Hi all,
I'm using a P30H captor from Lummel and I would like to collect the value from the captor by the Modbus TCP/IP Protocol.
I verified the slave id, register and IP adress with Modbus Doctor.
But when I tried to get the value in Node-Red, I get this error ;
Do you have any idea for solving it ?
[{"id":"684f0762.d4f9e8","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"8fc69fba.ad7e1","type":"debug","z":"684f0762.d4f9e8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":730,"y":220,"wires":[]},{"id":"e306c8fc.aed118","type":"modbus-flex-getter","z":"684f0762.d4f9e8","name":"","showStatusActivities":true,"showErrors":true,"logIOActivities":false,"server":"5a4d7d51.7640b4","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":true,"keepMsgProperties":false,"x":510,"y":180,"wires":[["2cc5fcc0.0200e4"],["8fc69fba.ad7e1"]]},{"id":"2cc5fcc0.0200e4","type":"modbus-response","z":"684f0762.d4f9e8","name":"","registerShowMax":"100","x":750,"y":120,"wires":[]},{"id":"b5da8ef4.7de02","type":"function","z":"684f0762.d4f9e8","name":"","func":"msg.payload = { \n value: msg.payload, \n 'fc': 3, \n 'unitid': 1, \n 'address': 7500,\n 'quantity': 2\n} \nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":300,"y":180,"wires":[["e306c8fc.aed118"]]},{"id":"9c5dd677.2cdfc8","type":"inject","z":"684f0762.d4f9e8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"str","x":110,"y":180,"wires":[["b5da8ef4.7de02"]]},{"id":"5a4d7d51.7640b4","type":"modbus-client","z":"","name":"Capteur P30H","clienttype":"tcp","bufferCommands":false,"stateLogEnabled":true,"queueLogEnabled":true,"tcpHost":"192.168.0.9","tcpPort":"502","tcpType":"DEFAULT","serialPort":"/dev/ttyUSB","serialType":"RTU-BUFFERD","serialBaudrate":"9600","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"100","unit_id":"1","commandDelay":"1","clientTimeout":"1000","reconnectOnTimeout":true,"reconnectTimeout":"2000","parallelUnitIdsAllowed":true}]
Thanks a lot for your help
