How to extract some properties from an array of object?
I believe that's a pretty basic question but I can't sort it out :
Given the following array :
       "TimeStamp":"2022-03-29T10:15:00.000Z",
       "Name":"SN: 2001680707",
       "Type":"SB 3300",
       "Serial":2001680707,
       "TotalYield":228433,
       "Power":600,
       "PVOutput":1
       "TimeStamp":"2022-03-29T10:10:00.000Z",
       "Type":"SB 3300",
       "TotalYield":228383,
       "Power":636,
       "PVOutput":1
I would like to create an array of object from it containing only the TimeStamp and Power keys/values :
         "TimeStamp" : "2022-03-29T10:15:00.000Z",
         "Power" : 600
       "TimeStamp" : "2022-03-29T10:10:00.000Z",
        "Power" : 636
I particularly love Sonata which I find very elegant, but a function would suit as well :blush:
Thanks for your help,
Matthieu
Have a look at this:
[{"id":"7dd0136182e54540","type":"inject","z":"753fdb2386ae42a9","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[    {        \"TimeStamp\":\"2022-03-29T10:15:00.000Z\",        \"Name\":\"SN: 2001680707\",        \"Type\":\"SB 3300\",        \"Serial\":2001680707,        \"TotalYield\":228433,        \"Power\":600,        \"PVOutput\":1    },    {        \"TimeStamp\":\"2022-03-29T10:10:00.000Z\",        \"Name\":\"SN: 2001680707\",        \"Type\":\"SB 3300\",        \"Serial\":2001680707,        \"TotalYield\":228383,        \"Power\":636,        \"PVOutput\":1    } ]","payloadType":"json","x":150,"y":120,"wires":[["c474eaf52ea22f1e"]]},{"id":"68f62b358958c059","type":"debug","z":"753fdb2386ae42a9","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":630,"y":120,"wires":[]},{"id":"c474eaf52ea22f1e","type":"change","z":"753fdb2386ae42a9","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"[{\t        \"TimeStamp\": payload[0].TimeStamp,\t        \"Power\": payload[0].Power\t    \t    },\t    {\t        \"TimeStamp\": payload[1].TimeStamp,\t        \"Power\": payload[1].Power\t    }\t]","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":400,"y":120,"wires":[["68f62b358958c059"]]}]
This page explains how to get the path to object properties:
https://nodered.org/docs/user-guide/messages
Like this:
Screenshot-7
Or, if the array is of variable length, then assuming it is in msg.payload a Function node containing this should do the job
msg.payload = msg.payload.map((element) => ({TimeStamp: element.TimeStamp, Power: element.Power}))
Thanks @ghayne, as @Colin guessed, my array's length is variable and therefore the obvious solution doesn't work, sorry for not mentioning it.
@Colin perfect ! I'm not fluent in Javascript. I did found the .map object but missed the element thing you used here. I'm good now, let's put some more nodes :blush:
@Colllin, I should actually have an array of arrays containing the objects.
Something like this :
         "Power" : 600
        "Power" : 636
How would I achieve this ?
Txs
Modify @colin's code by inserting array brackets:
msg.payload = msg.payload.map((element) => ([[{TimeStamp: element.TimeStamp, Power: element.Power}]]))
I really must learn Javascript. Thanks @ghayne !
Does that do what you want? I would have thought you only want one set of brackets.
msg.payload = msg.payload.map((element) => ([{TimeStamp: element.TimeStamp, Power: element.Power}]))
Exactly @Colin. I was wondering why two brackets and soon discovered that one was more than enough :wink:
@colin, correct!
So, just for fun, any idea how to do this using Jsonata ? There is a $map() function but no idea how to use it.
[{"id":"7dd0136182e54540","type":"inject","z":"753fdb2386ae42a9","name":"","props":[{"p":"payload"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"[    {        \"TimeStamp\":\"2022-03-29T10:15:00.000Z\",        \"Name\":\"SN: 2001680707\",        \"Type\":\"SB 3300\",        \"Serial\":2001680707,        \"TotalYield\":228433,        \"Power\":600,        \"PVOutput\":1    },    {        \"TimeStamp\":\"2022-03-29T10:10:00.000Z\",        \"Name\":\"SN: 2001680707\",        \"Type\":\"SB 3300\",        \"Serial\":2001680707,        \"TotalYield\":228383,        \"Power\":636,        \"PVOutput\":1    } ]","payloadType":"json","x":150,"y":120,"wires":[["c474eaf52ea22f1e"]]},{"id":"68f62b358958c059","type":"debug","z":"753fdb2386ae42a9","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":630,"y":120,"wires":[]},{"id":"c474eaf52ea22f1e","type":"change","z":"753fdb2386ae42a9","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$map(\t   payload,\t   function($v,$i) {\t       [{\t           \"TimeStamp\":$v.TimeStamp,\t           \"Power\":$v.Power\t       }] \t   }\t)","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":380,"y":120,"wires":[["68f62b358958c059"]]}]
Look here for an explanation:
If you don't know javascript of jsonata I suggest starting with javascript. Once you are proficient with that then try jsonata. I unless you have more brain power than I have anyway. For me learning one new language at a time is more than enough :slight_smile:
True. However, my brain feels more adapted to the JSONata way of doing this, probably because it's more visual (and that's also why I love coding in NodeRed). @ghayne 's solution works brilliantly by the way :
$map(
   payload,
   function($v,$i) {
           "time":$toMillis($v.TimeStamp),
           "Power":$v.Power
Since I asked preferably the JSONata code, I think he deserves the "solution" tag, but thank you both of you really for your support.
Matthieu
In that case by all means do that. Mine most definitely is happier with the procedural route.
No need to call the $map() function
This also maps
$$.payload.[{
       "TimeStamp":$toMillis($.TimeStamp),
       "Power":$.Power
I love jsonata so much :heart::heart::heart:
Ah @E1cid I knew you were around somewhere :slight_smile:
