Dashboard UI disappear
After changing the layout name of the dashboard the UI becomes empty. I don't know the way to rebuild.
immagine
This won't be of much help the the problem, but I too have seen something like that happen.
Alas I can't say what I did to fix it.
I think I changed the name back to what it was and deployed.
the Dashboard came back.
I renamed it again and it worked.
Good luck. But this is just to reassure you: you are not the only one who's seen it.
I solved rebuilding the dashboard. After that, I've checked flags and sets. I think that the dashboard tab has been disabled, but not by me. Maybe automatically?
Thanks for the replay.
F.
Can you describe exactly what you did to cause the problem?
No, I don't remember the exact operations taken. Just, at some point, it happened.
Sorry.
