Node Red noob,
I am doing an HTTP request and successfully getting that data back fine, I am using JSONata to create an array from that data for use on the dashboard as a table, all that is working fine...I see all the data appropriately on the dashboard. However, I would like to remove array key:value pairs I don't need from the array so the dashboard only displays the desired data. I've tried using a change on the msg.payload to an expression of
$ ~> |$|{}, ['Id', 'IntegrationProjectId', 'ClientId', 'ClientNumber', 'Approved', 'CONumber', 'CurrencyCode', 'Price', 'ImportedOn', 'PublishedOn', 'Deleted']|
and it works in the test of the change when I paste in the array but not in deploy, it turns it back into an object instead of an array with the expression applied.
If anyone can help me out I would appreciate it. I don't want to include the flow because it contains an API key I can't share.
EDIT, here's a flow with an inject with the data I need to remove the fields from for display in the table, the fields I need to remove are above in the expression.
[{"id":"2d4745ba43201053","type":"tab","label":"Flow 2","disabled":false,"info":"","env":[]},{"id":"83c837deb0b211cb","type":"ui_table","z":"2d4745ba43201053","group":"a2a36cb0373d7204","name":"Table","order":5,"width":"0","height":"0","columns":[],"outputs":0,"cts":false,"x":930,"y":140,"wires":[]},{"id":"784789570e33411a","type":"inject","z":"2d4745ba43201053","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[{\"Id\":\"xxx\",\"IntegrationProjectId\":null,\"ClientId\":\"xxx\",\"Client\":\"Dermatology\",\"ClientNumber\":null,\"Name\":\"Waiting Room Monitors\",\"Number\":\"D6\",\"Progress\":\"02 - Estimation (Engineer)\",\"Approved\":false,\"CONumber\":null,\"CurrencyCode\":\"USD\",\"Price\":0,\"ImportedOn\":null,\"PublishedOn\":\"2022-01-13T20:42:00\",\"Deleted\":null},{\"Id\":\"yyy\",\"IntegrationProjectId\":null,\"ClientId\":\"yyy\",\"Client\":\"Northy\",\"ClientNumber\":null,\"Name\":\"AJA 104K Plus\",\"Number\":\"DT5\",\"Progress\":\"02 - Estimation (Engineer)\",\"Approved\":false,\"CONumber\":null,\"CurrencyCode\":\"USD\",\"Price\":0,\"ImportedOn\":null,\"PublishedOn\":\"2022-01-12T22:41:00\",\"Deleted\":null}]","payloadType":"json","x":530,"y":140,"wires":[["83c837deb0b211cb"]]},{"id":"a2a36cb0373d7204","type":"ui_group","name":"Project Information","tab":"f449e75060c583f8","order":1,"disp":true,"width":"6","collapse":false,"className":""},{"id":"f449e75060c583f8","type":"ui_tab","name":"D-Tools Project Data","icon":"dashboard","disabled":false,"hidden":false}]
