Data length error, expected x got y (x > y)
We can communicate with a device at /dev/ttyAMA0.
It uses ModBus RTU, 9600 baud rate.
But when I try to read data according to the documentation of the device I am getting the error:
"Data length error, expected 7 got 2"
The reading configuration:
    'fc': 3, // Modbus function 0x03
    'unitid': 0,
    'address': 2,
    'quantity': 1
We also get a timeout error quite often. So there might be problems regarding parity and stop bits, but I cannot see, how we configure this in node-red-contrib-modbus.
Any idea for the reason of this kind of problem?
Can you send part of the flow? Tell me what device it is.
I think I once had a case where the device responded to an even number in quantity.
I've figured how to set parity and the number of data bits etc
This can be done by selecting Serial Expert for the modbus server.
I think the problem could also be caused by missed termination in the RS485 network, because no matter what I am trying with baud rate, parity, data bits etc., I am getting errors only (data length error or timeout). So we will check the hardware configuration there, too.
Here is the flow, but
        "id": "1d730243db9feb8a",
        "type": "tab",
        "label": "ModBus Seriell ClampOn ",
        "disabled": false,
        "info": "",
        "env": []
        "id": "a4c9a2f40bc6910c",
        "type": "modbus-flex-getter",
        "z": "1d730243db9feb8a",
        "name": "Serial ModBus ClampOn",
        "showStatusActivities": true,
        "showErrors": true,
        "showWarnings": false,
        "logIOActivities": false,
        "server": "9918af96579ce096",
        "useIOFile": false,
        "ioFile": "",
        "useIOForPayload": false,
        "emptyMsgOnFail": false,
        "keepMsgProperties": true,
        "delayOnStart": false,
        "enableDeformedMessages": false,
        "startDelayTime": "2",
        "x": 570,
        "y": 180,
                "1e69851eced5d421"
                "699db3ec86531f6b"
        "id": "7bb0e6a2935402b5",
        "type": "inject",
        "name": "trigger",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "true",
        "payloadType": "bool",
        "x": 110,
        "y": 100,
                "cdacefc17ac2b270"
        "id": "cdacefc17ac2b270",
        "type": "function",
        "name": "FC ??? -- 4 517 [6]",
        "func": "\nmsg.payload = { \n    // value is true WHY ????\n    // value: msg.payload,\n    // https://blog.softwaretoolbox.com/opc-modbus-function-codes\n    'fc': 3,\n    'unitid': 0,\n\n    'address': 1,\n    'quantity': 1\n};\nreturn msg;",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 330,
        "y": 180,
                "a4c9a2f40bc6910c"
        "id": "1e69851eced5d421",
        "type": "debug",
        "name": "debug 4",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "false",
        "statusVal": "",
        "statusType": "auto",
        "x": 820,
        "y": 140,
        "id": "699db3ec86531f6b",
        "type": "debug",
        "name": "debug 7",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "statusVal": "",
        "x": 820,
        "y": 220,
        "id": "9918af96579ce096",
        "type": "modbus-client",
        "clienttype": "serial",
        "bufferCommands": true,
        "stateLogEnabled": true,
        "queueLogEnabled": false,
        "failureLogEnabled": true,
        "tcpHost": "127.0.0.1",
        "tcpPort": 502,
        "tcpType": "DEFAULT",
        "serialPort": "/dev/ttyAMA0",
        "serialType": "RTU",
        "serialBaudrate": "9600",
        "serialDatabits": "5",
        "serialStopbits": 1,
        "serialParity": "none",
        "serialConnectionDelay": 100,
        "serialAsciiResponseStartDelimiter": "0x3A",
        "unit_id": 0,
        "commandDelay": 0,
        "clientTimeout": 2000,
        "reconnectOnTimeout": false,
        "reconnectTimeout": 2000,
        "parallelUnitIdsAllowed": false,
        "showErrors": true,
        "showWarnings": true,
        "showLogs": true
        "id": "2d201daaac4afbbb",
        "type": "global-config",
        "env": [],
        "modules": {
            "node-red-contrib-modbus": "5.44.1"
But I cannot change the value for this configuration field: "serialAsciiResponseStartDelimiter": "0x3A", right?
