Dashboard text-node change text color
Hello.
I would like to change the text color of a text node depending on the input.
-------- [IF switch is on show ON(green) else show OFF(red)]
From this page : https://dashboard.flowfuse.com/nodes/widgets/ui-text.html#dynamic-properties
I should be able to send msg.ui_update.color to the text-node and change the font color, but I cannot get this to work. Please help.
thanks
Bernard.
Hello and welcome to forum.
It starts working if you tick the Apply style
But the way it does the color change may surprise you a bit....
Hello, thank you very much for your help.
I did tick that box, did not work.
Obviously I am messing up somewhere, please post a example.
thank you very much.
Here you are
[{"id":"191ee848013e1267","type":"ui-text","z":"8240715f881ef736","group":"2c34b9c7d6324531","order":0,"width":0,"height":0,"name":"","label":"the text node","format":"{{msg.payload}}","layout":"row-spread","style":true,"font":"","fontSize":16,"color":"#bfbfbf","wrapText":false,"className":"","x":810,"y":1360,"wires":[]},{"id":"9f72c3b497988bd1","type":"inject","z":"8240715f881ef736","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"OFF","payloadType":"str","x":450,"y":1340,"wires":[["1f2ef2aa8b0e3a25"]]},{"id":"b5296ae047bcd9be","type":"inject","z":"8240715f881ef736","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"ON","payloadType":"str","x":450,"y":1380,"wires":[["1f2ef2aa8b0e3a25"]]},{"id":"1f2ef2aa8b0e3a25","type":"function","z":"8240715f881ef736","name":"function 10","func":"const c = msg.payload == \"OFF\" ? \"#ff0000\" : \"#00ff00\"\nmsg.ui_update = {\"color\":c}\nreturn msg;","outputs":1,"timeout":0,"noerr":0,"initialize":"","finalize":"","libs":[],"x":630,"y":1360,"wires":[["191ee848013e1267"]]},{"id":"2c34b9c7d6324531","type":"ui-group","name":"Devices","page":"7294756f31e17b81","width":"6","height":"1","order":2,"showTitle":false,"className":"dynamic-title","visible":"true","disabled":"false","groupType":"default"},{"id":"7294756f31e17b81","type":"ui-page","name":"Home","ui":"29792df7d7b05e2e","path":"/home","icon":"home","layout":"grid","theme":"52ba8a01d6eda628","breakpoints":[{"name":"Default","px":"0","cols":"3"},{"name":"Tablet","px":"576","cols":"6"},{"name":"Small Desktop","px":"768","cols":"9"},{"name":"Desktop","px":"1024","cols":"12"}],"order":9,"className":"","visible":"true","disabled":"false"},{"id":"29792df7d7b05e2e","type":"ui-base","name":"My Dashboard","path":"/dashboard","appIcon":"","includeClientData":false,"acceptsClientConfig":[],"showPathInSidebar":false,"showPageTitle":true,"navigationStyle":"default","titleBarStyle":"default"},{"id":"52ba8a01d6eda628","type":"ui-theme","name":"Mobile","colors":{"surface":"#ffffff","primary":"#0094ce","bgPage":"#eeeeee","groupBg":"#ffffff","groupOutline":"#cccccc"},"sizes":{"density":"default","pagePadding":"5px","groupGap":"5px","groupBorderRadius":"10px","widgetGap":"5px"}}]
Thank you very much for your help, will try that as soon as I get home.
is there a way to change the background color?
I don't see any options to do it with the ui_control.something-dedicated but definitely possible to apply some CSS using msg.class
i tried doing it, but it is affecting all the text nodes across the dashboard. need to see how to do a particular widget only.
Got it...
