"id":"4983e150.378938","type":"ui_button","z":"86829614.e78918","name":"save","group":"9bce1c47.a279c","order":6,"width":"4","height":"1","passthru":false,"label":"","tooltip":"","color":"","bgcolor":"","icon":"fa-save","payload":"save","payloadType":"str","topic":"","x":990,"y":700,"wires":[[]]},{"id":"9bce1c47.a279c","type":"ui_group","z":"","name":"Controls","tab":"ddfa73a0.7527c","order":1,"disp":true,"width":"24","collapse":false},{"id":"ddfa73a0.7527c","type":"ui_tab","z":"","name":"Game play screen","icon":"fa-cogs","order":1,"disabled":false,"hidden":false}]
Thanks!
K . Will have a look when I get to computer
