I am trying to create this table on a Node-Red dashboard:
I have been through this forum and other online advice and have found only complicated solutions discussing passing arrays to template nodes or ng-repeat (which did not like the strings). I have gotten very close but cannot reproduce the comma separator (due to using using parseFloat to Fixed). See just a couple of the references or examples below.
Is there a straightforward method to mix Strings (the first two columns) and Numbers with different decimal digits in a dynamic table in Node-Red dashboard? I have tried node-red-node-ui-table. Can I use ng-repeat for each row individually and change the format? Can I call each element in my array (msg.payload) individually in the template note code?
It also seems to me that toLocaleString() would solve my issue but I have red a few posts that this does not work with Node-Red. Does anyone know if this has been corrected?
Thanks for any ideas or additional references.
