Dashboard text node CSS help
I'm using the old dashboard text node and have added the CSS class of lyrics and I'm trying to get them to display correctly from the top while centered but I am not good with CSS yet. I believe a dashboard ui_template node with something like:
<style>
.lyrics {
</style>
is what is needed, but I can't seem to get it correct. Any hints would be much appreciated?
Nevermind, figured it out with just using the ui-template node instead.
<style>
    /* Styling for the container that holds the lyrics */
    /* Set the font family for the lyrics */
    .lyrics-container {
        font-family: Arial, sans-serif;
        /* Define the font size of the lyrics */
        font-size: 20px;
        /* Set the line height for better readability */
        line-height: 1.2;
        /* Allow line breaks to be displayed as entered in the text */
        white-space: pre-line;
        /* Position the container absolutely */
        position: absolute;
        /* Distance from the top of the container to the top of the page */
        top: 10px;
        /* Center the container horizontally using left and transform */
        left: 50%;
        transform: translateX(-50%);
        /* Make the lyrics bold for emphasis */
        font-weight: bold;
</style>
<!-- Display the lyrics within the styled container -->
<div class="lyrics-container" ng-bind-html="msg.payload"></div>
ChatGPT to the rescue, really saves me a ton of time with Node-RED even.
Ha I was just going to post this flow for you:
[{"id":"d4c590d2e9132950","type":"inject","z":"a7f288cd13e5b960","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"hello Harold<br>how do you do<br>I really really hope this works for you.","payloadType":"str","x":330,"y":240,"wires":[["a0167b9c185ed265"]]},{"id":"228e5b3e9e8929ab","type":"ui_template","z":"a7f288cd13e5b960","group":"470f560930184392","name":"","order":1,"width":0,"height":0,"format":"<style>\n.lyrics {\n    text-align: center;\n}\n</style>\n","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"global","className":"","x":400,"y":180,"wires":[[]]},{"id":"a0167b9c185ed265","type":"ui_text","z":"a7f288cd13e5b960","group":"9b206ae7211278ff","order":1,"width":"10","height":"5","name":"","label":"","format":"{{msg.payload}}","layout":"col-center","className":"lyrics","style":true,"font":"","fontSize":16,"color":"#000000","x":510,"y":220,"wires":[]},{"id":"470f560930184392","type":"ui_group","name":"Default","tab":"682b35404aa5688c","order":1,"disp":true,"width":"10","collapse":false,"className":""},{"id":"9b206ae7211278ff","type":"ui_group","name":"Default","tab":"d582cfa80fb4f717","order":1,"disp":true,"width":"12","collapse":false,"className":""},{"id":"682b35404aa5688c","type":"ui_tab","name":"Home","icon":"dashboard","order":2,"disabled":false,"hidden":false},{"id":"d582cfa80fb4f717","type":"ui_tab","name":"lyrics","icon":"dashboard","order":1,"disabled":false,"hidden":false}]
I'll still take a look as it may be a more elegant solution, and thank you.
