CSS - ui_template new ck-button widget text is not centered vertically
I am trying to style a ui_template button. Using 'width: 100%' works OK in that the rendered button follows the chosen width for the widget.
How can I do the same for height ?
I have tried 'height: 100%'.
Or where do I find more info relating to this problem ?
EDIT: fixed by stripping out as much css as possible.
Did you search the forum? I seem to remember that this was answered in the last few days.
Thanks for your response and yes I have. This CSS malarkey is a slippery creature.
I have just got a result by trial and error and stripping out as much css as possible. I see others have recommended making single adjustments and verifying result then backing out if no effect. I can confirm that unless you fully understand the css involved then there is no other way forward.
I have just one problem now (famous last words) and that is the vertical position of the text.
Do I edit the title of this post accordingly ?
[{"id":"bef9867d.b18028","type":"ui_template","z":"503e64bc.acab6c","group":"c3500612.c24038","name":":r8g1","order":3,"width":"1","height":1,"format":"<!--\n    V1\n    ==\n//-->\n<div>\n<md-button class=\"md-button ck-button ck-switch on off small\" \n    data-payload=\"1\" \n    data-buttontype=\"radio\"\n    data-radiogroup='group1'\n    data-topic=\"8\"\n    >\n    <div class=\"ck-button\">\n       <label class=\"ck-switch\">\n          <input type=\"checkbox\" unchecked>\n            <span style=\"background-color:#00cc00\" class=\"on\">btn<br>on</span>\n            <span style=\"background-color:#006600\" class=\"off\">btn<br>off</span>\n        </label>\n    </div>\n</md-button>\n</div>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":90,"y":100,"wires":[[]]},{"id":"fdb1290a.963198","type":"ui_template","z":"503e64bc.acab6c","group":"c3500612.c24038","name":"CSS only ","order":2,"width":0,"height":0,"format":"/!--\n\n-->\n<style>\n    .nr-dashboard-template {\n        padding: 0px;\n    }\n/* New ck-button */    \n.ck-switch {\n    height: 100%;\n  position: relative;\n  display: inline-block;\n}\n\n.ck-switch input {\n    display: none;\n}\n\n.off {\n    margin: -6px;\n    padding: 6px;\n  position: absolute;\n  top: 0px;\n  height: 100%;\n  width: 100%;\n  opacity: 1;\n  background-color: #911;\n  color: white;\n}\n.on {\n    height: 100%;\n    margin: -6px;\n    padding: 6px;\n  color: white;\n}\n.ck-button input:checked + .on {\n  opacity: 1;\n  background-color: #911;\n  color: white;\n}\n.ck-button input:checked + span + .off {\n  opacity: 0;\n  background-color: #911;\n}\n\n\n.ck-button {\n    width: 100%;\n    height: 100%;\n    margin: -6px;\n    padding: 6px;\n\n/* ok  margin: 4px;*/\n/*new height: var(--dashboard-unit-height); */\n/*new        min-height: var(--dashboard-min-height);*/\n        min-height: unset;\n        min-width: unset;\n        line-height: unset;\n  background-color: #EFEFEF;\n/*OK  border-radius: 10px;*/\n/*  border: 1px solid #D0D0D0;*/\n  overflow: hidden;\n  float: left;\n}\n\n.ck-button:hover {\n/*    margin: 0;*/\n/* ok  margin: 4px;*/\n  background-color: #EFEFEF;\n/*OK  border-radius: 10px;*/\n/*  border: 1px solid red;*/\n  overflow: hidden;\n  float: left;\n  color: red;\n}\n\n.ck-button label {\n    height: 100%;\ntext-align: center;\n  float: left;\n  width: 100%;\n}\n\n.ck-button label span {\n    margin: -6px;\n    padding: 6px;\n/*New            height: var(--dashboard-unit-height);*/\n/*New        min-height: var(--dashboard-min-height);*/\n        min-height: unset;\n        min-width: unset;\n        line-height: unset;\n\n  text-align: center;\n/*  padding: 3px 0px; */\n/*\n    margin: -4px;\n  padding: 4px;\n  */\n  display: block;\n}\n\n.ck-button label input {\n  position: absolute;\n  top: -20px;\n}\n/*\nCSS\n---\n.ck-switch {\n  position: relative;\n  display: inline-block;\n}\n\n.ck-switch input { display: none; }\n\n.off {\n  position: absolute;\n  top: 0px;\n  width: 100%;\n  opacity: 1;\n  background-color: #911;\n  color: white;\n}\n.on {\n  color: white;\n}\n.ck-button input:checked + .on {\n  opacity: 1;\n  background-color: #911;\n  color: white;\n}\n.ck-button input:checked + span + .off {\n  opacity: 0;\n  background-color: #911;\n}\n\n\n.ck-button {\n  margin: 4px;\n  background-color: #EFEFEF;\n  border-radius: 4px;\n  border: 1px solid #D0D0D0;\n  overflow: auto;\n  float: left;\n}\n\n.ck-button:hover {\n  margin: 4px;\n  background-color: #EFEFEF;\n  border-radius: 4px;\n  border: 1px solid red;\n  overflow: auto;\n  float: left;\n  color: red;\n}\n\n.ck-button label {\n  float: left;\n  width: 4em;\n}\n\n.ck-button label span {\n  text-align: center;\n  padding: 3px 0px;\n  display: block;\n}\n\n.ck-button label input {\n  position: absolute;\n  top: -20px;\n}\n\n<md-button class=\"md-button remote-buttonOld3x bigger\" \n    data-payload=\"1\" \n    data-buttontype=\"radio\"\n    data-radiogroup='group1'\n    data-topic=\"8\"\n    >\n    <div class=\"ck-button\">\n       <label class=\"ck-switch\">\n          <input type=\"checkbox\" value=\"1\">\n            <span style=\"background-color:#00cc00\" class=\"on\">red<br>on</span>\n            <span style=\"background-color:#006600\" class=\"off\">red<br>off</span>\n        </label>\n    </div>\n</md-button>\n</div>\n*/\n\n</style>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"global","x":100,"y":60,"wires":[[]]},{"id":"1237f7a0.5cace8","type":"ui_template","z":"503e64bc.acab6c","group":"c3500612.c24038","name":":r9g1","order":3,"width":"2","height":1,"format":"<!--\n    V1\n    ==\n//-->\n<div>\n<md-button class=\"md-button ck-button ck-switch on off\" \n    data-payload=\"1\" \n    data-buttontype=\"radio\"\n    data-radiogroup='group1'\n    data-topic=\"9\"\n    >\n    <div class=\"ck-button\">\n       <label class=\"ck-switch\">\n          <input type=\"checkbox\" checked>\n            <span style=\"background-color:#00cc00\" class=\"on\">9:1<br>on</span>\n            <span style=\"background-color:#006600\" class=\"off\">9:0<br>off</span>\n        </label>\n    </div>\n</md-button>\n</div>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":230,"y":100,"wires":[[]]},{"id":"bb33fa8e.a48f68","type":"ui_template","z":"503e64bc.acab6c","group":"c3500612.c24038","name":"r10g1","order":3,"width":"2","height":1,"format":"<!--\n    V1\n    ==\n//-->\n<div>\n<md-button class=\"md-button ck-button ck-switch on off bigger\" \n    data-payload=\"1\" \n    data-buttontype=\"radio\"\n    data-radiogroup='group1'\n    data-topic=\"10\"\n    >\n    <div class=\"ck-button\">\n       <label class=\"ck-switch\">\n          <input type=\"checkbox\" checked>\n            <span style=\"background-color:#00cc00\" class=\"on\">btn<br>on</span>\n            <span style=\"background-color:#006600\" class=\"off\">btn<br>off</span>\n        </label>\n    </div>\n</md-button>\n</div>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":90,"y":140,"wires":[[]]},{"id":"b856ea19.2280f8","type":"ui_template","z":"503e64bc.acab6c","group":"c3500612.c24038","name":":r11g1","order":3,"width":"2","height":"2","format":"<!--\n    V1\n    ==\n    <div class=\"ck-button\">\n       <label class=\"ck-switch\">\n          <input type=\"checkbox\">\n            <span style=\"background-color:#00cc00\" class=\"on\">11:1</span>\n            <span style=\"background-color:#006600\" class=\"off\">11:0</span>\n        </label>\n    </div>\n    \n//-->\n<div>\n<md-button class=\"md-button ck-button ck-switch on off bigger\" \n    data-payload=\"1\" \n    data-buttontype=\"radio\"\n    data-radiogroup='group1'\n    data-topic=\"11\"\n    >\n\n    <div class=\"ck-button\">\n       <label class=\"ck-switch\">\n          <input type=\"checkbox\">\n            <span style=\"background-color:#00cc00\" class=\"on\">11:1<br>on</span>\n            <span style=\"background-color:#006600\" class=\"off\">11:0<br>off</span>\n        </label>\n    </div>\n</md-button>\n</div>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":230,"y":140,"wires":[[]]},{"id":"eacf7593.fa2ca8","type":"ui_button","z":"503e64bc.acab6c","name":"","group":"c3500612.c24038","order":6,"width":"2","height":"2","passthru":false,"label":"button","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":110,"y":180,"wires":[[]]},{"id":"c3500612.c24038","type":"ui_group","z":"","name":"Btn2","tab":"94f74e9f.6a717","order":1,"disp":true,"width":"4","collapse":false},{"id":"94f74e9f.6a717","type":"ui_tab","z":"503e64bc.acab6c","name":"TEST","icon":"dashboard","order":7,"disabled":false,"hidden":false}]
Not sure what to offer on aligning the button text. Maybe someone else will chime in.
Hi all, What a roller coaster. After two days in the plughole of time (otherwise known as CSS) I have emerged with a massive improvement.
I got there by stripping the new css of all except the essential to the basic function of the latching button style using jsfiddle.
I then removed all unessential css in the css header node and gradually added an element at a time. A bit like walking a tightrope blindfold wearing ice skates.
During the process I have lost other working functions like the radio buttons so the code is a bit of a mess but the CSS styling may be useful.
Thanks for all the help so far, any help with the two radio buttons would be most welcome.
[{"id":"5666698b.c679c8","type":"inject","z":"503e64bc.acab6c","name":" disabled, on 11","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"11","payload":"{\"command\":\"toggleClass\",\"value\":\"disabled\"}","payloadType":"json","x":120,"y":360,"wires":[["d63508d7.9bea48"]]},{"id":"c3be9084.fc1fe","type":"inject","z":"503e64bc.acab6c","name":"9:0","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"9","payload":"0","payloadType":"num","x":90,"y":200,"wires":[["d63508d7.9bea48"]]},{"id":"35d1aadc.5941e6","type":"inject","z":"503e64bc.acab6c","name":"9:1","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"9","payload":"1","payloadType":"num","x":90,"y":240,"wires":[["d63508d7.9bea48"]]},{"id":"2f8b4bb4.988a54","type":"debug","z":"503e64bc.acab6c","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":330,"y":400,"wires":[]},{"id":"bef9867d.b18028","type":"ui_template","z":"503e64bc.acab6c","group":"c3500612.c24038","name":":r8g1","order":3,"width":"1","height":1,"format":"<!--\n    V1\n    ==\n//-->\n<div>\n<md-button class=\"md-button ck-button on off small\" \n    data-payload=\"1\" \n    data-buttontype=\"radio\"\n    data-radiogroup='group1'\n    data-topic=\"8\"\n    >\n    <div class=\"ck-button\">\n        <label class=\"ck-switch\">\n            <input type=\"checkbox\" unchecked>\n            <div style=\"background-color:#cc0000\" class=\"on\">btn<br>on</div>\n            <div style=\"background-color:#660000\" class=\"off\">btn<br>off</div>\n        </label>\n    </div>\n</md-button>\n</div>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":310,"y":160,"wires":[[]]},{"id":"fdb1290a.963198","type":"ui_template","z":"503e64bc.acab6c","group":"c3500612.c24038","name":"CSS only ","order":2,"width":0,"height":0,"format":"/!--\n\n-->\n<style>\n    .nr-dashboard-template {\n        padding: 0px;\n    }\n    .md-button {\n        border-radius: 10px;\n    }\n    .md-button:hover {\n        border:1px solid red;\n    }\n    .bigger{\n        font-size:1.5em;\n    }\n    .bold {\n        font-weight:bold;\n    }\n    /*  This is for buttons with a lot of text.  `font-size:0.7em` */\n    /*  makes the font 70% normal size  */\n    .small{\n        font-size:0.7em;\n    }\n\n\n    /* New ck-button */    \n    .ck-button.disabled{\n        pointer-events: none;\n        opacity: 0.5;\n    }\n    .ck-switch {\n        position: relative;\n    }\n    \n    .ck-switch input {\n        display: none;\n    }\n    \n    .off {\n        position: absolute;\n        top: 0px;\n        height: 100%;\n        width: 100%;\n        opacity: 1;\n    }\n    .on {\n        height: 100%;\n    }\n    .ck-button input:checked + .on {\n        opacity: 1;\n    }\n    .ck-button input:checked + div + .off {\n        opacity: 0;\n    }\n    \n    \n    .ck-button {\n        margin: -6px;\n        padding: 6px;\n        width: 100%;\n        height: 100%;\n        overflow: auto;\n    }\n    \n    .ck-button label {\n        height: 100%;\n        text-align: center;\n        float: left;\n        width: 100%;\n    }\n    \n    .ck-button label div {\n        margin: -6px;\n        padding: 6px;\n        text-align: center;\n        display: block;\n    }\n    \n    .ck-button label input {\n        position: absolute;\n        top: -20px;\n    }\n    .ck-button label div {\n/*ok        white-space: normal;*/\nwhite-space:pre-wrap;\n        word-break: break-word;\n        display: flex;\n        align-items: center;\n        justify-content: center;\n    }\n/*\nHTML\n====\n<div>\n<md-button class=\"md-button ck-button ck-switch on off small\" \n    data-payload=\"1\" \n    data-buttontype=\"radio\"\n    data-radiogroup='group1'\n    data-topic=\"8\"\n    >\n    <div class=\"ck-button\">\n        <label class=\"ck-switch\">\n            <input type=\"checkbox\" unchecked>\n            <div style=\"background-color:#00cc00\" class=\"on\">btn<br>on</div>\n            <div style=\"background-color:#006600\" class=\"off\">btn<br>off</div>\n        </label>\n    </div>\n</md-button>\n</div>\n*/\n\n</style>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"global","x":100,"y":40,"wires":[[]]},{"id":"bc2d0de2.d27c8","type":"comment","z":"503e64bc.acab6c","name":"data-buttontype:checkbox","info":"","x":130,"y":80,"wires":[]},{"id":"ee44ef95.2afab","type":"inject","z":"503e64bc.acab6c","name":"disabled, on 9","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"9","payload":"{\"command\":\"toggleClass\",\"value\":\"disabled\"}","payloadType":"json","x":110,"y":160,"wires":[["d63508d7.9bea48"]]},{"id":"d63508d7.9bea48","type":"ui_template","z":"503e64bc.acab6c","group":"c3500612.c24038","name":"script for all buttons with class .remote-button3x","order":14,"width":"0","height":"0","format":"<div>\n<!--diliberately emtpy - only need the script below -->\n</div>\n\n<script>\n\n(function($scope) {\n//debugger\n\n    //cause a small delay while things load \n    //ideally this would be an init event or on all parts of document loaded\n    //(may not be necessary!)\n    setTimeout(function() {\n        //debugger\n        $scope.init();\n    },100);\n    \n    \n    //SETTINGS...\n    var BUTTON_CLASS = \".ck-button\";\n    var SEND_0_FOR_CLEARED_RADIO_BUTTONS = true;\n    var SEND_ONLY_STATE_CHANGES_FOR_RADIO_BUTTONS = true;\n    \n    \n    /** \n     * Initialise all buttons with class BUTTON_CLASS\n    */\n    $scope.init = function () {\n        //debugger\n        console.log(\"$scope.init called. Adding event handlers to all buttons with class '\" + BUTTON_CLASS + \"'.\");\n        var clickButtons = $(BUTTON_CLASS + \":not([data-buttontype='repeater'])\") \n//        var clickButtons = $(BUTTON_CLASS) \n        clickButtons.click(function(e){\n            \n            var btn = $(this)\n            var type = btn.data(\"buttontype\");//get the button type from attribute data-buttontype=\"xxxxx\"\n            var topic = btn.data(\"topic\");//get the topic from attribute data-topic=\"xxxxx\"\n            var payload = btn.data(\"payload\");//get the payload from attribute data-payload=\"xxxxx\"\n            // debugger\n            if(type == \"radio\"){\n                setRadioButton(btn, true);\n            } else if(type == \"toggle\"){\n                var state = btn.data(\"state\") || 0;//get the last state payload from attribute data-state=\"n\"\n                var newPayload = state == 1 ? 0 : 1;\n                setButtonState(btn,newPayload)\n                var tm = {\"type\": type, \"topic\":topic,\"payload\":newPayload, \"event\": \"click\"}\n                console.log(\"Sending msg for clicked toggle button\", tm)\n                $scope.send(tm)\n            } else if(type == \"checkbox\"){\n                var group = btn.data(\"radiogroup\") || null;\n                var state = btn.data(\"state\") || 0;//get the last state payload from attribute data-state=\"n\"\n                var newPayload = state == 1 ? 0 : 1;\n                if(group) {\n                    setRadioButton(btn, true);\n                } else {\n                    setButtonState(btn,newPayload)\n                    var tm = {\"type\": type, \"topic\":topic,\"payload\":newPayload, \"event\": \"click\"}\n                    console.log(\"Sending msg for clicked checkbox button\", tm)\n                    $scope.send(tm)\n                }\n            } else {\n                var sm = {\"class\": BUTTON_CLASS, \"new type\": type, \"topic\":topic,\"payload\":payload, \"event\": \"click\"}\n                console.log(\"Sending msg for clicked button\", tm)\n                $scope.send(sm)\n            }\n        });\n        var repeatButtons = $(BUTTON_CLASS + \"[data-buttontype='repeater']\") \n        repeatButtons.on('mousedown touchstart',function(e) {\n            e.preventDefault();\n            e.stopPropagation();\n            console.log(e.type);//remove me after debugging\n            var btn = this;\n            var $btn = $(btn);\n            if(btn._intervalId) return; //already in operation\n            btn._topic = $btn.data(\"topic\");//get the topic from attribute data-topic=\"xxxxx\"\n            btn._payload = $btn.data(\"payload\");//get the payload from attribute data-payload=\"xxxxx\"\n            btn._interval = $btn.data(\"interval\");//get the desired repeat duration\n            if(isNumeric(btn._interval) == false || btn._interval < 1) btn._interval = 300;//prevent zero & non numeric timeout value\n            var max = $btn.data(\"max\");//get the max repeat count\n            if(isNumeric(max) && max > 0) \n                btn._max = parseInt(max);\n            else\n                btn._max = undefined;\n            btn._count = 1;\n            $scope.send({\"topic\":btn._topic,\"payload\":btn.payload,\"event\":\"down\", \"count\": btn._count})\n            btn._lastevent = \"down\";\n            //remove any existing timer\n            if(btn._intervalId){\n                clearInterval(btn._intervalId);\n                btn._intervalId = null;\n            }\n            //start the timer if conditions are ok\n            if(!btn._max || (btn._max && btn._count < btn._max)){\n                btn._intervalId = setInterval(function() {\n                    if(btn._max && btn._count >= btn._max){\n                        clearInterval(btn._intervalId);\n                        btn._intervalId = null;\n                        return;\n                    }                    \n                    btn._count = btn._count + 1;\n                    $scope.send({\"topic\":btn._topic,\"payload\":btn.payload,\"event\":\"down\", \"count\": btn._count})\n                },btn._interval); \n            }\n        }).on('mouseup blur focusout mouseout touchend',function(e) {\n            e.preventDefault();\n            e.stopPropagation();\n            console.log(e.type);//remove me after debugging\n            var btn = this;\n            var $btn = $(btn);\n            \n            //next, if data-fireonup == true, then fire up event\n            var sendUpEvent = $btn.data(\"fireonup\") == true;\n            if(sendUpEvent && btn._lastevent === \"down\"){\n                btn._lastevent = \"up\"\n                $scope.send({\"topic\":btn._topic,\"payload\":btn._payload,\"event\":\"up\"})\n            }\n            \n            //finally, if the timer id is still valid, clear it (stop repeater)\n            if(btn._intervalId){\n                clearInterval(btn._intervalId);//stop timer\n                btn._intervalId = null;//clear timer id\n            }\n        });        \n        \n    };\n\n    //watch for node-red msgs\n    $scope.$watch('msg', function(msg) {\n        //debugger\n        if(!msg){ //if no msg \n            console.log(\"$scope.$watch('msg', ...) - msg is empty\");\n            return;\n        }\n        if(!msg.topic){ //if no topic set found\n            console.log(\"msg.topic is empty - cannot match this to any button\")\n            return; //stop processing!\n        }\n        var buttonSelector =  BUTTON_CLASS + \"[data-topic='\" + msg.topic + \"']\" \n        var $btn = $(buttonSelector);//get the button\n        if(!$btn.length){ //if no button found\n            console.log(buttonSelector + \" not found - cannot set state\")\n            return; //stop processing!\n        }\n\n        if($btn.length > 1){ //if MORE than one button found\n            console.log(buttonSelector + \" found more than 1 button - is this intended? Do you have the same data-topic set on multiple buttons?\")\n        }\n        \n        //see if this is a command - if so, process the command\n        if(typeof msg.payload === \"object\" && msg.payload.command){\n            processCommand($btn, msg.payload)\n            return;\n        }        \n        \n        if($btn.data(\"buttontype\") === \"radio\"){\n            setRadioButton($btn, false);\n        }\n        if($btn.data(\"buttontype\") === \"toggle\"){\n            if(msg.payload == \"1\"){\n                setButtonState($btn, 1);\n            } else if(msg.payload == \"0\"){\n                setButtonState($btn, 0);\n            } else {\n               console.log(\"Invalid toggle value in msg.payload, cannot set \" + buttonSelector + \". Ensure msg.payload is either 0 or 1\") \n            }\n        }\n//<md-button class=\"md-button remote-button3x bigger\" \n//    data-payload=\"1\" \n//    data-buttontype=\"checkbox\"\n//    data-topic=\"10\"\n//    >\n//   <label class=\"remote-button3x-switch\">\n//        <input type=\"checkbox\" id=\"10\">\n//        <div class=\"remote-button3x-slider round\">\n//            <span class=\"remote-button3x-on\">O-N</span><span class=\"remote-button3x-off\">O-F-F</span>\n//        </div>\n//    </label>       \n//</md-button>    \n        if($btn.data(\"buttontype\") === \"checkbox\"){\n            var group = $btn.data(\"radiogroup\");\n            var groupBtns = $(\"[data-radiogroup='\"+group+\"']\");\n            var m = null;\n            if(groupBtns.length>0) {\n                setRadioButton($btn, false);\n            } else {\n                var oldState;                \n                var $chck=$btn.find(\"input[type=checkbox]\");//get the checkbox\n                var $state=$chck.is(\":checked\");\n                console.log(\"$chck=\" + $state);\n                if(msg.payload == \"1\"){\n                    if(!$state) {\n                        $chck.prop('checked',true);\n                        oldState=setButtonState($btn, 1);\n                    }\n                } else if(msg.payload == \"0\"){\n                    // Not sure if this can happen ?\n                    // a click on a radio button is always 1\n                    if($state) {\n                        $chck.prop('checked',false);\n                        oldState=setButtonState($btn, 0);\n                    }\n //           setButtonState($btn, 1);\n                } else {\n                    console.log(\"Invalid checkbox value in msg.payload, cannot set \" + buttonSelector + \". Ensure msg.payload is either 0 or 1\") \n                }\n            }\n            setButtonState($btn, 1);\n        }\n\n\n    }); \n    \n    /** \n    * helper function to set the correct icon & update the \"data-payload\" memory \n    */\n    function setButtonState($btn, state){\n        console.log(\"setButtonState\", $btn[0], state);\n        var oldState = $btn.data(\"state\");\n        $btn.data(\"state\", state);//set data-payload to new state value (used as a memory)\n        \n        //determine the opposite state\n        var oppositeState;\n        if(state == \"1\" || state === 1){\n            state = 1; //normalise to a number\n            oppositeState = 0;\n        } else {\n            state = 0; //normalise to a number\n            oppositeState = 1;\n        }\n        \n        var $icon = $btn.find(\"i\"); //get the <i> element\n        if(!$icon.length){\n            var btntype=$btn.data(\"buttontype\");\n            if( btntype !== \"checkbox\") {\n                $icon = $btn.find(\"span\"); //get the <span> element instead!\n            }\n        }\n        if(!$icon.length && btntype !== \"checkbox\"){\n            console.log(\"<i> or <span> not found inside button - cant toggle the icon!\")\n            return oldState;//exit this function - nothing to toggle!\n        }\n        \n        //get the old icon and new icon names\n        var oldIcon = $btn.data(\"icon\" + oppositeState); //get icon1 or icon2 depending on oppositeState\n        var newIcon = $btn.data(\"icon\" + state); //get icon1 or icon2 depending on newPayload\n       \n        //if we have newIcon and an actual DOM element ($icon) - update it...\n        if(newIcon && $icon.length){\n            if(newIcon.includes(\"fa-\")){ \n                $icon.removeClass(oldIcon).addClass(newIcon);  // fontawesome\n            } else { \n                $icon.text(newIcon); // MDI\n            }\n        }\n        return oldState;\n    }\n\n\n    /** \n    * helper function \n    */\n    function setRadioButton($btn, sendMsgs){\n// original\n//                var state = btn.data(\"state\") || 0;//get the last state payload from attribute data-state=\"n\"\n//                var newPayload = state == 1 ? 0 : 1;\n//                setButtonState(btn,newPayload)\n//                var tm = {\"type\": type, \"topic\":topic,\"payload\":newPayload, \"event\": \"click\"}\n//                console.log(\"Sending msg for clicked checkbox button\", tm)\n//                $scope.send(tm)\n// checkbox\n//                var oldState;                \n//                var $chck=$btn.find(\"input[type=checkbox]\");//get the checkbox\n//                var $state=$chck.is(\":checked\");\n//                console.log(\"$chck=\" + $state);\n//                if(msg.payload == \"1\"){\n//                    if(!$state) {$chck.prop('checked',true);}\n// //           setButtonState($btn, 1);\n//                } else if(msg.payload == \"0\"){\n//                    if($state) {$chck.prop('checked',false);}\n// //           setButtonState($btn, 1);\n//                } else {\n//                    console.log(\"Invalid checkbox value in msg.payload, cannot set \" + buttonSelector + \". Ensure msg.payload is either 0 or 1\") \n//                }\n\n\n\n        var $chck=$btn.find(\"input[type=checkbox]\");//get the checkbox\n        var topic = $btn.data(\"topic\");//get the topic from attribute data-topic=\"xxxxx\"\n        var group = $btn.data(\"radiogroup\");\n        var groupBtns = $(\"[data-radiogroup='\"+group+\"']\");\n        var m = null;\n        for(var i = 0; i < groupBtns.length; i++) {\n            var oldState;\n            var rb = $(groupBtns[i]);\n            if(!rb || !rb.length) continue;\n            var t = rb.data(\"topic\");\n            if(t == topic) continue;//skip clicked button\n            oldState = setButtonState(rb,0);\n            if(sendMsgs && SEND_0_FOR_CLEARED_RADIO_BUTTONS) {\n                if(SEND_ONLY_STATE_CHANGES_FOR_RADIO_BUTTONS && oldState == 0) continue;\n                m = {\"type\": \"checkbox\", \"topic\":t,\"payload\":0, \"event\": \"click\"};\n                console.log(\"Sending 0 payload for other radio button in group\", m)\n                $scope.send(m);\n            }\n        }\n        if(sendMsgs) {\n//            var p = $btn.data(\"payload\");//get the payload from attribute data-payload=\"xxxxx\"\n//            var m = {\"type\": \"radio\", \"topic\":topic, \"payload\": p, \"event\": \"click\"};\n            var m = {\"type\": \"checkbox\", \"topic\":topic, \"payload\": 1, \"event\": \"click\"};\n            console.log(\"Sending msg for radio button\", m)\n            $scope.send(m);\n        }\n        setButtonState($btn,1);//set state of this button\n/*\n        setTimeout(function(){\n            setButtonState($btn,1);//set state of this button    \n        },200)        \n*/\n    }\n        \n    function processCommand($btn, payload){\n        //first check payload is correct format...\n        //{\"selector\":\".remote-button3x-on\",\"command\":\"setContent\",\"value\":\"HELLO\"}\n        if(!payload || !payload.command || !payload.value){\n            console.log(\"Cannot process command. Expected a payload object with .command and .value. \")\n        }\n        var cmd = payload.command.trim();\n        switch(cmd){\n            case \"addClass\":\n                $btn.addClass(payload.value); //this calls the jquery function by name (specified in .command) on the $btn and passes in .value\n                break;\n            case \"toggleClass\":\n                $btn.toggleClass(payload.value); //this calls the jquery function by name (specified in .command) on the $btn and passes in .value\n                break;\n             case \"setColour\":\n                var spanSelector = payload.selector.trim();\n                var $span = $btn.find(spanSelector);//get the span\n                console.log(\"$spanBefore=\" + $span.text() + \" $spanBefore=\" + payload.value);\n\n                $span.css({\"background-color\": payload.value});\n                \n//$btn.text(\"Hello world!\");\n              //  $btn.toggleClass(payload.value); //this calls the jquery function by name (specified in .command) on the $btn and passes in .value\n                break;\n             case \"setContent\":\n                var spanSelector = payload.selector.trim();\n                var $span = $btn.find(spanSelector);//get the span\n                console.log(\"$spanBefore=\" + $span.text() + \" $spanBefore=\" + payload.value);\n\n                $span.text(payload.value);\n                \n//$btn.text(\"Hello world!\");\n              //  $btn.toggleClass(payload.value); //this calls the jquery function by name (specified in .command) on the $btn and passes in .value\n                break;\n            case \"removeClass\":\n                $btn.removeClass(payload.value); //this calls the jquery function by name (specified in .command) on the $btn and passes in .value\n                break;\n            default:\n                console.log(\"command '\" + payload.command + \"' is not supported\")\n        }\n    }        \n        \n    /** \n    * helper function to determine a value is REALLY a number \n    */\n    function isNumeric(n){\n        if(n === \"\") return false;\n        if(n === true || n === false) return false;\n        return !isNaN(parseFloat(n)) && isFinite(n);\n    }\n   \n\n})(scope);\n</script>","storeOutMessages":false,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":275,"y":400,"wires":[["2f8b4bb4.988a54"]],"l":false},{"id":"2c95dab1.537be6","type":"inject","z":"503e64bc.acab6c","name":"10:0","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"10","payload":"0","payloadType":"num","x":90,"y":400,"wires":[["d63508d7.9bea48"]]},{"id":"b9742854.b0ff28","type":"inject","z":"503e64bc.acab6c","name":"10:1","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"10","payload":"1","payloadType":"num","x":90,"y":440,"wires":[["d63508d7.9bea48"]]},{"id":"2993cfb3.e315b","type":"inject","z":"503e64bc.acab6c","name":".on 9:button\\non 1","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"9","payload":"{\"selector\":\".on\",\"command\":\"setContent\",\"value\":\"button\\non 1\"}","payloadType":"json","x":130,"y":280,"wires":[["d63508d7.9bea48"]]},{"id":"3be9b0e2.b4ef3","type":"inject","z":"503e64bc.acab6c","name":".off 10:off","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"10","payload":"{\"selector\":\".off\",\"command\":\"setContent\",\"value\":\"off\"}","payloadType":"json","x":100,"y":480,"wires":[["d63508d7.9bea48"]]},{"id":"6395717.4416a9","type":"inject","z":"503e64bc.acab6c","name":".on 9:red","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"9","payload":"{\"selector\":\".on\",\"command\":\"setColour\",\"value\":\"#cc0000\"}","payloadType":"json","x":100,"y":320,"wires":[["d63508d7.9bea48"]]},{"id":"c7b32b4c.bf0798","type":"comment","z":"503e64bc.acab6c","name":"ck-button","info":"","x":320,"y":360,"wires":[]},{"id":"1237f7a0.5cace8","type":"ui_template","z":"503e64bc.acab6c","group":"c3500612.c24038","name":":t9","order":3,"width":"2","height":1,"format":"<!--\n    V1\n    ==\n    data-buttontype='radio'\n    data-radiogroup='group1'    \n//-->\n<div>\n<md-button class=\"md-button ck-button on off\" \n    data-payload=\"1\" \n    data-buttontype=\"checkbox\"\n    data-topic=\"9\"\n    >\n    <div class=\"ck-button\">\n        <label class=\"ck-switch\">\n            <input type=\"checkbox\" checked>\n            <div style=\"background-color:#00cc00\" class=\"on\">9:1<br>on</div>\n            <div style=\"background-color:#006600\" class=\"off\">9:0<br>off</div>\n        </label>\n    </div>\n</md-button>\n</div>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":310,"y":200,"wires":[[]]},{"id":"bb33fa8e.a48f68","type":"ui_template","z":"503e64bc.acab6c","group":"c3500612.c24038","name":"c11g1","order":3,"width":"1","height":"3","format":"<!--\n    V1\n    ==\n//-->\n<div>\n<md-button class=\"md-button ck-button on off small\" \n    data-payload=\"1\" \n    data-state=\"1\" \n    data-buttontype=\"checkbox\"\n    data-radiogroup='group1'\n    data-topic=\"11\"\n    >\n    <div class=\"ck-button\">\n        <label class=\"ck-switch\">\n            <input type=\"checkbox\" unchecked>\n            <div style=\"background-color:#097479);\" class=\"on\">radio<br>group1<br><br>btn 11<br>with a lot more text fun<br>on</div>\n            <div style=\"background-color:#003333;\" class=\"off\">radio<br>group1<br><br>btn 11<br>off</div>\n        </label>\n    </div>\n</md-button>\n</div>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":70,"y":600,"wires":[[]]},{"id":"b856ea19.2280f8","type":"ui_template","z":"503e64bc.acab6c","group":"c3500612.c24038","name":":r10g1","order":3,"width":"2","height":"2","format":"<!--\n    V1\n    ==\n    <div class=\"ck-button\">\n       <label class=\"ck-switch\">\n          <input type=\"checkbox\">\n            <span style=\"background-color:#0000ff\" class=\"on\">11:1</span>\n            <span style=\"background-color:#000066\" class=\"off\">11:0</span>\n        </label>\n    </div>\n    \n//-->\n<div>\n<md-button class=\"md-button ck-button on off bigger bold\" \n    data-payload=\"1\" \n    data-buttontype=\"checkbox\"\n    data-topic=\"10\"\n    >\n\n    <div class=\"ck-button\">\n        <label class=\"ck-switch\">\n            <input type=\"checkbox\">\n            <div style=\"background-color:#0000ff\" class=\"on\">10:1<br>on</div>\n            <div style=\"background-color:#000066\" class=\"off\">10:0<br>off</div>\n        </label>\n    </div>\n</md-button>\n</div>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":310,"y":240,"wires":[[]]},{"id":"eacf7593.fa2ca8","type":"ui_button","z":"503e64bc.acab6c","name":"","group":"c3500612.c24038","order":6,"width":"2","height":"2","passthru":false,"label":"button","tooltip":"","color":"","bgcolor":"","icon":"","payload":"","payloadType":"str","topic":"","x":310,"y":280,"wires":[[]]},{"id":"b6aa0725.b2a758","type":"ui_template","z":"503e64bc.acab6c","group":"c3500612.c24038","name":"r12g1","order":3,"width":"2","height":"2","format":"<!--\n    V1\n    ==\n//-->\n<div>\n<md-button class=\"md-button ck-button on off small\" \n    data-payload=\"1\" \n    data-state=\"1\" \n    data-buttontype=\"checkbox\"\n    data-radiogroup='group1'\n    data-topic=\"12\"\n    >\n    <div class=\"ck-button\">\n       <label class=\"ck-switch\">\n          <input type=\"checkbox\" unchecked>\n            <div style=\"background-color:#00aaaa\" class=\"on\">radio<br>group1<br><br>btn 12 with a lot morrrrrrrrrrrrrrrrrrrre text fun<br>on</div>\n            <div style=\"background-color:#097479\" class=\"off\">radio<br>group1<br><br>btn 12<br>off</div>\n        </label>\n    </div>\n</md-button>\n</div>","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":false,"templateScope":"local","x":210,"y":600,"wires":[[]]},{"id":"b2e90b1c.78bbc8","type":"comment","z":"503e64bc.acab6c","name":"data-buttontype:checkbox group1","info":"","x":150,"y":520,"wires":[]},{"id":"d706e1b9.853eb","type":"inject","z":"503e64bc.acab6c","name":"11:0","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"11","payload":"0","payloadType":"num","x":90,"y":640,"wires":[["d63508d7.9bea48"]]},{"id":"a61d6558.bdbe58","type":"inject","z":"503e64bc.acab6c","name":"11:1","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"11","payload":"1","payloadType":"num","x":90,"y":680,"wires":[["d63508d7.9bea48"]]},{"id":"731bf5a.fa03a0c","type":"inject","z":"503e64bc.acab6c","name":"12:0","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"12","payload":"0","payloadType":"num","x":230,"y":640,"wires":[["d63508d7.9bea48"]]},{"id":"dfbdd891.b006e8","type":"inject","z":"503e64bc.acab6c","name":"12:1","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"12","payload":"1","payloadType":"num","x":230,"y":680,"wires":[["d63508d7.9bea48"]]},{"id":"23ffa11f.b1acfe","type":"comment","z":"503e64bc.acab6c","name":"Disable/enable, change on/off text and on/off colour","info":"","x":210,"y":120,"wires":[]},{"id":"2eaffa84.972856","type":"comment","z":"503e64bc.acab6c","name":"Work in progress","info":"","x":100,"y":560,"wires":[]},{"id":"c3500612.c24038","type":"ui_group","z":"","name":"Btn2","tab":"94f74e9f.6a717","order":1,"disp":true,"width":"4","collapse":false},{"id":"94f74e9f.6a717","type":"ui_tab","z":"503e64bc.acab6c","name":"TEST","icon":"dashboard","order":7,"disabled":false,"hidden":false}]
