Hi all,
I am trying to arrange the Dashboard so that I can centre the picture(ui-media) in the centre of the Dashboard. Is there CSS that I need to give the ui-media node or is there some setup in the site area?
You may be able to do it using the dashboard layout option.Select the dashboard button at the top of the right hand pane, select the Layout tab. Hover over the tab containing the group and click Layout. Then you can should be able to move the image across, though you have not told us what widget you are using for that, so it may not be possible.
